Valve Adjustment 03 600rr - Wrist Twisters
post #1 of 26 Old 04-07-2008, 10:49 AM Thread Starter
Hastatus Prior
eazy e's Avatar
So I am a bit over due for my valve adjustment. I have some time scheduled at the end of this month to get the new exhaust mapped/tuned on the dyno, so I want to get this done ahead of time.
Is there a shim kit or anything specific that I need to buy in order to do this???
Thanks
Erick
+ $5
eazy e is offline
post #2 of 26 Old 04-07-2008, 10:52 AM
Those 2 Mofos Rollin
Snikwad's Avatar
as far as i know, you just buy shims as needed. im over due also, wanna do mine.
Buy my Pirelli supercorsa takeoffs. sizes 120/180
Originally Posted by McCrimmon View Post
...I'm slowly prepping the FZ...Goin to VIR with NESBA most likely next year since they are reasonably priced
^ Mark his words.
My 1000RR
Im on another forum.
Snikwad is offline
post #3 of 26 Old 04-07-2008, 11:26 AM
Wookie
ragdoll's Avatar
I'm going to wait til 50,000 miles to do mine.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #4 of 26 Old 04-07-2008, 11:36 AM
I just received 10 shims for the 9er from socali919. Wonder if they are the same for the 600's? Hmmm...
post #5 of 26 Old 04-07-2008, 11:40 AM Thread Starter
Hastatus Prior
eazy e's Avatar
Its due for an adjustment per maintenance book etc, but it started doing it after I crashed it. Could a crash cause this to happen???
Guess I better order some shims
+ $5
eazy e is offline
post #6 of 26 Old 04-07-2008, 11:43 AM
Erick, don't order any shims. Measure the valve lash first then see what shims you need.
post #7 of 26 Old 04-07-2008, 11:45 AM Thread Starter
Hastatus Prior
eazy e's Avatar
alright, I guess I need to get on this. Noticed it was ticking pretty bad the other day when I started it up. hasn't been running since I crashed it last summer.
+ $5
eazy e is offline
post #8 of 26 Old 04-07-2008, 11:48 AM
Might only be from sitting and not running. How long did you let it run and is the oil fresh?
post #9 of 26 Old 04-07-2008, 11:51 AM Thread Starter
Hastatus Prior
eazy e's Avatar
Oil is not fresh...needs changed. I let it run for 3-4 minutes max.
+ $5
eazy e is offline
post #10 of 26 Old 04-07-2008, 11:54 AM
Wookie
ragdoll's Avatar
I would change oil and put in some fresh high octane gas to see if it goes away.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #11 of 26 Old 04-07-2008, 11:57 AM Thread Starter
Hastatus Prior
eazy e's Avatar
how do you guys dispose of Gas??
Besides starting the neighborhood on fire
+ $5
eazy e is offline
post #12 of 26 Old 04-07-2008, 12:03 PM
I wait until my wife jumps in bed then pull the covers over her head.
Seriously; dump it into one of your 4 wheel vehicles.
post #13 of 26 Old 04-07-2008, 02:48 PM
Trackday Recognition
yeah, if you mix it into a bigger tank on a car it won't be an issue. E, how many miles do you have? i check mine at almost 17k, had 1 valve that was SLIGHTLY out of spec, not worth doing the entire job according to my old Service Manager (who is an anal-retentive airplane tech). let it get to full temp a few times and see how it sounds.
blueblur is offline
post #14 of 26 Old 04-07-2008, 09:29 PM
Snikwad's Avatar
I've been told by quite a few techs, that most hondas rarely ever need adjustments at the recomended period. So I'm not sweating mine.
^ Mark his words.
My 1000RR
Snikwad is offline
post #15 of 26 Old 04-08-2008, 05:08 AM Thread Starter
Hastatus Prior
eazy e's Avatar
alright, so an update on this...more problems.
When I got home last night I started the bike up and let it run for a bit. Maybe 5 minutes or so. The temps were measuring around 160ish. I started to slowly increase the throttle, trying to listen if it was ticking with the RPM of the motor; increase vs decrease. Yep, definitely is.
So I reved it up a couple times and then heard a small pop and the ticking got worse. Look under the bike and it was spitting out coolant (not a lot, just drops at a time) from around the area of the coolant reservoir. Not sure what is causing this. I am pretty sure there is no serious engine damage but I need to check all the lines coming and going from the radiator as well as the water pump and see whats up with it.
fuk, there's always something.
+ $5
eazy e is offline
post #16 of 26 Old 04-08-2008, 05:16 AM
Don't panic... Sounds like the thermostat might be frozen shut. Pull that sucker out and test it. It's easy to do, place it in a pot of boiling water and see if it opens up.
post #17 of 26 Old 04-08-2008, 05:18 AM Thread Starter
Hastatus Prior
eazy e's Avatar
I'm just wondering if a line is squashed somewhere. Had no problems with the motor pre-crash.
+ $5
eazy e is offline
post #18 of 26 Old 04-08-2008, 05:23 AM
Good point; always check to obvious first.
post #19 of 26 Old 04-08-2008, 07:05 AM
the hose on the left side of the frame/radiator isn't crushed is it?
blueblur is offline
post #20 of 26 Old 04-08-2008, 07:55 AM Thread Starter
Hastatus Prior
eazy e's Avatar
I don't think so, but I will look into everything closely soon.
where is Gbord, he could tell a story about this.
+ $5
eazy e is offline
post #21 of 26 Old 04-09-2008, 05:19 AM Thread Starter
Hastatus Prior
eazy e's Avatar
actually a thanks to Gbord. He advised me of the likely problem.
Loose headers! fixed.
+ $5
eazy e is offline
post #22 of 26 Old 04-09-2008, 05:43 AM
Unbannable
Super Sneaky Steve's Avatar
How do lose headers cause coolant to leak?
Super Sneaky Steve is offline
post #23 of 26 Old 04-09-2008, 05:54 AM Thread Starter
Hastatus Prior
eazy e's Avatar
hahah, my bad. I was more concerned with the ticking sound.
The coolant leak is still there, but not related. Its coming from a loose hose on the reservoir I believe.
+ $5
eazy e is offline
post #24 of 26 Old 04-09-2008, 05:22 PM
wow that's a good call! gonna store that in the back of my trouble-shooting mind!
blueblur is offline
post #25 of 26 Old 04-09-2008, 05:30 PM
It helps when the symptoms are explained correctly!
post #26 of 26 Old 04-09-2008, 05:34 PM
Brain stolen again?
Excelent advice by gbord. He should receive casino money plus accolades and fix him up with some appropriate sexual favors.
Mathew Quigley
