Starting in gear. - Wrist Twisters
post #1 of 10 Old 08-27-2006, 08:29 PM Thread Starter
Wookie
ragdoll's Avatar
Starting in gear.
Am I crazy, or is the RC51 supposed to be startable when in gear as long as the clutch is in? Since I'm really cool, I stalled my bike in a busy intersection today and went to start it and nuttin. Had to go to neutral first and then start it and then go back to gear.
The two wires that run to the clutch are plugged in. I took them off and reseated them and nothing.
Anyone? Thanks.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #2 of 10 Old 08-27-2006, 08:34 PM
Removed User 1
Guest
Posts: n/a
Did you check the kick stand switch?
post #3 of 10 Old 08-27-2006, 08:44 PM Thread Starter
Wookie
ragdoll's Avatar
Good idea. I just checked it, it's plugged in. It's still under warranty for a while, I GUESS I could just have them fix whatever it is.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #4 of 10 Old 08-27-2006, 09:41 PM
The Guy passing you...
Evad101's Avatar
Donation Donation BOTM Donation
Check the micro switch on the clutch lever. Sometimes the wires to it pop off.
-Dave
Evad101 is offline
post #5 of 10 Old 08-28-2006, 07:15 AM
Hmmmmmmm try turning the key on.
dadogs is offline
post #6 of 10 Old 08-28-2006, 11:11 AM
If it's like the 600RR the clutch sensor is on the left-hand side by the tranny. Is the Neutral light on when you put the bike in neutral?
NewRedRider is offline
post #7 of 10 Old 08-28-2006, 11:28 AM
Left Hand Suzuki Method
dayrock's Avatar
"excellent... I see my device is working properly."
5,
4,
3,
2,
boom!
dayrock is offline
post #8 of 10 Old 09-02-2006, 10:44 PM
Removed User 1
Guest
Posts: n/a
RagDoll did you get this checked out?
post #9 of 10 Old 09-03-2006, 10:55 AM
He still can't find the key....I think Wim may have stole it out of not having a bike jealousy type thingy.
dadogs is offline
post #10 of 10 Old 09-12-2006, 11:35 AM Thread Starter
Wookie
ragdoll's Avatar
I JUST got off the phone with the dealership, it's going in Friday to get fixed. He said they did a little research on it and are going to order up a sensor just in case. I'll let you know what's wrong with it when I get it back.
'02 RC-51
'10 Unicycle
ragdoll is offline
