busa issue - Wrist Twisters
post #1 of 14 Old 10-18-2008, 11:19 PM Thread Starter
hellrazor3114's Avatar
busa issue
ok as everyone knows I now own a 05 busa, well As of now I love everything about the bike. Today I rode the bike to work and on the way home I noticed that when I put it in gear it moves on its own like the clutch isnt totally disengaging, the clutch lever doesnt do anything untill about the last 1/4 part of pull. The hydrolic fluid for the clutch is also full. Could the 40 degree temp outside tonight have something to do with this or is it maybee something more severe?
theres no such thing as stupid questions only stupid people
hellrazor3114 is offline
post #2 of 14 Old 10-19-2008, 08:04 AM
Has the fluid been changed? Sadly, I have found that many "Big Bike" owners are the worst for maintenance. They may check the tire pressure and lube the chain, but are usually all talk about knowing bikes. Many, many posers!
Change the fluid and I believe you have a lever throw adjustment. Adjust it to where you feel is best suited for your riding style.
RC51_CBRXX is offline
post #3 of 14 Old 10-19-2008, 08:32 AM
+1 Yeah, what he said...
Check adjustments...
post #4 of 14 Old 10-19-2008, 11:09 AM Thread Starter
ok I changed the fluid today by completely draining the system, then added new fluid, bled the system, but now the clutch doesnt work at all and there is no resistance to the cluth lever at all
post #5 of 14 Old 10-19-2008, 11:12 AM
keep bleeding the line. It will come to soon enough.
post #6 of 14 Old 10-19-2008, 12:50 PM
As mentioned, you still have air in the line. Keep bleeding. It can come very easily at times and can take an ungodly amount of time at other times. A decent inexpensive bleed vacuum is a great thing to have. A great thing to put on Christmas and Birthday lists.
Unlock, smooth slow squeeze on the clutch lever, lock, release, unlock, smooth slow squeeze on the clutch lever, lock, etc. Get a rhythm down. Make certain it is nice and clear ... waste a little fluid if you must.
post #7 of 14 Old 10-20-2008, 08:01 AM
Donation BOTM
Howd it go ? Those are the WORST about getting air in the lines -
2ohno is offline
post #8 of 14 Old 10-20-2008, 04:10 PM Thread Starter
yes they are definatially the worst so far, I actually bleed the thing so much that I went threw half a small bottle of brake fluid then it still didnt work. So I left it alone and was going to go 2marrow to get a vacume bleeder. While I was working on my garage I thought of a way that may work.... Tip th bike to its right side. With the help of my brother we tipped it so that the peg was almost on the ground and held it there wile we pumped the clutch handle, held the handle in wile sitting her up then cracked open the bleeder... Yay all bubbles came out and the clutch works great again...
post #9 of 14 Old 10-20-2008, 06:32 PM
That's good news. Hopefully that will not be the max that the bike will ever see?!
post #10 of 14 Old 12-14-2008, 06:02 PM Thread Starter
well the bleeding didn’t help I went out yesterday to move the bike from my in-laws garage into mine and the clutch wasn’t disengaging again even after it warmed up in my garage. Could it be the line going from the master cylinder to the slave? Or possibly my slave?
post #11 of 14 Old 12-14-2008, 07:03 PM
Speed Lover
XRCajun's Avatar
Did you try adjusting the lever?
XRCajun is offline
post #12 of 14 Old 12-14-2008, 08:19 PM
Go'n So slow I'm stopped
xrmikey's Avatar
Sounds like a slave cylinder.
Check the push rod for binding &/or sticking. Grease well when reinstalling.
xrmikey is offline
post #13 of 14 Old 12-14-2008, 09:00 PM Thread Starter
Yes the lever has 5 settings and I tried them all. I will be checking the slave whenever i get a chance. I am currently stuck at work since 2pm and here till atleast 8am.
post #14 of 14 Old 12-15-2008, 08:12 AM
Donation BOTM
Have you cracked the bolts loose at the cyclinder and made sure there is no air trapped there ? Lots of times you and bleed a bottle of fluid through a system and still have some air trapped at the connections -
2ohno is offline
