WTB Handlebar Holder - Wrist Twisters
post #1 of 9 Old 03-14-2013, 09:46 AM Thread Starter
Todi's Avatar
WTB Handlebar Holder, Honda part # 53131-MCZ-000. My 9er came with handlebar risers and I would like to try the bike without it.
Thanks
Todi is offline
post #2 of 9 Old 03-14-2013, 10:56 AM
rpcraft's Avatar
Do the risers not have a cap that can just come off and go on top of the triple clamp? I'm sure those risers just bolt down to the OE clamp and can come undone...
Just trying to think of a no cost solution for ya.
rpcraft is offline
post #3 of 9 Old 03-14-2013, 11:03 AM Thread Starter
Todi's Avatar
I have a little offset, but if the bolts are all the way through, it may work. I'll try that. Thanks
Todi is offline
post #4 of 9 Old 03-14-2013, 02:24 PM
rpcraft's Avatar
Yeah, if it is an offset ad they are anything like mine were there should be 3 sets of bolts. One set (the middle two, which are longer than the other 2 sets) goes all the way through the riser cap, the riser extension and then into original triple riser. Then the other 2 sets of bolts are the original shorter bolts. One will be holding the clamp caps to the offset riser (bottom most likely) and the top most one will be holding the riser extension to the original triple . You should be able to take off all 3 sets of bolts and then set the riser extension and longer set of bolts to the side. If it's anything like mine was it will have little chrome plastic caps on the allen head bolts and you can just use a knife edge to pry them up and see.
rpcraft is offline
post #5 of 9 Old 03-14-2013, 02:47 PM Thread Starter
Todi's Avatar
It looks like this. It could be just two long bolts, not the original ones.
Looks like the top riser is not the original clamp either.
The bolts are over tight so I'll stop by the local dealer first to get some extra (just in case I mess it up).
Todi is offline
post #6 of 9 Old 03-14-2013, 02:54 PM
I have a set available, I may have the bolts as well. Have to check on the bolts.
PM sent!
post #7 of 9 Old 03-14-2013, 03:07 PM
rpcraft's Avatar
Yeah those are definitely a different type than I thought about when you said offset. Sorry man.
rpcraft is offline
post #8 of 9 Old 03-14-2013, 03:14 PM
PM sent!
Got a full set if bolts as well!
post #9 of 9 Old 03-14-2013, 03:15 PM
They look like the SW-Motech handlebar risers - SW-MOTECH 30mm handlebar riser for 28mm OD bars - TwistedThrottle.com
Those looks like just longer bolts.
