WTB - 919 or comparable factory tool kit - Wrist Twisters
post #1 of 8 Old 08-25-2014, 11:53 AM Thread Starter
alekkas's Avatar
Can't beat factory kits for a set of what you'd need most in a compact size that fits under the seat.
Not sure what other models would also work.
THanks
Some ride reports:
http://leroylanes.blogspot.com/
On two wheels:
alekkas is offline
post #2 of 8 Old 08-25-2014, 12:00 PM
The only tools worth buying in the tool kit are the spark plug wrench and the spanner for adjusting the rear shock. I just ordered those two from my local dealer. The rest are just common tools like allen wrenches, screwdrivers, and pliers.
post #3 of 8 Old 08-25-2014, 02:44 PM
Yup. 6/8/10/12 and even 14mm are the go to wrenches, maybe even one of those small socket sets as well.
post #4 of 8 Old 08-25-2014, 04:31 PM Thread Starter
alekkas's Avatar
So, on my Concours, basically no spark plug socket in the entire world worked except for the one in the tool kit. Same here? I have a spanner that will work for the shock.
Some ride reports:
On two wheels:
alekkas is offline
post #5 of 8 Old 08-25-2014, 09:09 PM
Some folks here have had some success with their own sockets and universal joints, but that spark plug wrench is worth it's weight in gold for plug #3. If you wait and change your plugs at the same intervals as valve clearance checks....any old setup will work.
The issue with #3 is there is normally a lot of stuff in the way, plus it's right under the frame.
post #6 of 8 Old 09-06-2014, 11:53 AM
PAULIBIKER is offline
post #7 of 8 Old 09-06-2014, 05:23 PM
i had no issues with #3 when i did my plugs... just needed the right lenghts of extension(s)
really all you gotta do is loosen it.... then use a piece of vacuum tube to slide over the end to pull it out.
post #8 of 8 Old 09-06-2014, 06:42 PM
Or an old plug wire with the other end chopped off (personal preference)
