Wtb 919 center stand - Wrist Twisters
post #1 of 15 Old 09-02-2014, 04:41 AM Thread Starter
Cheese's Avatar
I am looking for a center stand for my 04 919.
Cheers
Cheese is offline
post #2 of 15 Old 09-02-2014, 11:14 AM
derpydog's Avatar
derpydog is offline
post #3 of 15 Old 09-02-2014, 06:06 PM
Have one ready to go
OEM w instructions. Used one season and in good condition. $150 + shipping from 48124.
cheers-J
CaptianJ is offline
post #4 of 15 Old 09-03-2014, 04:54 PM
PM sent
CaptianJ is offline
post #5 of 15 Old 09-04-2014, 03:45 AM Thread Starter
Cheese's Avatar
Thanks J. I saw your pm before I saw this post. Forgive the questionsin the PM. It will be obvious I didn't read your post. New pm is coming.
Cheers
Cheese is offline
post #6 of 15 Old 09-04-2014, 03:53 AM Thread Starter
Cheese's Avatar
Thanks for the lead Derpy. I will look into that one more if the captain's stand doesn't work out for me.
On a side note, I noticed you commented on some difficulties with the install in that thread. Any pointers about installing it?
Cheers
Cheese is offline
post #7 of 15 Old 09-04-2014, 09:56 AM
derpydog's Avatar
Man, I had to basically disconnect every part of the exhaust system that could be disconnected to get enough of a gap at the Y-pipe joint where the centerstand is supposed to slip in... if you're the paranoid type I'd maybe pick up new exhaust gaskets just in case you end up dropping the headers all the way out but otherwise really there's nothing to it. It's incredibly simple, just a pain in the ass. Ended up taking me maybe two or three hours including the time it took to figure out a way to pull the springs.
derpydog is offline
post #8 of 15 Old 09-04-2014, 08:05 PM
Stand
Done & done. The exhaust gaskets on mine still work great after the un-install, HONDA quality. The trick for the springs is to put quarters (or nickles) between the coils so you don't have as far to pull to install (worked great on removal as well). Hope this helps.
cheers- J
CaptianJ is offline
post #9 of 15 Old 09-04-2014, 08:42 PM
derpydog's Avatar
I tried the coin thing-- or rather, intended to. But how do you get it to work when it's one spring inside another?!
I ended up using a ratchet strap and the garage door frame. Felt pretty sketchy but it got it done...
derpydog is offline
post #10 of 15 Old 09-05-2014, 07:00 AM
I wrapped a thin nylon "rope" around the springs and tied the other end to my waist and crawl/walked forward until it was stretched enough that my girlfriend could slide it onto the post...
post #11 of 15 Old 09-05-2014, 07:17 AM
For the inner spring I used some FM to make it work...
cheers-J
CaptianJ is offline
post #12 of 15 Old 09-05-2014, 07:46 AM
Originally Posted by badmoon692008 View Post
... it was stretched enough that my girlfriend could slide it onto the post...
Do tell....
post #13 of 15 Old 09-05-2014, 08:57 AM Thread Starter
Cheese's Avatar
[QUOTE="CaptianJ;905674"]For the inner spring I used some FM to make it work... cheers-J[/QUOTE
FM?
Cheese is offline
post #14 of 15 Old 09-05-2014, 10:07 AM
Freakin Magic!
CaptianJ is offline
post #15 of 15 Old 09-10-2014, 09:42 AM Thread Starter
Cheese's Avatar
I haven't center stand. Installed. Coins and Freakin magic were employed for the springs.
Now my bike is sitting high and proud when parked.
Thanks again to all for the advice.
Cheese is offline
