rear cush drive needed - Wrist Twisters
post #1 of 15 Old 05-01-2015, 01:19 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
I'm putting on my new sprocket set and the nut and bolt strip on the sprocket carrier / cush drive. I Need one asap. Anyone have one lying around?
spyke1019 is offline
post #2 of 15 Old 05-01-2015, 01:40 PM
I think I do .... but am in Canada. I'll take a look tonight and let you know.
post #3 of 15 Old 05-01-2015, 01:41 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
Thanks
post #4 of 15 Old 05-01-2015, 01:42 PM
post #5 of 15 Old 05-01-2015, 01:46 PM
I think they are the same? .... I would guess they are.
post #6 of 15 Old 05-01-2015, 01:47 PM
Is this technology a possible solution?
HeliCoil
K1w1Boy is offline
post #7 of 15 Old 05-01-2015, 01:48 PM
post #8 of 15 Old 05-01-2015, 01:59 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
If they fit how much for it shipped to 32024?
post #9 of 15 Old 05-01-2015, 01:59 PM
The 900RR dampers have a different number but they work fine, I have them in my rear wheel now
post #10 of 15 Old 05-01-2015, 02:01 PM
Sorry, you're talking about the flange, also a different number than the 9er but looks identical
post #11 of 15 Old 05-01-2015, 02:05 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
HeliCoil
That's more than I want to mess around with. Is rather just but one
post #12 of 15 Old 05-01-2015, 02:24 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
So I found out it's not the bolt that's the problem the nut threads came off in the threads of the bolts. Headed to Napa now for new flange bolts
post #13 of 15 Old 05-01-2015, 02:50 PM
Since I am in the middle of a 6-spoke wheel conversion and full black out powder coat on another members 919 .... I have all the parts to compare everything on hand.
The 900rr & CB919 cush drives are the exact same. The casting on the 900rr cush is rougher, and they have different part numbers. But as far as I can tell they are the same. I mixed and matched the sprockets/wheels and cushs between a 900rr and 919 wheel and everything installs easily with no real difference.
CBR900RR cush on the left ..... CB919 cush on the right.
post #14 of 15 Old 05-01-2015, 05:47 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
Thank you. I got it all back together and running but I still have a bit of tweak in the rear sprocket. I think the carrier might be bent slightly. So I still want to buy one. I got Ldh's 17/44 conversion and chain so I don't want to risk it.
post #15 of 15 Old 05-02-2015, 04:43 AM
PM sent.
