Looking for frame sliders - Wrist Twisters
post #1 of 26 Old 08-13-2012, 11:21 AM Thread Starter
Dragon Slayer
oak1971's Avatar
Any suggestions on what best suits the 919? I'm open to used ones if they are out there.
oak1971 is offline
post #2 of 26 Old 08-13-2012, 11:32 AM
Motovation.
post #3 of 26 Old 08-13-2012, 12:00 PM
Omnivore
acall's Avatar
Motovation.
+1
Honda CB900F / 919 Hornet Frame Sliders
you will need to drill the frame out to fit the mounting rod, but it isn't too difficult.
acall is offline
post #4 of 26 Old 08-13-2012, 12:46 PM
garyb900 is offline
post #5 of 26 Old 08-13-2012, 12:51 PM
Originally Posted by acall View Post
+1
I have a 919 with the frame holes already drilled out - all you need to do is supply the sliders ...
post #6 of 26 Old 08-13-2012, 01:40 PM
+1
I feel that drilling and tapping is superior to the pass through rod.
If nothing else it's lighter and more purpose specific looking as compared to a low grade adaptation.
post #7 of 26 Old 08-13-2012, 05:53 PM Thread Starter
Dragon Slayer
oak1971's Avatar
Says that the new version requires no drilling. Bonus. Thanks to all.
oak1971 is offline
post #8 of 26 Old 08-13-2012, 06:05 PM
Meaning the rod is skinny so it fits in the existing hole ?
And therefore weaker.
UNbonus.
post #9 of 26 Old 08-13-2012, 06:23 PM Thread Starter
Dragon Slayer
oak1971's Avatar
UNbonus.
Well yes, there is that.
oak1971 is offline
post #10 of 26 Old 08-13-2012, 06:48 PM
On the Motovation site on the 919 page it says "PLEASE NOTE that drilling/reaming of the frame to accept a 10mm rod is required" Is there a newer version?
post #11 of 26 Old 08-13-2012, 07:22 PM
heist's Avatar
just got my motivation sliders a month ago and still had to drill, could use almost any brand slider if got your own rod and ran a die down each side to thread it, was happy with motivation sliders and had great service from them.
954 front forks
LsL triple tree
pro taper bars
Sato rear sets
F4I Guages
Two Bros pipe
heist is offline
post #12 of 26 Old 08-14-2012, 10:06 AM Thread Starter
Dragon Slayer
oak1971's Avatar
Guess I failed reading comprhension. I'm not sure that I want to punch bigger holes.
oak1971 is offline
post #13 of 26 Old 08-14-2012, 10:33 AM
It's not a big deal. The tube the threaded rod goes thru is big enough. Its just the holes at the end. So it's not much to drill.
post #14 of 26 Old 08-14-2012, 11:14 AM
Family Dog
Bowwow's Avatar
If I was to buy new sliders I would get the motivation sliders. They look like they are designed the best with the 10mm Stainless steel rod through the frame.
I bought some LSL sliders last year at the MotoGP for my 599. They are engine mounted ones that I know now are bad. since I already paid good money for these....I fit them on my 919. I had to make different spacers then drilled and taped the Frame holes to 10mm. The only problem I can see is that they are high rated engine mount bolt that may not bend in a crash and there for damage the frame. What do you think? should I get lower grade bolts that would bend or do you think I am fine?
2002 Honda 919 in Fast Black
2006 Honda 599 sold
1999 Honda CR 250
Bowwow is offline
post #15 of 26 Old 08-14-2012, 11:21 AM Thread Starter
Dragon Slayer
oak1971's Avatar
Ok. That's not too bad then.
Next question, are they strong enough to support the front of the bike when I take the forks off?
oak1971 is offline
post #16 of 26 Old 08-14-2012, 11:34 AM
Grade 8 bolts or metric equivalent are the wrong thing to use for anything but pure tensile loading of the fastener.
Use Grade 5 or metric 8.8.
Cheaper and better for the application.
post #17 of 26 Old 08-14-2012, 12:13 PM
Er, yeah, I wouldn't do that!
Save those bolts the tension and stress for when (if ever) they are needed; don't induce weakness by putting stress on them.
Besides, those bolts and sliders are meant to take frontal impact; not sure if they were necessarily (specifically) designed to to handle side or shearing loads directly. And you'd also be lifting by the Delrin sliders - they are not as strong as the bolts and WILL bend/brake.
I'm sure they probably could support the weight, but you're going to induce weakness and stress that could cause problems later.
If you need to raise the bike, put a 3/8's rebar in the center stand holes and put the bike up on jack stands. Then put an A-frame ladder straddling the handlebars and throw a couple of tie-downs under the neck of the frame. You can take the entire front end off of the bike this way; I've done it multiple times.
That last one looks like she's flying!!!
post #18 of 26 Old 08-14-2012, 08:42 PM Thread Starter
Dragon Slayer
oak1971's Avatar
That is cool. My garage has no exposed rafters so I'm going to need to use your method.
oak1971 is offline
post #19 of 26 Old 08-15-2012, 06:01 AM
Family Dog
Bowwow's Avatar
I was thinking that was the case. I better go buy some 10mm grade 8.8 bolts.
Thanks!
2006 Honda 599 sold
1999 Honda CR 250
Bowwow is offline
post #20 of 26 Old 08-15-2012, 01:59 PM
Hey, it can be worse.
Like when I put 1-4/20 Grade 8 allen head capscrews in the cam towers of my 73 CB750 after camming and springing it.
Then being oblivious to the retaining strength of the case aluminum head and instead using the ideal torque value for the fastener alone.
Getting the picture of the end result ?
Let's just say that this affair ended with me learning about how to install Heli-Coils. I still have the original install kit in the garage, and giggle every time I see it. Ah yes, wistful memories of painful lessons.
post #21 of 26 Old 08-21-2012, 11:29 AM
Short rod?
I just put on the Motovation sliders on also. Did you have any problems putting on the washers and nuts? According to the instructions, the rod is supposed to be 47cm, but it's actually 46. Just short enough so that the 2 washers didn't fit and the rod's threading didn't go all the way through one nut. I think if it had been 47cm, it would have fit perfectly. Anyway, it's jerry-rigged with some red loctite.
I called Motovation, and they said that it was re-speced to be 46, and that I am the only one that called with a problem.
No one else had problems?
2003 919
Yoshimura TRS
Power Commander
Renthal UL
Tower is offline
post #22 of 26 Old 08-22-2012, 06:44 PM
I had the same problem.
RalphLong is offline
post #23 of 26 Old 08-23-2012, 10:17 AM
I only mention it because you should let them know. I figure if enough people let them know, they'll reorder the rod at 47cm. Maybe then, they'll send me a new rod?
Cuz, you know, squeaky wheel gets the grease.
2003 919
Yoshimura TRS
Power Commander
Renthal UL
Tower is offline
post #24 of 26 Old 08-23-2012, 04:47 PM
Satos Satos Satos
But not mounted to the engine block frame mounting tab.
Instead, with grade 8.8 8 mm allen head capscrews threaded into the frame holes one must open up and then tap.
So easy, so neat, so much lighter.
post #25 of 26 Old 08-28-2012, 12:53 PM
Satos Satos Satos
I already put on the motovations, but are you saying that all you did was tap the 8mm holes in the frame, and then screwed in the Satos?
2003 919
Yoshimura TRS
Power Commander
Renthal UL
Tower is offline
post #26 of 26 Old 10-11-2012, 02:09 AM
abadacus's Avatar
BUMP
I am wanting to know this too!
abadacus is offline
