crashed 919! need some parts! - Wrist Twisters
post #1 of 14 Old 04-06-2014, 02:25 PM Thread Starter
shumayskates's Avatar
Need:
rear brake lever, rear bracket, rear passenger foot peg, right bar end and info how to fix this...
Thanks!
shumayskates is offline
post #2 of 14 Old 04-06-2014, 04:10 PM
Ouch! Are you OK? What happened?
post #3 of 14 Old 04-06-2014, 04:16 PM
Sorry about your get-off. Hope you are OK. The rear brake lever can probably be bent back in shape.
post #4 of 14 Old 04-06-2014, 04:46 PM
Hope you're ok - for not having frame sliders you are VERY lucky in your outcome, should be an easy fix, except the custom paint job is going to cost you more to fix that tail (rather than just buying a new one).
post #5 of 14 Old 04-06-2014, 05:38 PM
kkeigan's Avatar
I got a rear peg you can have. Cover shipping it's yours. I'd agree that the brake lever can be bent back with a little heat and some time.
Parts Ninja
kkeigan is offline
post #6 of 14 Old 04-06-2014, 05:56 PM Thread Starter
A lady was doing a u turn and I thought she was going straight and I was passing her on the left.. got banged up but no broken bones.
post #7 of 14 Old 04-06-2014, 06:17 PM
kkeigan's Avatar
http://bit.ly/1hjAiRS
eBay has a set of the peg "wing" mounts for $86 obo. You sell the spare on here and get some money back.
Parts Ninja
kkeigan is offline
post #8 of 14 Old 04-06-2014, 06:20 PM Thread Starter
Pm sent for the peg. I checked you can get a new bracket for 50 new on one parts websites
post #9 of 14 Old 04-06-2014, 10:20 PM
Delraco's Avatar
bummer man, glad you're okay!
I'm in a similar boat and am still piecing my baby back together.
-for the bent passenger "wing" those things bend easily. I used a large crescent wrench wrapped in a rag in a few strategic spots to pull mine back to straight. Worked like a charm.
-for the crack in the cowl, look into using plastic weld. It's similar in use to an epoxy syringe applicator.
Fixed my licence plate bracket perfectly - just follow the directions.
BTW, that paint job is flippin' gorgeous! Love the color
Delraco is offline
post #10 of 14 Old 04-06-2014, 11:08 PM Thread Starter
Thanks, i bent back the brake pedal, and tried bending the rear set bracket no luck right now, maybe ill try again soon. Is plastic weld hard to do?
post #11 of 14 Old 04-07-2014, 12:08 AM
Delraco's Avatar
Not at all, but the crack will still be visible. Repainting will be necessary for the best fit and finish.
Plastic weld is exactly like using epoxy. Just follow the directions closely
Delraco is offline
post #12 of 14 Old 04-10-2014, 10:32 PM
kkeigan's Avatar
Here's that peg. Sorry it took so long for me to post this. It's in pretty good shape.
Parts Ninja
kkeigan is offline
post #13 of 14 Old 04-11-2014, 12:16 AM
I've got a bar end, just the weight. A little lightly scuffed on the end but a little sanding and some satin black paint and it would look new.
$5 shipping and it's yours. PM if you want it.
post #14 of 14 Old 04-11-2014, 11:48 PM
kkeigan's Avatar
Peg sent.
Parts Ninja
kkeigan is offline
