Anybody have 900 headers? - Wrist Twisters
post #1 of 6 Old 05-07-2014, 09:55 PM Thread Starter
Austin919er's Avatar
Considering the low mount option if I can find headers at a decent price. Also, can someone tell me the diameter of what the headers pipe should be right before the down pipe? Thanks
Austin919er is offline
post #2 of 6 Old 05-08-2014, 06:06 AM
Honda919Rider #1
Any of the 1992-1998 (Don't hold me to that) CBR900RR headers, stock or aftermarket, can be made to work pretty easily.
The pipe flange diameter (where it fits into the head) is 41.25mm I believe - You would also need to take into consideration the flange bolt and tube spacing.
The actual header pipe is only around 35mm - probably contributes to the torque of 919.....
Hope this helps
Steve is offline
post #3 of 6 Old 05-08-2014, 01:21 PM Thread Starter
Thanks for the info. Steve.
post #4 of 6 Old 05-08-2014, 05:37 PM
Honda919Rider #1
Anytime, my pleasure!
I was in Houston this week - left before the storms rolled in. Almost made the trip to Austin - very nice place to be.
Good luck and any questions, someone here should be able to help.
Steve is offline
post #5 of 6 Old 05-08-2014, 07:20 PM
CG
catonsvilleguy's Avatar
I could be mistaken but I believe there were 2 versions of the oem 900rr headers. I think the later ones fit the 919 and the early ones don't due to interference with something. I'm not sure what year they switched.
catonsvilleguy is offline
post #6 of 6 Old 05-09-2014, 05:03 AM
Honda919Rider #1
I had to cut a small frame bracket off to get the early header to fit.
It might of been for the center stand, with wheel stands, I did not care.
Good point, thanks for mentioning it.
https://www.wristtwisters.com/forums/...ion-31773.html
or
Danmoto Jisu Installed - Honda 599 Forum
Steve is offline
