Selling brand new led headlight $35 - Wrist Twisters
 1Likes
  • 1 Post By Islandboy
post #1 of 11 Old 08-19-2018, 06:10 PM Thread Starter
I bought a pair of these couple weeks ago and do not need this one. Bought pair off ebay for 65. Will sell for $35. Or will trade for bike parts.
File Type: jpg Capture+_2018-08-19-20-00-18-1_1534727238395.jpg (31.6 KB, 20 views)
Niner101 is offline
post #2 of 11 Old 08-19-2018, 06:21 PM
Interested, how did you mount it?
post #3 of 11 Old 08-19-2018, 09:31 PM
I mounted a similar led headlight in the stock bucket using a cb400 retainer ring/rim assembly. Had to drill a hole on top and slightly shift side screw mount holes. I fiberglassed parts of my stock bucket and filled original mount holes. Then redrilled new holes. The fiberglass also reinforced those areas of the bucket.
Be sure you are getting the "good" version of this light. There is a shitty copy of this light out there. The shitty copy is shitty. The running lights will not remain on when low or high beam is on. There are some clues. Shitty copy has only 9 leds in each of the running lights. Good one has 12. The good copy has a compression fitting sealing the cable loom on the rear of unit, see pic. Shitty copy cable just runs through a rubber plug. Good unit has more venting on rear and a better seal on lens cover.
These light units have three keys on the rear that the cb400 retainer ring clamps. I also moved some of my stock wiring loom out of the headlight bucket and into the void left behind from the pair valve removal. That gap in the frame near steering head. I covered the wiring with those rubber pads that clip in there. Be real careful when drilling those three mount holes. Try the unit in there first and have a good look it's all square. Mine ended up a couple of degrees out. No one else has noticed it just me but I think it sux. These lights are about 60w and bright as f..... I got a pair deal as well and just keep the other for a spare. I like em. Running it for about a year now, no worries.
Jamesbuck likes this.
post #4 of 11 Old 08-20-2018, 08:28 AM Thread Starter
SAME AS HE SAID
I FOLLOWED ISLANDS DIRECTIONS AND WENT BY THIS https://www.wristtwisters.com/forums...ion-58378.html I GOT THE HEADLIGHT RIM FROM DIMECITY CYCLES CAUSE 2WHEEL WAS OUT OF STOCK VERY EASY MOD TO DO...
Niner101 is offline
post #5 of 11 Old 08-22-2018, 02:24 PM
How is the light/brightness/field of view compared to the old one?
derek0177 is offline
post #6 of 11 Old 08-22-2018, 02:38 PM Thread Starter
Much better than stock to me. Every1 might have something different to say, but I won't go back.
Niner101 is offline
post #7 of 11 Old 08-22-2018, 02:40 PM Thread Starter
I won't go back to stock headlight and plus mostly everything is black on my bike so it really looks cool. Just my opinion.
Niner101 is offline
post #8 of 11 Old 08-22-2018, 03:07 PM
The light is great. Very bright. Low beam has a good cutoff and high beam pattern is more concentrated and very bright. See pic. Low beam on left, high on right. Also has running lights for extra visibility during day. I'll never go back to stock again. IMO it also looks cool!
post #9 of 11 Old 08-23-2018, 11:28 AM Thread Starter
THANK YOU ISLAND BOY , LOL IM BUSY AT WORK
Niner101 is offline
post #10 of 11 Old 08-23-2018, 01:51 PM
Diablo's Avatar
Whats with all the caps.
Diablo is offline
post #11 of 11 Old 08-24-2018, 08:29 AM Thread Starter
sorry where i work keyboard is on caps all the time so if i rush to reply i just roll with it.....
Niner101 is offline
