KOSO RX2N - Wrist Twisters
 3Likes
  • 2 Post By bartsitarski
  • 1 Post By bartsitarski
post #1 of 8 Old 06-02-2017, 03:03 PM Thread Starter
The Instigator
Ditch's Avatar
KOSO RX2N
Got an unused, never installed Koso. I was troubleshooting a different one I actually installed and feared mine was defective which ended up not being the case so my loss it your gain.
Only thing different from a new one is the speedo wire was cut during the troubleshooting process but if you are soldering your connections it shouldn't be a big deal for you. It also has 2 miles on it but the factory protective thingy is still on the gauge.
Asking $200 plus a few bucks for shipping depending on where you live.
All yer Koso info is here:
Koso RX2N Finally installed.... - Wrist Twisters
2007 919
2003 CBR1100XX
Ditch is offline
post #2 of 8 Old 06-02-2017, 05:33 PM
bartsitarski's Avatar
If it was in the budget, I would be all over this. Unfortunately a deck is the expense of the summer.
-Michael Jordan
bartsitarski is offline
post #3 of 8 Old 06-11-2017, 09:25 PM Thread Starter
The Instigator
Ditch's Avatar
Wow, tough sell. $150 takes it.
2007 919
2003 CBR1100XX
Ditch is offline
post #4 of 8 Old 06-16-2017, 02:35 PM
Moto-Doc
Nealio919's Avatar
I may be interested... Seems like a lot of work but I totally dig the end result.
2006 Honda 919 TURBO
2014 Honda CB1000R
2005 Ducati Monster S4R
2000 Honda 750 Nighthawk -Sold
1997 Suzuki DS350SE -Sold
2002 Honda 750 Shadow ACE -Sold
2006 Kawasaki ZX-6R -Sold
2003 Honda CBR954RR (Drag Bike) -Sold
2002 Honda CBR954RR -Sold
1992 Honda 750 Nighthawk -Sold
1972 Honda CB350 -Sold
Nealio919 is offline
post #5 of 8 Old 07-07-2017, 01:38 PM
KGB
KGB's Avatar
Ditch, pm'd you.
KGB is offline
post #6 of 8 Old 07-13-2017, 07:10 PM
Got it all wired up my man. Thank you for making the deal.
ewmin3m and CB 919 like this.
-Michael Jordan
post #7 of 8 Old 07-13-2017, 07:13 PM
KGB
KGB's Avatar
Bart, how was the install? I plan on getting the other one lol. Did you wire to the stock subharness?
KGB is offline
post #8 of 8 Old 07-14-2017, 09:16 AM
It was not too bad. My bike is an 03, so it uses the old harness. The "hardest" part is getting mounted cleanly because the gauge no longer uses the mounts on the headlight ears. I ended up cutting and bending some steel strips in the stock location on the triple and it worked out well. Specific to wiring, here is a modified list that I posted on the big Koso thread with wiring directions. Just make sure that you solder and use shrink tubing.
This was copied from arctic954 wiring a KOSO RX2N gauge to his 919, the title of the thread was "Koso RX2N Finally installed" and a modification was added from the thread titled “Gauge cluster Wiring Digram for 2007 919” to add 12v constant from the harness and 12v switched from the harness. After a couple hours of digging, I found the nugget of goodness that allowed constant and switched to come off the harness and I wanted to have one central place with wiring info.
By following this wiring guide, I was able to get Neutral, turn indicators, high beam, oil, CEL, and temp to work on my 2003 using all harness connections, making the unit plug and play with my 2003. I am using the Koso speed sensor. Contributors, among many, are arctic954, bpolunin, ganktor.
Hope this helps, use at your own risk, I am not responsible for any damage
KOSO--------------------------------- OEM Harness
White (right turn signal) --------------Lt Blue
Brown (RPM wire)--------------------- Yellow/Green Stripe
RED (Main Positive Power)------------ Red/Green Stripe
Black (ground) ------------------------ Green (this wire goes to Rob's LED fuel harness)
Brown (keyed Ignition, 12v +)-------- Brown/Black Stripe(2002-2003) White/Green Stripe (2004+)
Lt Grey (left turn signal) ------------- Orange
Orange (oil light) --------------------- Blue/Red Stripe
Purple or Violet (FI light) ------------ White/Blue Stripe
Yellow (high beam indicator)---------Dark Blue/Black Stripe
Blue (neutral light)--------------------Light Green/Red Stripe
Green (fuel gauge indicator)----------No Connection, use Rob’s light.
CB 919 likes this.
-Michael Jordan
