HONDA CENTERSTAND - Wrist Twisters
 2Likes
  • 1 Post By mcromo44
  • 1 Post By K1w1Boy
post #1 of 21 Old 11-28-2018, 08:37 AM Thread Starter
HONDA CENTERSTAND
Good condition, includes all hardware needed.
$130 shipped to cont US.
PAULIBIKER is offline
post #2 of 21 Old 11-28-2018, 08:39 PM
The Instigator
Ditch's Avatar
These make rear shock removal a 5 minute job.
2007 919
2003 CBR1100XX
Ditch is offline
post #3 of 21 Old 11-29-2018, 03:31 AM
This was one of the best things I've brought for my bike.
I did the mod which makes it quick to take off or put on.
post #4 of 21 Old 11-29-2018, 06:31 PM
Hello Paul:
Sent you a PM.
Bought your windscreen last month - now interested in your centerstand.
--Roger--
MyCB919 is offline
post #5 of 21 Old 11-30-2018, 08:39 AM
jack
old fart's Avatar
stand & manual
Paul pay pal sent
old fart is offline
post #6 of 21 Old 11-30-2018, 09:15 AM Thread Starter
SOLD...............
post #7 of 21 Old 01-10-2019, 11:18 AM
WERA481
Is the center stand a Honda part?
Anyone know a part number?
jkraft is offline
post #8 of 21 Old 01-10-2019, 07:06 PM
The stand depicted is a bonafide Honda OEM part.
I can't find the paperwork for mine, otherwise I'd give you the P/N.
jkraft likes this.
post #9 of 21 Old 07-21-2019, 10:23 PM
08M50-MCZ-100
But they are apparently no longer available, that's why I'm here, I need one.
Anyone want of get rid of one or know where to get one?
oddtodd is offline
post #10 of 21 Old 07-22-2019, 09:07 AM
Originally Posted by oddtodd View Post
08M50-MCZ-100
Suggest you also check out the current availability of the SW-MOTECH centre stand for the 919.
As for the OEM item, did you check at a bricks and mortar Honda dealer, as compared to web on line sellers?
post #11 of 21 Old 07-22-2019, 11:26 AM
Didn't someone just post an aftermarket one for sale about a month ago?
I bring this up because on a classic mustang forum, someone posted a .PDF drawing of the parts needed to make adjustable perches for a classic mustang. Basically, you print out the .PDF drawing, trace the lines onto steel and weld it together and you have the part. These parts cost some $250 of you buy them or dirt cheap if you cut the steel and weld it yourself.
Why can't we do the same thing with that center stand that doesn't bolt onto the bike?
https://www.wristtwisters.com/forums...een-80833.html
Doesn't look that hard or expensive to make, just need some specs... Anyone have one that can take some measurements? Or maybe they come ready made for cheap?
Seems a great option to have a center stand that isn't bolted on all the time.
post #12 of 21 Old 07-22-2019, 02:45 PM
I'll try SW-Motech again, I think I looked at their website but it had problems of some sort so I gave up.
Haven't tried brick/mortar, but the dealers here in central Arkansas are not that big. There is one in Russellville (about an hour and a half away) that does pretty good sales wise so I might try them if I get out that way.
Thanks for the suggestions.
"I have plenty of common sense, I just choose to ignore it." - Calvin
oddtodd is offline
post #13 of 21 Old 07-22-2019, 02:49 PM
https://www.wristtwisters.com/forums/f86/ti-satos-p-stand-motivation-sliders-mra-windscreen-80833.html
This is what I was coming arouind to thinking, I've got access to welding equipment so would just need to spec it out.
oddtodd is offline
post #14 of 21 Old 07-22-2019, 03:55 PM
Good luck with it all.
As for SW-Motech, being European, there might be better success via a major NorAm webseller that carries their numerous products.
post #15 of 21 Old 07-22-2019, 04:41 PM
This thread has all the OEM stand measurements.
A service stand would be no trouble to make.
OEM centre stand pics and measurements. https://www.wristtwisters.com/forums...ad.php?t=79274
post #16 of 21 Old 07-22-2019, 05:35 PM
Yes, I've got one that I'll measure up in a few hours when I get home - it uses the centrestand pivots and a large pin that slides into place - still worked after my lo-pipe conversion, too, but my bike has got too tall for it now, with longer shock and forks.
K1w1Boy is online now
post #17 of 21 Old 07-22-2019, 08:23 PM
The pics should tell you everything about it..but if not, ask away.
It's 25mm box section, 2.5mm wall. The tabs on the ends [40mm x 50mm] are where your feet push down to rock the bike up, just like a centrestand.
The pin is about 250mm o/all, 235 excluding hex head, 15mm dia.
Islandboy likes this.
post #18 of 21 Old 07-22-2019, 08:53 PM
I read about this in another thread awhile back IIRC, but never saw it until now.
Perfect, excellent, ad infinitem (did I use that correctly? IDK Latin)
Gives me a reason to go visit ma this weekend as well, many thanks, Islandboy!
oddtodd is offline
post #19 of 21 Old 07-22-2019, 11:14 PM
No worries oddtodd.
If you feel inclined post some pics of what you come up with.
post #20 of 21 Old 07-22-2019, 11:15 PM
Perfect.
post #21 of 21 Old 07-23-2019, 02:01 PM
...and I've just remembered a measuring / levelling app on my phone, so can tell you that the uprights on this one are 12 degrees from vertical.
