WTB- Chain Adjustor assembly - Wrist Twisters
post #1 of 13 Old 02-22-2012, 04:12 PM Thread Starter
Hastatus Prior
TheBeeDeeGee's Avatar
Looking for both left and ride side, Really I only need the two adjustor bolts for my 2002. Mine seized up somehow and I've mangled them trying to get them loose. Please help kind sir's.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #2 of 13 Old 02-22-2012, 05:08 PM
Love my BIG BOY Toys!
BBB2's Avatar
Honda 919 Hornet CB900F ADJUSTER, CHAIN. 40543-MAS-000. NEW. M2 | eBay
1999 Honda Valkyrie Interstate
2011 Kawasaki Vulcan Vaquero*
2004 Honda 919 *
2002 Honda VTX 1800C*
* SOLD *
BBB2 is offline
post #3 of 13 Old 02-22-2012, 05:44 PM
I have a set somewhere? Let me take a look....
post #4 of 13 Old 02-22-2012, 05:46 PM Thread Starter
Hastatus Prior
I can't tell if that one has the screw or not, which is really what i need
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #5 of 13 Old 02-22-2012, 06:07 PM
According to the microfiche, the chain adjuster bolt is a separate part. At my dealer it's $6.25
post #6 of 13 Old 02-22-2012, 06:11 PM
Did you mess up the threads or just the head of the bolt? If it's the threads I would be more worried about the aluminum swingarm.
If its just the 8mm head of the bolt. You could weld a 10mm bolt head or wing nut onto it or ...... clean it up and cut a slot into it for a common screwdriver.
post #7 of 13 Old 02-22-2012, 06:28 PM Thread Starter
Hastatus Prior
I'm hoping it's not the threads, those fuckers won't move at all though. I don't know how they got seized up.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #8 of 13 Old 02-22-2012, 06:31 PM
take out the axle, spray some wd40 and let it soak a bit, spray more on and try to work them loose. Its possible they might be bent, preventing you from backing them out more.
post #9 of 13 Old 02-22-2012, 06:36 PM
Obvious question but......you have loosened the axle nut correct?
Tty some heat, MAP works wonders for a small.portable torch. Dont be shy with it cook the hell out of em.
post #10 of 13 Old 02-22-2012, 06:40 PM Thread Starter
Hastatus Prior
Yeah I loosened it, I actually posted about this in another thread I started. But since I'm dumb I didn't realize I could just buy a bolt from a hardware store I was thinking it was a special part.
But it looks like I can get the same assembly for around 12 bucks, hopefully I won't need it though. I just wish I could figure out how this happened.
Thanks for the advice guys.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #11 of 13 Old 02-22-2012, 06:55 PM
Missed the other thread, just covering the basics wasn't trying to insult.
Maybe the PO cranked on the bolts without loosening the axle. It could bind up the threads in the soft alloy swing arm pretty easy.
post #12 of 13 Old 02-22-2012, 07:00 PM
Some good advice in this thread, Apparently you aren't the first.
https://www.wristtwisters.com/forums/...ght-24658.html
post #13 of 13 Old 02-22-2012, 07:24 PM Thread Starter
Hastatus Prior
God dammit, I hope that's not what happened.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
