WTB Aftermarket Shock - Wrist Twisters
post #1 of 18 Old 06-02-2012, 09:53 AM Thread Starter
Woodward Ave
Bryan's Avatar
Looking for a good aftermarket rear shock that will fit the 919 new or used.
Bryan is offline
post #2 of 18 Old 06-02-2012, 10:41 AM
Contact LDH for an Ohlins. You won't regret it!
post #3 of 18 Old 06-02-2012, 11:56 AM Thread Starter
Woodward Ave
Bryan's Avatar
I hear great things about the ohlins. Are they worth the thousand dollar investment? I see some less expensive alternatives on ebay coming out of Australia. I have an 03, so no adjustment.
Bryan is offline
post #4 of 18 Old 06-02-2012, 12:47 PM
Lack of adjustment has zero to do with the crappiness of the OEM units.
The dampers are just as bad in early no adjuster and later adjuster forms.
At the least the early ones came with a spring rate, unlike the later ones that came with a mush rate better suited for a pixie on a bike weighting 200 # less.
post #5 of 18 Old 06-02-2012, 01:13 PM Thread Starter
Woodward Ave
Bryan's Avatar
I don't completely hate the oem shock.. It takes corners okay considering my 200 lb frame. My big problem is with the way it takes bumps and dips in the road.. Can I have the oem shock rebuilt with a spring that fits my weight better?
Bryan is offline
post #6 of 18 Old 06-02-2012, 01:22 PM
for that kind of money/work, you'd be better off ditching the OEM shock and picking up a progressives unit. however they are not available anymore so you only choices really are the penske or ohlins. You're better off ditching the OEM shock no matter what you do. In other words, rebuilding the OEM shock is not a viable goal since it is simply just complete trash due to the valving, internals, and what not.
If you want a great breakdown on the OEM unit and why its not worth rebuilding it, contact LDH as he's VERY knowledgeable on the topic and will tell how things are.
another good source is mcromo. he's tracked his bike enough that he became the test pig for Penske to build a rear shock unit specifically for the 919.
post #7 of 18 Old 06-02-2012, 01:47 PM Thread Starter
Woodward Ave
Bryan's Avatar
I have a Penske distributor close by in Brooklyn, MI
Bryan is offline
post #8 of 18 Old 06-02-2012, 05:46 PM
One of our Aussie/Kiwi members had good things to say about these Hagon shocks: Hagon mono-shock Honda CB900F Hornet (SC48) from 2001 to 2006 fully re-buildable | eBay
Is it AllanB?
post #9 of 18 Old 06-02-2012, 06:53 PM
No, I'm pretty sure that Allan had the local Ohlins guy build him something...
Do you have YSS shocks in the US? Lacking the budget to go the O route, I found something to work for me, after I fitted a better rate of spring...
K1w1Boy is online now
post #10 of 18 Old 06-02-2012, 09:42 PM
I have a progressives 420 shock.... i'd sell it for oh say.... $500? lol.
post #11 of 18 Old 06-02-2012, 09:50 PM
Aren't 420 shocks slow to react?
post #12 of 18 Old 06-03-2012, 12:13 AM
Originally Posted by K1w1Boy View Post
No, I'm pretty sure that Allan had the local Ohlins guy build him something......
Correct! Just posted in another rear shock thread about it as there is a USA member who has ordered one from Sweden.
post #13 of 18 Old 06-03-2012, 04:55 AM
Lol.....they are slow and constantly have the munchies.
post #14 of 18 Old 06-03-2012, 07:35 AM Thread Starter
Woodward Ave
Bryan's Avatar
I emailed Penske about the 8900E. For my riding style/capabilities on this bike, I think that shock is a good fit.
Bryan is offline
post #15 of 18 Old 06-03-2012, 07:57 AM
You can't go wrong, but be real careful on the spring rate - make sure it is stiff enough.
They make a good unit and the adjustable length is a really good feature.
I'd buy Penske again.
post #16 of 18 Old 06-03-2012, 08:32 AM Thread Starter
Woodward Ave
Bryan's Avatar
How similar is the Ohlins HO322 compared to the Penske 8900E?
Bryan is offline
post #17 of 18 Old 06-03-2012, 08:50 AM
This is a very good question.
One thing I have always wondered about and simply do not know, is what the low speed compression damping force curve is like for the Ohlins.
I've wondered if it is noticeably different and better than the Penkse.
I've never been able to find the Ohlins curve to do a compare.
Both are good units.
Low speed compression is an issue on the 919 because of the unlinked swing arm.
919s are squat meisters.
This is really only an issue under hard riding, in particular track days.
For the typical 919 rider, you simply can not go wrong with the Ohlins, and there is more support for it than there is the Penske.
I say that as a pro Penkse guy. (pro as compared to con, not professional)
post #18 of 18 Old 06-23-2012, 12:31 PM Thread Starter
Woodward Ave
Bryan's Avatar
Bryan is offline
