WTB: 919 FRame sliders - Wrist Twisters
post #1 of 14 Old 05-28-2009, 12:30 PM Thread Starter
Guzzi Man
Not the ones I need to drill the front subframe out to install!
mikestib1 is offline
post #2 of 14 Old 05-28-2009, 03:46 PM
I have a set with bolts and threaded rod if you want them.
ilovheros is offline
post #3 of 14 Old 05-28-2009, 05:11 PM
The drilling is really no big deal. I only had to enlarge the hole a bit at each end and didn't have to drill all the way thru.
post #4 of 14 Old 05-29-2009, 12:27 PM Thread Starter
Guzzi Man
Why are you turning them loose?
Thanks for the offer!
post #5 of 14 Old 05-29-2009, 12:29 PM Thread Starter
Guzzi Man
I heard the motovation ones can be a real pain to install somewhere in the forum.Maybe each bike is different?
post #6 of 14 Old 05-29-2009, 06:00 PM
I ordered them a while ago to make my own go throu the frame type (threaded rod) but decided to order GSG type because of the better double bolt mount.
post #7 of 14 Old 05-30-2009, 06:49 AM Thread Starter
Guzzi Man
Who is the manufacturer and how much do you want for them?
Thanks
post #8 of 14 Old 05-30-2009, 07:04 AM
Hey Mike, I have two 9ers, both with the non-drill sliders. No problems. The one I have dropped and skidded at low and high speed. They work!
post #9 of 14 Old 05-30-2009, 08:56 AM
Tirone shoelaces
TexasTraffic's Avatar
This.
Drilling is easy, unless you find a hard spot in the weld like I did.
Still, it is more annoying than difficult - drilling then takes 20 minutes vs. the normal 3 minutes.
Your other option is to mount the sliders to the engine case, and that will most likely get VERY expensive the first time you use the sliders (ie. a cracked engine case).
TexasTraffic is offline
post #10 of 14 Old 05-30-2009, 09:13 AM
Originally Posted by TexasTraffic View Post
This.
+1. If you have the right bit, drilling is not hard. One side of mine did take a lot longer than the other though, must have had a spot in the weld as TT mentioned.
post #11 of 14 Old 05-30-2009, 09:18 AM Thread Starter
Guzzi Man
Appreciate the feedback, but quit going down, will ya!
post #12 of 14 Old 05-30-2009, 03:05 PM Thread Starter
Guzzi Man
Guess I'll bite the bullet and get some GSG sliders from streetfighterinc for a buck eighty
Thanks for the info!
post #13 of 14 Old 05-30-2009, 04:11 PM
Good call!
post #14 of 14 Old 05-31-2009, 02:43 PM Thread Starter
Guzzi Man
Thanks again for the tip!
