Stock bar end - Wrist Twisters
post #1 of 12 Old 06-07-2012, 02:03 AM Thread Starter
Dewbie
bacis's Avatar
Stock bar end
My 919 came with a missing bar end on the left side. Anybody have one hanging around that I can buy for cheap? Thanks!
bacis is offline
post #2 of 12 Old 06-07-2012, 07:20 AM
You looking for just the end or do you need the insert too?
I have a pair of ends with inserts.
PAULIBIKER is offline
post #3 of 12 Old 06-07-2012, 11:00 AM
StormSurfer
Whiplash97's Avatar
I have some black ones from my Drz
:buell:
Whiplash97 is offline
post #4 of 12 Old 06-07-2012, 12:38 PM Thread Starter
Dewbie
bacis's Avatar
My ignorance is going to show here because I don't know exactly what that means. The brake side has a hard black end past the grip while the clutch side ends at the grip (leaving the end a tad squishy), with a threaded hole inside. Not sure what the 'inserts' are.
bacis is offline
post #5 of 12 Old 06-07-2012, 12:47 PM
StormSurfer
Whiplash97's Avatar
Inserts= made of expandable rubber or aluminum with a bolt or screw through it, when said bolt/screw is tightened insert expands and fits tightly inside the end of the bar
:buell:
post #6 of 12 Old 06-07-2012, 01:57 PM
That's for most aftermarket bar end weights/inserts.
However, Bacis has the stock barend weights/inserts. Bacis, the stock system comprises of a 2 piece weight system. The black outermost end is the actual barend weight itself. the insert piece is a long metal rod that is held in place inside of the bar via 2 metal clips and is what the outer barend weight screws into.
From what it sounds like, you have the stock insert, you just need the outer barend weight. If paulbiker doesn't want to split his barends/inserts, I have some stock barend weights I'll give ya. Just let us know.
post #7 of 12 Old 06-07-2012, 02:45 PM
StormSurfer
Whiplash97's Avatar
Ohhhhh...so my DRZ stuff isn't good enough?(joking)
:buell:
post #8 of 12 Old 06-07-2012, 02:49 PM
Hey, PVster, if you don't get rid of those bar ends, hold on to them for a while - I need to borrow a set to replace my mirrors for our track day in August, lol...
post #9 of 12 Old 06-07-2012, 03:07 PM
StormSurfer
Whiplash97's Avatar
Once again! I can't give these things away, maybe I can use for fishing weights
:buell:
post #10 of 12 Old 06-07-2012, 03:26 PM
Nineophile Retired
radicalwillie's Avatar
Maybe this schematic will help describe which part you need.... 2004 Honda 919 - CB919F OEM Handlebar + Top Bridge Parts | MotoSport
radicalwillie is offline
post #11 of 12 Old 06-08-2012, 12:04 AM
I'll trade you! Question is, will you get em back?
post #12 of 12 Old 06-08-2012, 12:24 AM Thread Starter
Dewbie
bacis's Avatar
Yeah, looks like I just need the weight/end, not the insert too. I'd love to grab yours Pvster if you're willing to give it/them up.
Thanks everyone for helping me out.
bacis is offline
