***SOLD*** Rizoma zero 11 indicators & custom led relay $100 - Wrist Twisters
post #1 of 8 Old 07-23-2012, 04:35 AM Thread Starter
Yup, the whole set. 4 blinkers plus the relay, which is plug and play. This way you don't have to wire a resistor inline on each indicator.
One indicator has a hairline crack in the back, but it's been that way for a long time and hasn't gotten worse. I put it on the back where it was hard to see. You could glue it if you felt it needed it.
Of course the wires are cut, but there is no sense in me resoldering them back together, the wire connectors don't fit through the front frame mounting holes anyway. You will need to fit these up and then solder or crimp your connections.
These are bright! They also don't natively work as running lights like stock indicators do, but some here have wired their lights up to do that, just need the right equipment.
FYI, I spent about $35 a PIECE on these blinkers. The relay is about $20.
post #2 of 8 Old 07-23-2012, 12:37 PM
Great deal, and the best LED lights out there other than the older Watsen style LEDs. Whoever buys them won't be disappointed!
post #3 of 8 Old 07-23-2012, 12:51 PM
So Watsen's are better than these?
post #4 of 8 Old 07-23-2012, 12:53 PM Thread Starter
Question is, what kind of oil is best to use in the bike that HAS these...
post #5 of 8 Old 07-23-2012, 02:35 PM
Depends on what generation Watsens they are
Oil? Screw oil, blinker fluid is where its at!
post #6 of 8 Old 07-23-2012, 03:17 PM
bloodtricution
bloodtricution's Avatar
dibs. PM Sent
bloodtricution is offline
post #7 of 8 Old 07-23-2012, 03:20 PM Thread Starter
Originally Posted by bloodtricution View Post
dibs. PM Sent
Replied. Pending sold.
post #8 of 8 Old 07-24-2012, 10:31 AM Thread Starter
SOLD
