**SOLD**Renthal Fatbar conversion kit (bars + risers) - Wrist Twisters
post #1 of 11 Old 07-16-2014, 07:50 AM Thread Starter
Renthal CR high fatbars gently used NOT drilled & Pro Taper 7/8 to 1 1/8 bar risers. These allow you to install 1 1/8th handlebars on your 9er & give you a 3/4" rise as well. Everything is in mint condition.
Originally paid:
CR high Fatbar -$70
Pro Taper risers -$40
Total $110
Yours for $70 + SHIPPING.
Paypal friends & family payment appreciated.
arshishb is offline
post #2 of 11 Old 07-17-2014, 10:00 AM
If you don't get any takers on the complete set I would be interested in just the bars. I'm in no hurry so see if you can sell as a set first
post #3 of 11 Old 07-17-2014, 10:56 AM Thread Starter
Sure thing man, will let you know.
arshishb is offline
post #4 of 11 Old 07-17-2014, 01:36 PM
Lido's Avatar
I'm interested. Does this setup use original cables? Does it offer a bit more of a straight up riding position by straight up I mean not as leaned over. Regards lido.
Lido is offline
post #5 of 11 Old 07-17-2014, 02:55 PM Thread Starter
The risers give a 3/4" rise but the bars themselves are shorter than stock so you essentially end up with almost the same height.
However, the bars are wide & have a small pull back compared to stock which has a very steep pull back which puts your wrists on an awkward angle.
This setup will work stock cables & brake lines no problems. You will need to reroute the clutch cable from your headlight stay which takes 5 mins.
Here is a copy paste from the spreadsheet I made a while back comparing the stock bars to the different Renthal bars.
arshishb is offline
post #6 of 11 Old 07-17-2014, 03:05 PM
The Fatbar should help with vibes too.........
GLWS
PAULIBIKER is offline
post #7 of 11 Old 07-29-2014, 11:54 AM Thread Starter
Fatbars SOLD & shipped.
Pro Taper clamps / adapters still available.
arshishb is offline
post #8 of 11 Old 07-31-2014, 04:12 AM
Tool & Die
morrow919's Avatar
I'm interested in the risers. I'll shoot you a PM.
'07 Hornet - Candy Glory Red
morrow919 is offline
post #9 of 11 Old 07-31-2014, 04:52 AM
Tool & Die
morrow919's Avatar
Also, just to clarify, the CR High Fatbar is just 1 1/8" in the clamp area and still 7/8" at the bar ends correct?
post #10 of 11 Old 07-31-2014, 07:11 AM Thread Starter
Correct. The mounting point of the handlebars are 1 1/8"; thats where the "Fat" region of the Fatbar is.
The control area of the handlebar is 7/8.
arshishb is offline
post #11 of 11 Old 08-02-2014, 12:14 AM Thread Starter
Everything SOLD. Mods, please close thread, thanks.
arshishb is offline
