***SOLD*** 06 forks and rear shock, OEM 02 handlebars and mirrors - Wrist Twisters
post #1 of 27 Old 08-21-2012, 02:56 PM Thread Starter
Hey guys, I decided that I don't need the forks and shock that I haggled in when I bought my 02 9er last month. I am light enough that I don't think I will need the pre load adjustments and whatnot. I also commute and don't really ride the track so I figured I would offer up the parts to my fellow WT members. I am not really sure what I should be asking for from the forks and shock, but I have a decent idea. I am open to all offers though.
2006 Honda 919 Forks and Rear Shock
Here's my craigslist post, I wasn't sure how to load nice pics on here, so I figured CL would do.
Thanks
Black919Rider is offline
post #2 of 27 Old 08-21-2012, 03:02 PM
If you are light, the '06 rear shock is better for you. The spring is much softer than the '02.
post #3 of 27 Old 08-21-2012, 03:27 PM
+1! Your CL add says you're 170 lbs., I would swap the shock, it'll be an improvement over the '02 shock. You should be OK with the forks.
post #4 of 27 Old 08-21-2012, 03:46 PM Thread Starter
do u guys have any idea what I should be asking for the forks?? I was told they were very expensive like 700-800 new from a motorcycle service guy but that seems a little high to me. I'd like to give someone on here a deal, but I'd like to walk away happy too. I have 4800 in tuition thats due next week it hurts to sacrifice parts, but I am always hurting for cash come tuition payment time.
post #5 of 27 Old 08-21-2012, 05:35 PM
04+ forks.... id say 250ish.
seriously, i know how money can be tight for a college kid (i am one) but put that 06 shock on at the very least.... and the 04 forks are a good step better than the 02s.
post #6 of 27 Old 08-21-2012, 06:04 PM
Install both the shock and forks and sell them when/if you sell the 919.
post #7 of 27 Old 08-21-2012, 06:47 PM
gpickles's Avatar
Are the forks adjustable too
gpickles is offline
post #8 of 27 Old 08-21-2012, 07:48 PM Thread Starter
yea, I believe the forks that were 04 and later all are adjustable (someone correct me if I am wrong) I just don't see where you can adjust them unlike the shock
post #9 of 27 Old 08-21-2012, 08:32 PM
the 04+ forks had rebound dampening adjustment (the flat head screw at the very top center of the fork) as well as preload (14mm wrench to screw in screw out the aluminum piece that surrounds the rebound dampening screw)
the 04+ forks DO NOT have compression adjustment.
02-03 had nothing as far as adjustment.
02-03 shock had a stiffer spring and ONLY preload adjustment
04+ shock has a softer spring and rebound adjustment.
post #10 of 27 Old 08-21-2012, 08:40 PM
04+ forks had preload (14mm wrench to screw in screw out the aluminum piece that surrounds the rebound dampening screw)
They are actually ride height adjusters which is not at all preload adjustment.
The installed height of the spring does not change, just the ride height.
One day the factories and magazine guys will start use the correct words, as in Ride Height instead of Preload where the adjuster is of the ride height type.
post #11 of 27 Old 08-25-2012, 04:48 PM
gpickles's Avatar
Did you sell shock and forks?
gpickles is offline
post #12 of 27 Old 08-29-2012, 10:42 PM Thread Starter
In the process of selling forks. Shock is still not sold, I am undecided about putting the shock on or not. if someone gave me a good price, i would be willing to part with it
post #13 of 27 Old 08-30-2012, 07:51 AM
gpickles's Avatar
What did you get for forks?
gpickles is offline
post #14 of 27 Old 08-30-2012, 10:12 AM Thread Starter
250 with ship
post #15 of 27 Old 09-20-2012, 03:58 PM
So the forks are gone? Looks like tankslapper/getoff may have bent the stanchion tube
post #16 of 27 Old 09-23-2012, 11:24 AM Thread Starter
The forks are pending, still have everything else.
post #17 of 27 Old 10-02-2012, 10:10 PM Thread Starter
forks are sold! 06' rear shock, mirrors, handlebar still up for sale!
post #18 of 27 Old 10-02-2012, 10:31 PM
Filipiniaviator is looking for stock bars
post #19 of 27 Old 10-02-2012, 10:50 PM
tucker_98's Avatar
Pm'd
tucker_98 is offline
post #20 of 27 Old 10-24-2012, 10:55 PM Thread Starter
Rear Shock still available. Looking to get $125 but open to offers.
post #21 of 27 Old 11-02-2012, 08:19 AM Thread Starter
bump - that 125 includes shipping
post #22 of 27 Old 11-06-2012, 12:33 PM
Are the handlebars still available. Stock and straight? Got a Picture?
will9 is offline
post #23 of 27 Old 11-07-2012, 10:21 AM
During this thread it is said the 06 shock is softer and better then the 02 for lightweight. I'm about 250, is it still an improvement to go for the 06 shock over the 02?
ScramblerX is offline
post #24 of 27 Old 11-07-2012, 10:20 PM
With your weight, no. If you want better, look into a penske or ohlins.
post #25 of 27 Old 11-08-2012, 10:25 AM
thanks for the info, what about for the front forks?
Is it worth going to the 04's or doing something else?
post #26 of 27 Old 11-08-2012, 03:24 PM
For the front forks with your weight, new springs for sure! If you want adjustability, you can go with the 04+. Typically for the price of the 04+ forks other than this forum, you can find f4i forks for the same price or less for even more adjustability.
post #27 of 27 Old 11-09-2012, 06:09 PM Thread Starter
*****EVERYTHING IS SOLD*****
