Rizoma Brake Lever - Wrist Twisters
post #1 of 6 Old 11-06-2011, 11:32 AM Thread Starter
Rizoma Brake Lever
Was flexing the 919's power out in the twisties yesterday and pulled up to a stopsign, went for the front and rear brakes.... only no rear brake. apparently the lever vibrated loose and fell off sometime while I romping around.
Basically just need the rear brake lever off a Rizoma rearset (they may be universal I think).
fritzwilliam is offline
post #2 of 6 Old 11-06-2011, 11:48 AM
least it wasnt the other way around!!!
how is the rear lever held on? typically theres the main pivot point and the master cylinder pivot where its held on... surprised both failed in the short amount of time it took to notice.
post #3 of 6 Old 11-06-2011, 12:10 PM Thread Starter
It's just a single screw that secures it to the pivot point.
I don't know how it happened so fast, I guess it was loose already, didn't feel loose though. I tried back tracking, but it was useless, I only use my rear brake when coming to stops and when emergency braking.
post #4 of 6 Old 11-06-2011, 01:47 PM
intresting, so the actual lever doesnt hook to the master cylinder? i see the spline so id assume its there for adjustability, if so that makes sense and that sucks cus thats probably a pretty pricey part!
post #5 of 6 Old 11-06-2011, 01:58 PM Thread Starter
Yeah, they run about $80-95, the real problem is trying to find someone with spares though. The parts take forever to come over from Italy. At any rate, this won't happen again, going to locktite every last bolt that even has the remote possibility of coming loose in the future.
post #6 of 6 Old 11-06-2011, 03:38 PM
undercover919's Avatar
So everything?
2003 Honda 919
undercover919 is offline
