Rear brake light switch - Wrist Twisters
post #1 of 22 Old 04-26-2011, 03:52 PM Thread Starter
FYTER
Need a rear brake light switch for my 919.
There are some on fleabay, but everyone is insane on shipping - the cheapest offer I got for $14.50 just for the shipping!!! It's $5 lousy bucks to send an envelope to Canada, for Christ's sake!
So, help me out ppl - will pay top dollar (i.e. $15 or so shipped )
DrSavant is offline
post #2 of 22 Old 04-26-2011, 04:36 PM
firedave's Avatar
Are you looking for the original one?
2016 Honda Africa Twin
1998 Kawi ZX9R (Sold)
firedave is offline
post #3 of 22 Old 04-26-2011, 05:42 PM
You may have already been through this....but mine was was requiring constant adjustment and was very touchy. I removed it from the bike and cleaned the plunger shaft with wd-40 and put some silicone lube on it and it was worked great ever since (6 months) with no adjustment. Also the adjustment had a much wider band of proper operation. I guess it gets mucked up with road grime and the plungers sticks.
For most OEM Parts my dealer gives a 10% discount for ordering online and no shipping charge if I pick it up at the dealer. May check that option too. Its usually cheaper in the long run for smaller parts.
Good luck!
post #4 of 22 Old 04-27-2011, 06:33 AM Thread Starter
FYTER
@firedave - doesn't matter - it could be one from a Fireblade, a 900 or a 954.
@marylandmike - actually I haven't - thank you for a great suggestion!!!
I automatically assumed this is a non-serviceable part, and I also realized, that it's probably been this way, since I bought the bike - I just never paid attention, until I started my customization project.
WD40 night it is!
DrSavant is offline
post #5 of 22 Old 04-27-2011, 07:56 AM
firedave's Avatar
Let us know how it works out. I have a OEM one without the connector you can have for the cost of shipping.
firedave is offline
post #6 of 22 Old 04-27-2011, 08:03 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Good luck!
Same here only it was stuck in the on position. Remove/clean/lube was the answer.
Doc
ST-DocLizard1 is offline
post #7 of 22 Old 04-27-2011, 02:02 PM
Hey guys, must be the time of the season or something.... but I lost my switch as well when my rear brake was out of commission for a while. Would any of you mind sending one my way? I'll pay the postage. I don't need the connector, just the tension spring.
fritzwilliam is offline
post #8 of 22 Old 04-27-2011, 08:34 PM
^^Opp, sorry about that DrSavant, thought you had fixed yours up. Guess I'm in the line then. Good luck.
post #9 of 22 Old 04-28-2011, 07:07 PM Thread Starter
FYTER
No worries. I'm out of the country right now, so can't deal with anything until I come back. By the sound of what people sat, it should be fixable.
If not, I'm grabbing that one
DrSavant is offline
post #10 of 22 Old 04-29-2011, 07:27 AM
Flatulent
The cable and switch from my local dealer is 13 bucks. I have to order a new one for myself as I just took mine apart last night and saw that it was completely corroded. I cleaned off most of the corrosion and it works again but I am replacing it just to be on the safe side.
If you haven't tried to clean it, just remove it from the bracket. Look at the switch and roll up the rubber sheath on the top. There are 2 white nubs that you press in, and pull the down and the switch comes apart. It is just two flat pieces of copper attached to the wires and the plunger has a piece of copper around it that when the lever is pressed down it moves the plunger down and creates the circuit. They get extremely corroded, and will not allow the current to flow. Clean it and polish it and reassemble it, and you should be back in business.
If you still need a cable shipped to Canada, PM me and I will order two and send one your way.
Jon
sodakshooter is offline
post #11 of 22 Old 04-30-2011, 10:16 AM
notsowisecracker
Monkeywrench's Avatar
Good luck!
Doc
+3 here
My bike only had 1200 miles when I got it, but rear brake switch was non funtional.
Disassemble
Clean
Goop it up with dielectric grease
Re-assemble
Monkeywrench is offline
post #12 of 22 Old 05-02-2011, 09:55 AM Thread Starter
FYTER
Thanks for all the suggestions - I love forums like this one
Interestingly enough, now I have one to add to the discussion - rubbing alcohol. I was fixing one of those cool 1/24 scale RC tanks (forgot batteries in it a few years ago, haven't touched it since, they leaked out), and WD40 wasn't really effective in cleaning the contacts, i.e. the tank just wouldn't come back to life.
After cleaning them with rubbing alcohol, I immediately got it back to life, much to my daughter's delight.
So, once I get to the brake switch, I'm adding the alcohol to the mix. Until then, off to trying to sort out my turn signal mess... They just stopped working, and it's not the relay. So now I'm going through the motions, one by one.
DrSavant is offline
post #13 of 22 Old 05-02-2011, 03:22 PM
slight derail....I used rubbing alcohol to restore my smartphone after it dropped in a bowl of water.
I grabbed it, and without turning it on, yanked the battery.
Doused the hole thing in rubbing alcohol for 10 seconds, shook it dry, let it sit for 4 hours, then turned it on.
Wamo.
post #14 of 22 Old 05-02-2011, 03:48 PM
Don't mind me, but if you already have a plate on the bike and don't have to do a Province of Ontario Safety Check, WHY worry about the most useless switch on the bike ?
You'll never use the rear without the front, and you'll use the front without the rear, so why worry about it ?
post #15 of 22 Old 05-02-2011, 04:07 PM
I would worry about it because when it malfunctions, it stays closed meaning that your brake light stays on all the time whether you are applying the brakes or not. Someone behind you gets no indication that you are stopping.
post #16 of 22 Old 05-24-2011, 06:49 PM
Any luck on the switch? Still looking around for one.
post #17 of 22 Old 05-24-2011, 07:22 PM
Pierre-Marc
I've got one I just removed to install Sato rearsets... PM me if interested
mx463 is offline
post #18 of 22 Old 06-30-2011, 09:44 AM
No association w/ Tirone.
redletter's Avatar
I love these forums, thanks to everyone above for saving me 20 bucks to get my "broken" brake switch fixed. Pulled it out and scraped it down and it works like a charm.
redletter is offline
post #19 of 22 Old 09-24-2011, 09:45 AM
Another option for the rear brake light switch.
Amazon.com: Tusk Hydraulic Brake Switch Nissin Brakes: Automotive
Instead of a mechanical switch actuated off of the rear brake lever this one works off hydraulic pressure in the rear brake line. Roughly the same price as a replacement stock switch, but shouldn't have to worry about reliability issues due to corrosion and road grime.
I also sprung for a boot to finish it off a little better
Brake Switch Boot
Pic of it installed.
post #20 of 22 Old 09-24-2011, 02:09 PM
Cool mod!
post #21 of 22 Old 09-24-2011, 03:01 PM
919 aka Hornet 900
Mr T81's Avatar
I'm sure that will work alot better, my rear brake switch as
been disconnected for the past 2 years. Don't need it
cause I always use the front brakes first.
Mr T81 is offline
post #22 of 22 Old 09-25-2011, 05:15 PM
Veteran Donation
Brake Switch Boot
This what I did when mine went out.I keep forgetting I even had to fix mine.
Which is wierd because when mine died, it caught fire, Well that's when I noticed it...
tvetree is offline
