OEM tail light - Wrist Twisters
post #1 of 9 Old 04-20-2011, 01:43 PM Thread Starter
ariannasdaddy's Avatar
OEM tail light
I just purchased 07 919 and it came with integrated tail light and no oem fender or tail/signal lights . I would like to find the oem stuff minus the fender. I cant really afford to spend a lot so if anyone has some oem stuff just kickin around in the garage I would pay for the shipping and perhaps a little more if desired. The tail light is what I would prefer more than the whole assembly. I would need the harness with it too if possible. I may do aftermarket signals.
Thanks to anyone who may be able to help
ariannasdaddy is offline
post #2 of 9 Old 04-20-2011, 06:19 PM
Most of the integrated taillights seem to be installed into the OEM housing. If you just buy a light socket for the one they invariably take out, you can probably just reuse what you have. Take the seat out and the lens off and see what you have left; be careful of the lens gasket that will fall out.
If they replaced the taillight lens with a clear one, I have a stocker that I just pulled off when I converted.
post #3 of 9 Old 04-20-2011, 06:28 PM
Take a pic of what you have so we can see what you need...
post #4 of 9 Old 04-20-2011, 06:34 PM Thread Starter
I will take pics tomorrow. It is the clear lens. It looks as if one socket is gone and the wires are soldered onto the board. More to follow.
post #5 of 9 Old 04-20-2011, 07:07 PM
Should be fairly simple to convert back, then. Red lens, bulb socket, maybe the detachable stub harness.
post #6 of 9 Old 04-20-2011, 08:33 PM
I've got red t/l lenses if you need one.
post #7 of 9 Old 04-21-2011, 02:35 AM Thread Starter
Anyone know if I can just remove the signal wires and still have the led break/tail light still work? I may try this and just install new turn signals.
post #8 of 9 Old 04-21-2011, 06:26 AM
firedave's Avatar
It should work. If you have the CA kit the tail/brake light should be run off of one of your original brake light bulb sockets. The signal lights are tied into two yellow wires. You should be able to disconnect the signals and wire in the new ones.
2016 Honda Africa Twin
1998 Kawi ZX9R (Sold)
firedave is offline
post #9 of 9 Old 04-21-2011, 11:01 AM
3dcycle's Avatar
i have a complete set up all brand new sold my bike dont need any of it anymore. taillight houseing lense new fender with use blinkers. the plate light wires and turn signal wires have been cut but everything else can plug in. shoot me a pm
3dcycle is offline
