NEW ERION EXHAUST for 919 - Wrist Twisters
post #1 of 29 Old 01-11-2011, 10:12 AM Thread Starter
Brand new Erion single sided exhaust for sale. Comes with clamp, hanger, hanger bracket, springs, bolts, washers, & silicone.
$275 & shipping.
PAULIBIKER is offline
post #2 of 29 Old 01-11-2011, 01:10 PM
arctic954's Avatar
Which mid-pipe is that? Holy hell.....very sweet one of a kind deal.
arctic954 is offline
post #3 of 29 Old 01-11-2011, 05:26 PM Thread Starter
It's from Two Bros.......................I bought many cans and pipes before going with my Jardine set-up.
I was going to mount it up just to listen to it, but never found the time.
I have about $155 in just the pipe, clamp, hanger mount, silicone, springs, & bolts.
The can is this one:
2004 2005 Kawasaki ZX 10R Stainless Muffler
Then I had to have a bushing machined for it all to work. It actually turned out WAY better than expected.
IMO single side is the ONLY way to go. It saves a TON of weight and actually makes a little more power.
post #4 of 29 Old 01-12-2011, 07:31 PM
sml2727's Avatar
How does this mount up to the 919 if its for a kawasaki? I would feel safer buying something like this if there was pics of it installed
"You live more in five minutes on a bike like this going flat out than some people do in a lifetime" - Burt Munro
sml2727 is offline
post #5 of 29 Old 01-12-2011, 08:17 PM
arctic954's Avatar
It's a two brothers mid-pipe for the 919......with whatever can you wish.
Many members have mounted pipes with the 2 bros mid-pipe. It drops a ton of weight, looks, sounds great. What's there not to like?
Here's my bike with an arrow can and the same mid. My can is off of a Suzuki gsxr-750.
post #6 of 29 Old 01-12-2011, 08:56 PM
schrock86's Avatar
Had I not sold my header and gone with the 900rr setup. I would have bought this already.
schrock86 is offline
post #7 of 29 Old 01-13-2011, 07:02 AM
You can mount anything if you have a hanger. The can is pretty much just a can. A few years back a member mounted an R1 can in the same way. The key is having a midpipe that routes to where the can needs to be.
In a few years we'll probably all be doing this because there won't be any 919 specific stuff available.
2015 Ducati Monster 1200S
FlyCatcher is offline
post #8 of 29 Old 01-13-2011, 08:03 AM
arctic954's Avatar
I'd like to add to this.....and several other members have mentioned this also......
Through an exhaust gas sniffer & via dyno testing my bike with the arrow/2 bros setup.....I've found that with the rich fuel setup from the factory that this single can setup let's the bike run right where it needs to be.
Basically what happened.....I was playing around one day and decided to unhook my PCIII......did a run around the block.....my bike pulled the hardest it ever had. So....off to the dyno to figure out why.....I also was willing to pay for a full custom tune. After a couple pulls....I was told not to bother.
I now run this setup with the stock 919 fueling and I sold my PCIII-USB.
post #9 of 29 Old 01-13-2011, 08:13 AM Thread Starter
I went with the Jardine Ti for the same bike (04-05 ZX10). It fits better than the model specific kits that I have used on my other bikes (SV650 & SV1000).
Through an exhaust gas sniffer & via dyno testing my bike with the arrow/2 bros setup.....I've found that with the rich fuel setup from the factory on the 919.....that this setup with the stock fueling puts the bike in it's sweet.
I now run the setup with the stock 919 fueling.
Mine fuels PERFECT & NO stink!!!!!!!!!!!!!!
post #10 of 29 Old 01-13-2011, 08:51 AM
What's the risk of running lean?
post #11 of 29 Old 01-13-2011, 09:29 AM Thread Starter
None, the 919 is rich from Honda. That is why a lot of guys have the "stink".
I'm just about right (still a little rich). My Vmax ran better on the lean side, but it was carburated. The Vmax guys always say "Lean is Mean".
post #12 of 29 Old 01-13-2011, 11:11 AM
not quite true... its rich in some places, lean in others. the pcIII comes in most useful in correcting the areas that are too lean (specific throttle positions relative to rpm), and fixing bottom end throttle take offs. perfect for rush hour types of traffic and helps smooth out the throttle response.
post #13 of 29 Old 01-13-2011, 01:43 PM
sml2727's Avatar
So your saying all I need to do is buy the 2 bros mid pipe and it will hook right up? were do you get the mid pipe from?
sml2727 is offline
post #14 of 29 Old 01-13-2011, 02:29 PM Thread Starter
The mid pipe is included. You will get everything you need for it to fit/work.
post #15 of 29 Old 01-13-2011, 02:49 PM
To correctly answer the question, running lean is bad for any engine! It gets too hot and just plain ruins stuff. Now, correctly mentioned, the 919 does run a bit rich from the factory. A PCIII is just an interface to be used to see your A/F mixture AND be able to tweak it (upload a custom map into the PCIII). Most of the time, when you modify anything on the exhaust, you can have a great effect on the A/F mixture because you are messing with backpressure. If you lessen backpressure, you'll run a bit leaner. So most here will say on the 919 it's no big deal, as you might be rich to begin with so a little 'leaning out' doesn't hurt it.
But do that on a bike that is lean to begin with and it's best to check your A/F ratios and maybe get it tweaked, either with a jet kit for carbed bikes or a fuel mapping device like the PCIII.
post #16 of 29 Old 01-14-2011, 03:13 PM Thread Starter
SOLD!!!!!!!!!!!!
But I do have another new in the box can, hanger, & bushing(required for it to work with the Two Bros pipe).
$125 + shipping.
post #17 of 29 Old 01-14-2011, 04:27 PM
Too slow to ride fast
Rick919's Avatar
SOLD!!!!!!!!!!!!
I'll take this one. Where do I send the money? (looks like I'll probably be keeping the 9er)
Rick919 is offline
post #18 of 29 Old 01-14-2011, 05:31 PM Thread Starter
PM sent.
post #19 of 29 Old 01-14-2011, 06:54 PM
schrock86's Avatar
If rick doesn't take it, I'd like to look at it.
post #20 of 29 Old 01-15-2011, 10:33 AM
Dragon Slayer
oak1971's Avatar
Argh, friggen too late again.
oak1971 is offline
post #21 of 29 Old 01-15-2011, 01:15 PM
sml2727's Avatar
I'm guessing you bought two mufflers to run them with the stock mid pipe?
sml2727 is offline
post #22 of 29 Old 01-19-2011, 12:02 PM
since Paul already sold his Erion I'm not stepping on any toes or hijacking his thread by saying I have the same exact new Erion can that I'd let go for the same price. It's brand new as well and you'll need a midpipe from two bros or have your own made. I had my own made for $30 bucks so it's cheaper to do it that way. It's the cheapest way to put an aftermarket pipe on one of these and it does improve the throttle response on these 9er's. First dibs gets her.
1fastrex is offline
post #23 of 29 Old 01-19-2011, 01:04 PM Thread Starter
No worries..............all my stuff is sold.
Keep in mind that you will need a bushing for it to work with the Two Bros pipe.
I never thought of having someone make a pipe.
I can't believe I missed out on your Akrapovic can over on the FZ board.
post #24 of 29 Old 01-19-2011, 01:23 PM
Having a midpipe made is the fastest and cheapest way to do these 919 exhaust mods. I use one particular muffler shop and they treat me right on the price....less than half the cost to buy one outright. They've done about 20 on various bikes for me over the past few years. If you have one made you don't need any bushings....that's what a pipe flaring machine is for. Yes, that CF Akro was a beautiful pipe but right now everything I own is a bolt on and I couldn't use it.
1fastrex is offline
post #25 of 29 Old 01-19-2011, 01:38 PM
sml2727's Avatar
Hmmmm intersting, do you know of dimensions to use for the midpipe?
sml2727 is offline
post #26 of 29 Old 01-21-2011, 10:16 AM
Hey PAULIBIKER, could you post a picture of what your bushing looks like?
Professional
post #27 of 29 Old 01-21-2011, 02:22 PM Thread Starter
Ya know, I never thought to snap a pic of it.
post #28 of 29 Old 01-24-2011, 10:20 AM
how does a single side exhaust affect the power output? Ive heard it robs a bit of low-down grunt and adds a bit of top-end. is this true?
jehicks87 is offline
post #29 of 29 Old 01-24-2011, 07:02 PM
No, it's a big improvement in all aspects of throttle response. Much crisper.
1fastrex is offline
