43mm Fork Damper clamp - Wrist Twisters
post #1 of 1 Old 12-15-2010, 08:45 AM Thread Starter
arctic954's Avatar
I just installed a side mount Ohlins GSXR damper on my 919. I ordered this Lockhart Philips 43mm fork clamp for one of the damper mount points.....I got a little impatient and decided to pull off the entire front end and drill a hole in my lower triple instead. Either way, after the job was completed this showed up in the mail.
It's a 2 piece design (so you don't have to pull your forks to use it) and when clamped on your 919 fork tube it gives you a mount point perfect for mounting a side mount GSXR damper. (or a universal damper if you wish)
So, if you want to install a damper.....save a ton of time...(it's a real nice looking aluminum piece too) here you go........
Asking $25 shipped
arctic954 is offline
