Geek Question - Wrist Twisters
post #1 of 37 Old 08-20-2007, 09:18 AM Thread Starter
Geek Question
I need to turn on global_registers in a php.ini file but permissions wont allow me any transfers, nor will chmod allow any changes on either the subfolder or the root. using smartftp which normally works just fine wont allow me changes on any of these folders.
any ideas which completely remedial step I'm missing?
post #2 of 37 Old 08-20-2007, 09:27 AM
if it's a unix box, and it's the main php.ini file for the system, only the system root user can change it, which means it can only be changed in a console (say, ssh)
if it's a unix/linux box you (or someone) will need to ssh into it and use an editor to modify it
putty is great for that in the XP world
if it's a windows box, I have no idea (none of the windows filesystem is sacred unless it's made so by the admin)
post #3 of 37 Old 08-20-2007, 09:30 AM
Wookie
ragdoll's Avatar
If it's Windows then you simply need Admin access to it. If you are Admin and still can't do it, let me know... I could just say you're in trouble if you can't get it.
If it's Unix(Man, Simpson is a smart guy), then I don't know.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #4 of 37 Old 08-20-2007, 09:31 AM
BANNED!
midwest's Avatar
Like......... wha?
I LOVE Tig Bitties!
midwest is offline
post #5 of 37 Old 08-20-2007, 09:41 AM
I'm a root user abuser.
post #6 of 37 Old 08-20-2007, 09:50 AM Thread Starter
it's unix - that's what I figured. for some reason I can ssh in to the old server with putty but not into the new one. nothing but troubles everywhere I turn.
clarification. I can access the new server via putty but none of the commands work. It lets me in but doesn't let me move around.
post #7 of 37 Old 08-20-2007, 10:02 AM
you will need to edit it and save it as the root user (superuser, admin)
post #8 of 37 Old 08-20-2007, 10:13 AM
http://www.itc.virginia.edu/desktop/...terglobal.html
note the entry about the .htaccess file
a google search for register_globals turns up a lot of info, including the PHP dev's take on my setting it "on" is a Bad Idea (tm)
it allows persistent memory "storage" of global data for the PHP and apache stack it allows data to persist between different websurfer streams. which means it can be snooped by 3rd parties (trivially) and used to gain access and/or flood the machine into an overflow mode and compromise it
it's truly a bad idea
http://us2.php.net/releases/4_1_0.php
post #9 of 37 Old 08-20-2007, 10:15 AM
Jet, if you can't get it. Let me know ... I'll hook you up with my brother. He's the UNIX - Java expert on Wall St.
RC51_CBRXX is offline
post #10 of 37 Old 08-20-2007, 10:16 AM
I feel so dumb.
post #11 of 37 Old 08-20-2007, 10:19 AM Thread Starter
getting closer - used putty to chmod the filename successfully. says everything ftp'd & overwrote correctly but still not getting anywhere.
https://www.wristtwisters.com/catalog/
you can see what's happening. i'm working in /usr/local/lib - maybe I should be working in /scripts
no worries I've chmod 'ed back to 644
post #12 of 37 Old 08-20-2007, 10:19 AM
Go for a ride and clear the head. It might just fix itself.
Lemonhead is offline
post #13 of 37 Old 08-20-2007, 10:21 AM
Originally Posted by RidgeRunner View Post
I feel so dumb.
This is why you hire experts. My time is better spent making my pornos and selling them.
post #14 of 37 Old 08-20-2007, 10:35 AM Thread Starter
spank a fuggin duck!
I got shyt.
turned on global_registers in both php.ini in /scripts and in /usr/local/lib and i got nothing.
that's the only 2 places putty found a php.ini file on the old server. argh!
have chmod everything back to 644 and need a drink.
post #15 of 37 Old 08-20-2007, 10:41 AM Thread Starter
also keep getting this:
# locate php.ini
warning: locate: could not open database: /var/lib/slocate/slocate.db: No such file or directory
warning: You need to run the 'updatedb' command (as root) to create the database.
Please have a look at /etc/updatedb.conf to enable the daily cron job.
any ideas? not sure I want to go running scripts that affect the entire server without knowing the ramifications and quick undo buttons.
post #16 of 37 Old 08-20-2007, 11:30 AM
Originally Posted by midwest View Post
Like......... wha?
+1
All I understood was, "blah, blah, blah". It sounded like Charlie Brown's teacher talking
phast 9er is offline
post #17 of 37 Old 08-20-2007, 12:18 PM
nOOb
stanlanman's Avatar
Just a Quick question for clarity - why are you turning it on? Is an installation script requiring it? It should be disabled after you are done with the installation because of the implicit security vulnerabilities.
You need to make sure ALL folders touched by the script have an .htaccess file that permits whatever it is you are trying to do. Maybe copy the .htaccess from a folder that is working OK to the other folders listed in the script.
options for Apache .htaccess => http://httpd.apache.org/docs/2.0/howto/htaccess.html
"Lighten up, Francis." - Sgt. M.F. Hulka
stanlanman is offline
post #18 of 37 Old 08-20-2007, 12:20 PM Thread Starter
for lack of a better answer Stan, I'm turning it on because
tells me to.
Now, I've reverted all register_globals = Off so it's back like it was. I just want the catalog to work.
post #19 of 37 Old 08-20-2007, 12:22 PM
Heavy Metal
ratdog's Avatar
most of the time chasing globals is bogus...
set the ownership of the files/subdir of the app you are trying to fix to the use/group running the websvr s/w
chown -R apache.apache /subdir/subdir/appimtryingtorun
works everytime for stuff like vbulletin/joomla/mambo/nuke etc. etc. and save u having to chmod the permissions to risky stuff
ratdog is offline
post #20 of 37 Old 08-20-2007, 12:23 PM Thread Starter
i like what you're saying. could you say it in a slightly different way?
post #21 of 37 Old 08-20-2007, 12:41 PM
nOOb
stanlanman's Avatar
I think you already tried chown 777 on the directories. What is the application? Here is a generic fix for file application_top.php:
if ( ($session_started == true) && (PHP_VERSION >= 4.3) && function_exists('ini_get') && (ini_get('register_globals') == false) ) {
extract($_SESSION, EXTR_OVERWRITE+EXTR_REFS);
post #22 of 37 Old 08-20-2007, 12:45 PM
Heavy Metal
ratdog's Avatar
tarball/zip file of appc installed by root = files owned by root
apache process running as user apache
apache process attempts to access app installed by root
new app appears to work but has hang ups in various areas
(file rwx permissions have allowed process owned by user apache to access some but not all of what is needed)
chdir to subdir where app installed
change ownership of app files/subdirs to user apache, group apache
now when apache web server (process running as userid apache) attempts to call app (using userid apache), files accessible because ownership syncs up
global register defaults are mostly ok w/ php as is...
ratdog is offline
post #23 of 37 Old 08-20-2007, 12:46 PM Thread Starter
it's oscommerce
post #24 of 37 Old 08-20-2007, 12:47 PM
Heavy Metal
ratdog's Avatar
that would have to be chmod 777 and that doesn't do it cause it has to do w/ process forking and sticky bits and what not...mostly what not
chown -R apache.apache /subdir/subdir/newappdir trumps chmod 777 which is just whacky and a desperate attempt atshortcutting a solution ...usually performed by S.A.'s underfire
ratdog is offline
post #25 of 37 Old 08-20-2007, 01:15 PM
Well this explains why I can't log on and buy stuff. Hehehehe.
resuscit8u is offline
post #26 of 37 Old 08-20-2007, 01:18 PM Thread Starter
what's up Jim?!? We're trying man. Hope all is well.
post #27 of 37 Old 08-20-2007, 01:31 PM
nOOb
stanlanman's Avatar
post #28 of 37 Old 08-20-2007, 01:52 PM
Heavy Metal
ratdog's Avatar
Quo Ed Demonstratum
ratdog is offline
post #29 of 37 Old 08-20-2007, 02:15 PM
Heavy Metal
ratdog's Avatar
try it now and let's see if you put your money where your mouth is...
ratdog is offline
post #30 of 37 Old 08-20-2007, 03:16 PM
Heavy Metal
ratdog's Avatar
# locate php.ini
better to chill and ask if u don't know
fixed it temporarily...ran updatedb, no worries, it just updates the slocate database...crushes system performance for a few mins if you don't nice it first
i'll check on why the cron isn't running it weekly/monthly
and the mail thing..
ratdog is offline
post #31 of 37 Old 08-20-2007, 04:49 PM
It is very good!
I need some digits made. Casey Stoner style. I will PM you.
post #32 of 37 Old 08-21-2007, 01:52 PM
Heavy Metal
ratdog's Avatar
stupid dumb post to test subscription function error...ignore this
ratdog is offline
post #33 of 37 Old 08-21-2007, 03:29 PM
Stupid dumb ignore adhered to.
post #34 of 37 Old 08-27-2007, 01:51 PM
Heavy Metal
ratdog's Avatar
testing 123
check
check
sylllllllabence
check
check
testing jb-ima-wizz-bang-sa-type-linux-butt-kicker's fix of subsc mail prob
ignore ignore ignore...
ratdog is offline
post #35 of 37 Old 08-27-2007, 02:03 PM Thread Starter
these go to eleven.
post #36 of 37 Old 08-27-2007, 02:06 PM
wisco919's Avatar
these go to eleven.
Is that a Spinal Tap referrence? It made me laugh.
wisco919 is offline
post #37 of 37 Old 08-27-2007, 02:08 PM Thread Starter
working on a sex farm
plowing through your fields
getting out my pitchfork
poking your hay
LOL!
