fuel leak at full shut off valve - Wrist Twisters
post #1 of 5 Old 05-17-2015, 12:30 PM Thread Starter
rocker70's Avatar
I found a minor gas leak at the shut off valve, looks like 4 screws or bolts need to be tightened but I can't tell what type of head is used, what tools do I need to fix this?
rocker70 is offline
post #2 of 5 Old 05-17-2015, 01:08 PM
rpcraft's Avatar
The Hornet has a shutoff valve?
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #3 of 5 Old 05-17-2015, 01:17 PM
Which motorcycle?
post #4 of 5 Old 05-17-2015, 01:31 PM Thread Starter
rocker70's Avatar
Vulcan vn750
rocker70 is offline
post #5 of 5 Old 05-19-2015, 02:34 AM
I am assuming the four screws to which you are referring to are on the back of the petcock, #221 in the attached illustration. They are holding the outer plate of the vacuum fuel shutoff valve and are 4mm Philips head screws usually needing a #2 Philips screwdriver. You will also need a new vacuum diaphragm, #43028 in the illustration.
It tends to get brittle with continuous exposure to fuel and can crack, sending raw fuel into the cylinders. This is bad as it can wash off the oil necessary for the sealing and lubrication of the piston rings, causing scoring of the cylinder walls necessitating a top end rebuild with all the attendant parts and labor bills. Of course it also can drop gas onto the motor, which with little provocation can ignite and leave you standing by the side of the road watching your pride and joy burn to the ground upon which it is laying. Trust me, it is a very bad feeling!
Obviously I recommend taking care of this small problem before it becomes a big one.
