Yosh trs baffle question - Wrist Twisters
post #1 of 20 Old 06-21-2013, 08:03 PM Thread Starter
So since I got the bike the pipes have opened up a lot and gotten a decent amount louder. They came with the baffles removed, but they came along with it. I went to put them in today, and it seems pretty simple, but I got them in and they rattle horribly. Any ideas/suggestions/what I could be missing/doing wrong?
post #2 of 20 Old 06-22-2013, 02:10 PM
moza's Avatar
Yeah mine came with an extra washer about 1-2mm thick to go on the end before putting the cover back on to take up the slack or you could use something like steel wool for temporary
moza is offline
post #3 of 20 Old 06-22-2013, 04:32 PM
Canadian Blue
Mark919's Avatar
The baffles i put on my two brothers exhaust had o-rings to snug them down. You could just use silicone gasket eliminator if you have nothing specific for the Yoshi.
Mark919 is offline
post #4 of 20 Old 06-22-2013, 04:51 PM Thread Starter
The pipes came with the bike and the baffles were already out and in a box.. I got every other fastener that came off the bike and he had every other stock piece that was changed or removed, so I find it hard to believe he left those out, and I don't see any wear marks/clean spots from any washer. Everything else is covered in carbon that wasn't touched by the cap and you can see where those line up. But it's super loose and rattles also, and I don't think I could mess up putting it in, so I'm at a loss... Anyone have a set of trs's that could pull them apart and check/take some pictures?
post #5 of 20 Old 06-22-2013, 07:11 PM
Total Awards: 17
some baffles have a screw which hold them in place. If you don't see any provisions for one, I'd use high temp RTV and set the baffle on it, than some more RTV to set the cap.
zaq123 is offline
post #6 of 20 Old 06-22-2013, 07:52 PM Thread Starter
There's three screws in the cap that clamp it down, and I don't see any other holes for a fastener... I guess I'll just do the rtv
post #7 of 20 Old 06-22-2013, 08:11 PM
Total Awards: 17
also you try to use some gasket making material to snug it up a little. Cut it to donut shape and you are in business. You can also try cutting it to doughnut shape but it will be a little more involved. Glaze it with some RTV of your liking too
zaq123 is offline
post #8 of 20 Old 06-22-2013, 10:53 PM
Niner's Avatar
I've got the same setup and when I added the inserts they snugged up fine. I'd have to agree with the others about black RTV or something similar. Maybe something like this?-
Niner is offline
post #9 of 20 Old 06-22-2013, 10:54 PM
Niner's Avatar
Niner is offline
post #10 of 20 Old 06-25-2013, 07:37 PM
moza's Avatar
Just a simple spacer came with mine
moza is offline
post #11 of 20 Old 06-25-2013, 08:29 PM Thread Starter
Any chance you could give me a thickness/measurement on that? I could just make some at work.
post #12 of 20 Old 06-26-2013, 01:32 AM
moza's Avatar
Yeah no probs ill get the vernier on it when I get home from work
moza is offline
post #13 of 20 Old 06-26-2013, 03:30 AM
Need more money
DDT26's Avatar
1.285 ID
2.535 OD
.035 THK
DDT26 is offline
post #14 of 20 Old 06-26-2013, 05:24 AM Thread Starter
Thank you!
post #15 of 20 Old 06-27-2013, 05:53 PM
moza's Avatar
I was getting there lol
.9 mm thick
64.4mm OD
32.7 mm iD
Cheers
moza is offline
post #16 of 20 Old 06-27-2013, 08:10 PM
foggy's Avatar
Odd, mine didn't come with spacers and didn't rattle.
foggy is offline
post #17 of 20 Old 06-27-2013, 11:52 PM
moza's Avatar
Probly all depends on where they weld the first one and final inspection might measure and throw them in
moza is offline
post #18 of 20 Old 07-29-2013, 09:21 AM Thread Starter
crap
so I ended up just using black RTV to hold them in... but now I decided it's much to quiet unless I was going on a very long trip, and I can't get the damn baffles back out... I tried heating them up with a heat gun as much as I felt comfortable, but I don't want to damage the pipes or the paint.... Any suggestions?
post #19 of 20 Old 07-30-2013, 08:44 PM Thread Starter
Anyone?
post #20 of 20 Old 07-30-2013, 09:17 PM
Niner's Avatar
Maybe try putting some heat on it? A propane torch held a good distance back might do the trick.
Niner is offline
