Yikes! Bike lurched forward in neutral! - Wrist Twisters
post #1 of 31 Old 08-23-2009, 09:23 AM Thread Starter
Exclamation Yikes! Bike lurched forward in neutral!
I put on my new Yoshimura slip ons and noticed that the bike seems jumpy now. It's like how a lot of people complain about the throttle being very sensitive in 1st gear. Well, thats how it seems now, but even in 2nd and 3rd. I don't know if it just the increased volume of the new mufflers that make me perceive it that way, or maybe thats the way its supposed to feel after new slip ons??
I had my bike parked and a co-worker wanted to hear the new pipes, so I turned the bike on put it in neutral and when I went to rev it a little, the bike jumped forward, it pulled like it was going to take off. Scary as hell. Bike was not cold because I had just rode to work. Also, noticed when I had it on the center stand, right after installing pipes, when I revved it the back tired spun.
I don't even know if has anything to do with my new slip ons or not. Anyone know why it would do that? Clutch?
2526 is offline
post #2 of 31 Old 08-23-2009, 09:31 AM
Sounds like clutch. you will notice some spin while on a stand but you should be able to stop it with your hand with almost no effort.
Ripper is offline
post #3 of 31 Old 08-23-2009, 10:58 AM
You may have added a couple HP with the slip-ons, thats maybe why the throttle seems more sensitive.
As for the lurching, you may need a clutch adjustment. However, How long has it been since you changed Oil? You'll get nicer clutch and transmission action with clean oil if its due to be changed. Was this yesterday, when it was so hot out?
post #4 of 31 Old 08-23-2009, 11:01 AM
The exhaust has nothing to do with it.
The transmission, however, does.
If the rear wheel is turning faster than a slow crawl while th engine is running in neutral, particularly if it's already up to operating temperature, and can't be stopped by hand, this indicates one of the gears that is free to to rotate on it's shaft may be starting to bind in some way, and somehow it's firm enough to transmit power sufficiently to drive the bike forward.
Have the engine cases ever been opened up? Particularly if there has been trans work, it sounds like one of the gear bushings may have been installed with the oil holes not registered to the feeds on the shafts, starving the plain bearing and galling / seizing on the shaft. I have also seen this happen with pressure lubricated transmissions (which the 919 has) from coasting down a long mountain road with the engine off. Pressure lubricated plain bearings spinning rapidly minus oil pressure = seized bearing.
+1
Change the oil and run a strong magnet through it. If it has a few minor metal flakes in it you're fine, but if it's hairy something is grinding itself to uselessness, and must be addressed.
Diagnosis:
Support the bike with the rear wheel off the ground. Spin the rear wheel in the normal direction while feeling for drag. If there is a trans problem the lower run of the chain will get tight and stay that way as long as it's turning.
I sincerely hope it's something else, anything else, especially if that something else doesn't require a bottom end teardown. My extensive experience with transmissions tells me this is a possibility.
Good luck.
post #5 of 31 Old 08-23-2009, 11:15 AM
Rob,
I'm pretty sure her bike has never been torn down since it left the factory.
post #6 of 31 Old 08-23-2009, 11:40 AM
Curious to see how this unfolds, hopefully a fresh oil change will take care of the problem.
post #7 of 31 Old 08-23-2009, 12:05 PM Thread Starter
I changed my oil about 1500 miles ago. Is that too long?
I bought the bike brand new with only .4 of a mile on it and I've never opened up anything on the engine.
I put it up on the stand and when revving the wheel spins a little but can be stopped with the hand easily without any force.
This was yesterday but it was early in the morning before it go too hot.
My clutch is adjusted to engage closer to the grip because my hands are on the smaller size, so maybe I need to let it out a little bit. Isn't there supposed to be some slack on the cable? There is no free play on the lever.
2526 is offline
post #8 of 31 Old 08-23-2009, 12:16 PM
You shouldn't need an oil change yet but if you're not running full synthetic you might give it a try. Expensive, but I could tell a difference in the way my transmission shifted more smoothly.
There should be a tiny bit of freeplay in your clutch lever, that's why everyone complains about their lever vibrating in neutral. You may not be getting full clutch disengagement if it's adjusted too tight and your lever doesn't have much travel, will also cause it wear out more quickly. Doesn't explain your problem in neutral though unfortunately.
post #9 of 31 Old 08-23-2009, 12:48 PM
my 919 did the same thing... when you rev'd it up the bike kinda sorta "moved" forward enough to scare you into thinking it was gonna fall off the kickstand...
i am willing to bet if everyone with a 919 went outside and rev'd the bike in neutral theirs would do the same thing...
i also kept my clutch adjusted closer to the grip... maybe put a hair more play in it...
when i went to syn oil it was not nearly as noticable... i honestly don't think there is anything to worry about...
i beat the snot out of mine for 9500 miles and the clutch still was as slip free as the day i bought it...
everyone go try and rev your bikes to ~6-7k while in neutral and i bet it will act like its gonna jump off the kickstand...`
post #10 of 31 Old 08-23-2009, 02:08 PM Thread Starter
Thanks for all the help guys! I will definitely change the oil and check for shavings as soon as I run and get a filter to see if the helps. I have regular dinosaur oil in it now so maybe changing to synthetic will help. The wheel spun fine without any drag that I could notice nor did the chain tighten up along the bottom.
Now that I think about it, it was right about 7k. I hope its more or less normal for the 919. But still, it sure scared the heck out of me and my co-worker because his bike was in front of mine.
2526 is offline
post #11 of 31 Old 08-23-2009, 02:56 PM
Attitude is Everything
919Chef's Avatar
Slight side question...
How long do you go between oil changes? I thought the service schedule recommends every 600 miles? Seems pretty often but what do I know.
Do or Do Not... There is No Try.
2007 919...Delkevic Stubbies, Carbonfiber Hondaline Wind Screen, Integrated Blinker Mirrors, Brake Light Modulator, Headlight Modulator(soon)
919Chef is offline
post #12 of 31 Old 08-23-2009, 03:46 PM
600 miles is only the first oil change...after that the manual says 8K...I change mine every 2-3K.
post #13 of 31 Old 08-23-2009, 04:34 PM
919Chef's Avatar
Thanks.. Ithought that was a bit much
919Chef is offline
post #14 of 31 Old 08-27-2009, 12:40 PM
Guzzi Man
You need free play - see your owners manual - about 3/8" or 10mm at the ball end of the lever!
mikestib1 is offline
post #15 of 31 Old 08-28-2009, 03:04 AM
She can't have that much. She has little bitty hands
post #16 of 31 Old 08-28-2009, 08:15 AM
The "Eagle" Has Landed
Aquila-RC51's Avatar
Barton is right, he has the same size hands!
Aquila-RC51 is offline
post #17 of 31 Old 08-28-2009, 08:55 AM
i have big hands... long fingers.... size 13 ring.... covered with scars and teeth marks...
post #18 of 31 Old 08-28-2009, 02:10 PM
Vehicle Abuse Specialist
WheelieTime's Avatar
Thats one hell of a pickup line
WheelieTime is offline
post #19 of 31 Old 08-28-2009, 03:01 PM
turned you on did i?????
post #20 of 31 Old 08-28-2009, 10:38 PM
Go'n So slow I'm stopped
xrmikey's Avatar
If anybody thinks this issue has anything to do with clutch lever free play, smack yourselves in the head!
When the bike is in neutral, the clutch is fully engaged.
Less free play would make it less likely to lunge in gear. More likely to cause premature clutch wear due to slippage.
More lever free play will make the clutch bite sooner due to lack of disengagement Vs. lever travel. Once again, only in gear.
In neutral. It's irrelevant.
See robs post.
If there is no gear or bearing issues, I think its just a little viscus oil force combined with motor torque to make the bike move a little, along with a combined set of circumstances.
xrmikey is offline
post #21 of 31 Old 08-29-2009, 10:05 AM
The rear wheel spinning is a "cold oil at start-up issue" (like mikey said - more viscus) and nothing more. I'm willing to bet that once up to temp the rear wheel doesn't spin while on the centerstand. It's more pronounced in cooler climates and less so in hotter climates. Completely normal.
Professional
post #22 of 31 Old 08-29-2009, 10:30 AM
Legalize it please?
BigMike919's Avatar
Anyone know if she found a problem? Or fixed it?
2007 CB900f- sold
2009 K1300s- rockin out
BigMike919 is offline
post #23 of 31 Old 08-29-2009, 12:40 PM
i think she took my advice....
post #24 of 31 Old 08-29-2009, 07:53 PM Thread Starter
I checked what Rob said and didn't seem to find any problems. I guess the bike could of cooled off a bit. I rode to work (only 3 miles) parked it for about 10 minutes thats when I started it up, so hopefully it was due to the cool oil/wheel grab. It just scared the heck out of me, never experienced that before so I worried all day about it. I don't want to try it again, so I just hope it was all circumstantial.
2526 is offline
post #25 of 31 Old 08-29-2009, 10:46 PM
There's one cause everyone seems to have missed ... at 7000 rpm the 919 wants to be moving along at a good clip, not sitting in a parking lot just making noise. It is, after all, not a Harley. Watch it girl!
post #26 of 31 Old 08-30-2009, 05:10 AM
Viscosity
I started my Hornet 900 today on the rear stand. And noticed the rear wheel slowly turning. I could easily stop it with one finger.
I noticed that the rpm was about 1500.
Then I got to thinking. Cold start + 10W40 + rotating parts running in an oil bath = output shaft turns over.
Pist-N-Broke is offline
post #27 of 31 Old 09-02-2009, 06:24 AM
I just started mine to double check my theory (post #21) and it indeed just barely spins and stopped in about 1.5 minutes. Ambient temp this morning is 82 degrees at 6:15 am here in my neck of SO CAL. I know that in the winter the rear wheel spins faster and longer (colder oil). It's so normal, I really don' even pay attention to it any more.
I think Rob might be on to something as well with his above post though.
Professional
post #28 of 31 Old 09-02-2009, 08:44 AM Thread Starter
LOL
Good advice!
2526 is offline
post #29 of 31 Old 09-02-2009, 04:33 PM
Legalize it please?
BigMike919's Avatar
Dear lord don't try it with a HD either! I don't think any HD can rev to 7,000 rpm!
2007 CB900f- sold
post #30 of 31 Old 09-02-2009, 05:30 PM
Wrong!!! V-Rod Does!
Ka-Ching, pay the man!
post #31 of 31 Old 09-02-2009, 05:32 PM
Dear lord don't try it with a HD either! I don't think any HD can rev to 7,000 rpm! without falling apart....
i fixed that for ya....
