xr600 carb - Wrist Twisters
post #1 of 5 Old 05-12-2012, 11:27 AM Thread Starter
919Rev's Avatar
xr600 carb
Well, I took a short little ride today and almost got myself in a little mess. Some of you know I just recently bought an old xr600r. It has a plate and is street legal. I took it down the road to a little area of some dirt and trails where I have been riding since I got it. I'd been riding for about an hour - came out of a corner and wheelied a bit. Once I straightened it up it bogged and cut off. Looked down and gas was pouring out of the carb overflow tube. I immediately put the petcock in the off position. That is when I realized that I had very few tools with me.
I figured it was the float so I found a little wrench and knocked on the side of the carb a bit. Turned the fuel back on and it started pouring out again. Crap! Turned fuel back off. Knocked on the carb a little harder. Turned fuel back on...still pouring out....CRAP AGAIN! At this point I started looking for a way to remove the float bowl to get to the float. I discovered I didn't have a screwdriver that was worth anything in order to get the screws out of the float bowl. I start thinking about my options. I am about 3 miles from the house. You have to drive through some pretty deep mud to get back to where I am. I have my phone but I don't really have anyone I can think of with a 4-wheel drive truck to help me out. I'm definitely not calling my wife because....well...just because. Stupid bike!
OK, so I'm hot, aggravated and can't just leave my bike sitting there and walk home to get more tools. I pull the air filter off and set it out in the sun to dry. Suddenly I think....."bounce the bike around you idiot". I hop on the bike and bounce on the pegs several times as hard as I can. Turn the fuel back on and none is overflowing. Quickly put the air filter on. I fire it up in about 3 kicks and haul butt to the house.
Should I just replace the float and needle? Needle only? What would you do? This is the first time it has happened. I have ridden it roughly a dozen times since buying it.
When I die I want to die peacefully in my sleep like my grandfather did....not screaming in horror like the passengers in the backseat of his car.
919Rev is offline
post #2 of 5 Old 05-12-2012, 11:41 AM
If you're going to replace it replace needle and seat both, I'd strip the carb down to bare nuts and hit everything with a little spray carb cleaner first then inspect everything closely for grunge/debry, XR carbs are pretty basic and durable.
voodooridr is online now
post #3 of 5 Old 05-12-2012, 06:42 PM
typically when a carb is stripped down and reassembled and there are issues with the float, 1 of 2 mistakes tend to happen:
1. on reassembly the floats are not set correctly or tolerances are not paid attention to.
2. the slide doesn't get cleaned and/or lubed (a dab of transmission fluid works great).
tear em back apart again and take a look at the floats as well as the slides to find out what's going on.
post #4 of 5 Old 05-12-2012, 06:45 PM Thread Starter
919Rev's Avatar
Maybe my post wasn't clear. Sorry.
I haven't had the carb torn apart yet.
919Rev is offline
post #5 of 5 Old 05-14-2012, 02:06 PM
Interesting, I've never lubed my slide and it always seems to work just fine. Maybe enough 'prep work' wasn't performed prior?
