WTF!? Wheel Bearing Toast at 35k? - Wrist Twisters
post #1 of 26 Old 12-01-2013, 11:49 AM Thread Starter
"CERTIFIABLE"
Ken Phenix's Avatar
Really? The right rear is toast. the left and cush drive bearings are fine. Is this totally unheard of or what?
Ken Phenix is offline
post #2 of 26 Old 12-01-2013, 11:54 AM
to much offroading. LOL Mine went at 42k.
NZspokes is offline
post #3 of 26 Old 12-01-2013, 12:18 PM
Mine went at about 35k as well...Maryland Mike's too, and several others as I recall. 35k +/- seems to be the sweet spot for replacing the rear bearings on the 919.
post #4 of 26 Old 12-01-2013, 12:26 PM
Yup. Sounds about right. I just do mine about every 50K kms just to be sure.
post #5 of 26 Old 12-01-2013, 12:58 PM
I'll be replacing mine around 30k just to be safe....
post #6 of 26 Old 12-01-2013, 01:22 PM
yeah definitely not unheard of.
post #7 of 26 Old 12-01-2013, 01:28 PM
Yep right rear went at 37K....seems to be pretty common at that mileage.
post #8 of 26 Old 12-01-2013, 01:28 PM
That's about normal per most people who've posted. I replaced mine with Koyo bearings at 60K and will probably replace them again at 90K, if only to see how they fare vs the NSKs (who I don't think were as good at bearings) that Honda installed originally.
post #9 of 26 Old 12-01-2013, 02:39 PM Thread Starter
"CERTIFIABLE"
Ken Phenix's Avatar
How about the cush drive bearing?
post #10 of 26 Old 12-01-2013, 02:44 PM
They come as a set, you might as well replace them as a set.
post #11 of 26 Old 12-01-2013, 03:49 PM
Put me down for right rear failure at 28k miles... And I mean failure. Galled up, broken and downright ugly.
robroten is offline
post #12 of 26 Old 12-01-2013, 04:12 PM
voodooridr is online now
post #13 of 26 Old 12-01-2013, 04:29 PM
I think I did that one only once. My local bearing shop didn't have that size. It's not as important.
post #14 of 26 Old 12-01-2013, 05:35 PM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Mine made it to 38,074 miles before being changed out. It was so sloppy that you could wiggle the rear wheel and see the axle wallow in the bearing, but only on the brake side. Now coming up on 70k and I am ready for the next change.
ST-DocLizard1 is offline
post #15 of 26 Old 12-02-2013, 01:42 PM
Had mine done at 30k for good measure, nothing wrong with them at the time. Cush, and the two in the wheel all at one time.
Get the set from Boss bearing (Ebay), a little more than all ball but they are highly regarded Japanese bearings, not Chinese. They're still cheaper than going Honda replacements.
post #16 of 26 Old 12-02-2013, 02:09 PM
Let me guess all you guys that have had low mileage bearing failures always torque your axle nuts to the spec in the service manual don't you....
post #17 of 26 Old 12-02-2013, 02:15 PM
Legitimate question - do you consider 35k miles low mileage for a sealed bearing?
post #18 of 26 Old 12-02-2013, 02:18 PM
I do.
post #19 of 26 Old 12-02-2013, 02:24 PM
Should be pointed out that many motorcycle bearings, no matter who made the bike, rarely last *longer* than 30-40K these days with normal urban riding. If you replace them with All Balls' Chinese made bearings, you're looking at maybe 15-20K, which is why I sought out and found those Koyos that people are recommending upthread.
If you do a lot of highway work, you should see them last longer. But 30K seems to be 'average' life for 'average' city use with 'average' care.
However, if you use a pressure washer to clean your bike? Yeah, good luck, might not see even 15-20K out of even OEM bearings.
post #20 of 26 Old 12-02-2013, 03:08 PM
What do you recomend?
post #21 of 26 Old 12-02-2013, 03:15 PM
I've been torquing my rear axle to 50-55ft/lbs since LDH mentioned overtightening. I don't have the privelege to lift the rear all the time to get a proper torque by feel in. Plus I'd go OCD on it and keep loosening it to get a better feel on the next one.
post #22 of 26 Old 12-02-2013, 03:31 PM
Just a heads up...
If you go to "Helpful topics for 919 owners", under "Maintenance/Helpful How-to's" theres a thread on repacking wheel bearings...read it! If you do this when the bearings are still relatively new, and then periodically, they will probably last for the life of the bike.
Professional
post #23 of 26 Old 12-02-2013, 03:53 PM
At least!
post #24 of 26 Old 12-03-2013, 05:04 AM
moza's Avatar
What's a Cush drive
moza is offline
post #25 of 26 Old 12-03-2013, 05:38 AM
Originally Posted by moza View Post
What's a Cush drive
Your rear sprocket mounts to a carrier. The carrier fits inside a rubber bumper lined receiver inside the hub of your rear wheel.
The idea is to lessen shock loads to the drive train.
Professional
post #26 of 26 Old 12-07-2013, 12:20 PM
moza's Avatar
Ah ok cool now I get it
moza is offline
