Wreck gixxr rebuild - Wrist Twisters
post #1 of 406 Old 07-21-2012, 08:31 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Wreck gixxr rebuild
Ok here we go, got this 2000 GSXR 750 that had been wrecked, this will be a tale of its road back to the road
:buell:
Whiplash97 is offline
post #2 of 406 Old 07-21-2012, 08:33 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Got the forks back on
:buell:
post #3 of 406 Old 07-22-2012, 10:42 AM Thread Starter
StormSurfer
Whiplash97's Avatar
Alright trying to work out some of the wiring, on big problem, some bonehead snatched the key switch so it's going to be tough to get power into this lifeless body
:buell:
post #4 of 406 Old 07-22-2012, 11:54 AM
What?
2002-919's Avatar
Pick one. Hide it somewhere. Custom.
http://www.amazon.com/b?ie=UTF8&node=3398801
2002-919 is offline
post #5 of 406 Old 07-22-2012, 12:06 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Yes smokin idea, and even my style, so being that they unplugged the hole thing what's the safest way to power up the CPU? I'm not above pilfering from other bikes
:buell:
post #6 of 406 Old 07-22-2012, 04:19 PM Thread Starter
StormSurfer
Whiplash97's Avatar
It's starting to resemble a bike again
:buell:
post #7 of 406 Old 07-22-2012, 04:20 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Omg! Without the key switch the wiring is a disaster! Help!!
:buell:
post #8 of 406 Old 07-22-2012, 05:11 PM Thread Starter
StormSurfer
Whiplash97's Avatar
I got it to power up something in the FI, what else needs power to get this thing to fire?
:buell:
post #9 of 406 Old 07-22-2012, 05:23 PM
ECU, all the sensors, etc.
post #10 of 406 Old 07-22-2012, 05:29 PM
You will have to get power to 2-3 circuits in the switch cannon plug at the same time. Also there may be gear switch, kickstand switch, clutch switch etc. that will keep it from starting.
You really need a wiring diagram to make sure all the circuits are good and you don't unintentionally hurt something trying to hot wire it.
post #11 of 406 Old 07-22-2012, 05:40 PM
undercover919's Avatar
x 1000 Last thing you wanna do is hurry through a wiring project on this beast and have it cost you lots of money, as well as a headache
I suggest looking on ebay for a ignition switch set for it.. gives you ability to lock forks and have a key so not just anyone can jump on it and go.
Edit: I think I found one for ya
http://www.ebay.com/itm/IGNITION-SWI...item53e1090985
2003 Honda 919
undercover919 is offline
post #12 of 406 Old 07-23-2012, 04:50 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Yep that's the one I been lookin at
:buell:
post #13 of 406 Old 07-24-2012, 09:25 AM Thread Starter
StormSurfer
Whiplash97's Avatar
Ok got a service manual on the way, says it has a full, in color wiring diagram, that should be a big help, yes? I just want to hear this beast come to life
:buell:
post #14 of 406 Old 07-24-2012, 10:33 AM
blur
drewvir's Avatar
yea whip,
now ur cookin'. you also might want to look into a wire harness from ebay if yours is damaged.
a multi-meter is an invaluable tool if you don't have one.
good luck and keep us posted
drewvir is offline
post #15 of 406 Old 07-24-2012, 10:42 AM Thread Starter
StormSurfer
Whiplash97's Avatar
Originally Posted by drewvir
yea whip,
I have the meter covered, the harness has some damage but I'll have to see, some of it is just blinks that got ripped of, easy to rewire,
I might shop for one any way, the plug to the rectifier is kinda melted
:buell:
post #16 of 406 Old 07-24-2012, 10:54 AM
blur
drewvir's Avatar
re: rec/reg
i don't know if it's a gsxr problem but many of the interceptor boys experience reg/rec failure and plug melting.
you might want to google it to see if it's a gsxr problem for your year
drewvir is offline
post #17 of 406 Old 07-24-2012, 11:41 AM
It's been 3.5 days and this thing still isn't running! Is this project stalled?
Haha. j/k man. Keep working at it.
post #18 of 406 Old 07-24-2012, 11:48 AM Thread Starter
StormSurfer
Whiplash97's Avatar
re: rec/reg
Turns our this is true, but sounds like the fix is easy, just hard wire the rec/reg,
My next mission isn't so simple, I'm out to figure out how to hot wire this puppy, most are being pretty uncooperative so far, being that posting pictures from my phone can't be done on most forums, the answer I've been getting is "how do we know it's really yours?" well if they could see it they would probably be more free with the info
:buell:
post #19 of 406 Old 07-24-2012, 12:44 PM Thread Starter
StormSurfer
Whiplash97's Avatar
I'm glad I belong to WT! I just witnessed a bloodbath on gixxer.com, another member there had already asked hot to Hotwire a GSXR 600 and was almost cained to death, I understand the guys not wanting to answer that question, but this poor bastard got crusified! So I'll just wait for the manual an figure it out for myself minus the bloodshed
Jim, this is going to be as quick as I can go believe me I want to get this puppy road worthy ASAP, but my work week of 4/12's put a big damper on it, and I have other bikes to fix so I can fund my projects, I'll keep chipping away at it, you all will be the first to know when she takes her first breath...
So here's a "safe" question, my gauges/speedo/tac are gone, could the present any problems in starting?
:buell:
post #20 of 406 Old 07-24-2012, 01:38 PM
Waiting on the manual is the best idea. You should also try and get the cluster set up so that you have some of indication that you are going in the right direction when you are applying power.
post #21 of 406 Old 07-24-2012, 01:45 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Figured you'd say that, already been shopping
Wow!! Those are cheap!
:buell:
post #22 of 406 Old 07-24-2012, 04:22 PM
My 919, would not start up without gauges. At least I'm pretty sure. Without hotwiring something.
post #23 of 406 Old 07-24-2012, 04:38 PM Thread Starter
StormSurfer
Whiplash97's Avatar
The plug for the gauges looks pretty intense(lots of wires) so I'm thinking that will have to be dealt with when the time comes
:buell:
post #24 of 406 Old 07-24-2012, 05:31 PM
My '02 919 will start without gauges, as long as the ignition switch/kill switch are connected u are good to go.
post #25 of 406 Old 07-26-2012, 02:28 PM
redline919's Avatar
You need a 15 ohm resistor. Or it will not start. Just buy a used switch and key and b done with it. You dont want someone stealing your bike then suing you when they hurt themselves on it
redline919 is offline
post #26 of 406 Old 07-26-2012, 06:52 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Yes hard facts, I'm shopping right now.....I've found a few, I think most years will work as long as it has the 6 prong plug, I'm talking like '99-'05, please correct me if I'm wrong, I'd rather not buy the wrong one
:buell:
post #27 of 406 Old 07-26-2012, 06:59 PM Thread Starter
StormSurfer
Whiplash97's Avatar
This one say it will fit a 1999 GSXR 750, my finger is on the buy it now button, just want a second opinion, give me the word!
[ATTACH]21
:buell:
post #28 of 406 Old 07-26-2012, 07:17 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Sorry I screwed that post all up, I'm looking at the one with the green plug
Anyway here's the latest pic, almost looking like a bike again
:buell:
post #29 of 406 Old 07-26-2012, 08:04 PM
is it me or does the key look bent on the one with the green plug. I'd say go for it, if it has the right style plug and isn't outrageously expensive.
2003 Honda 919
post #30 of 406 Old 07-26-2012, 08:09 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Yes the key is bent, but it's only $25.00 with shipping, and it is compatible, yeehaa!!
:buell:
post #31 of 406 Old 07-27-2012, 12:16 AM Thread Starter
StormSurfer
Whiplash97's Avatar
Turns out the GIXXR doesn't need the gauge cluster to run, but is highly recommended
:buell:
post #32 of 406 Old 07-27-2012, 07:36 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Ok got a key switch on the way, no hotwireing here, now I'm on the hunt for a fuel cap
What kind? And what parts do I need? The caps I'm looking at appear to be needing some sort of spacer to go under them
:buell:
post #33 of 406 Old 07-27-2012, 08:03 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Motosport has the cap and key listed for $215.70
:buell:
post #34 of 406 Old 07-27-2012, 08:14 PM
redline919's Avatar
post #35 of 406 Old 07-27-2012, 08:38 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Ha that's the one I was looking at
I'll get it ordered as soon as wifey falls asleep
:buell:
post #36 of 406 Old 07-28-2012, 05:33 AM Thread Starter
StormSurfer
Whiplash97's Avatar
Would these work for head lights on my GIXXR?
If not, is there a wattage restriction? Just wondering, and these are dirt cheap
:buell:
post #37 of 406 Old 07-28-2012, 05:37 AM
redline919's Avatar
Yes it you can fab a mount or get fork straps
post #38 of 406 Old 07-28-2012, 05:41 AM Thread Starter
StormSurfer
Whiplash97's Avatar
Sweet! I love home fab work
:buell:
post #39 of 406 Old 07-28-2012, 03:07 PM Thread Starter
StormSurfer
Whiplash97's Avatar
A little fancy foot work with the side grinder/tiger disc and the GIXXR is starting to bring sexy back!
I'll probably have to stop posting pics of it, otherwise PV and Goog will be wanting to hump the pipe!
:buell:
post #40 of 406 Old 07-28-2012, 03:18 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Can someone recommend a top quality flat black spray paint that will stand up to gas spills???? the Stixxr will be flat black and polished aluminum
Oh yes Stixxr, it's not really a GIXXR anymore, streetfighter + GIXXR = STIXXR
:buell:
