will stock lines allow 1" bar risers? - Wrist Twisters
post #1 of 8 Old 02-27-2012, 09:20 PM Thread Starter
Batman
velodesign's Avatar
Just want to know if anyone has stock bar + lines and run a 1" riser? I can't remember if I had asked this yet or not...
Thanks all.
velodesign is offline
post #2 of 8 Old 02-27-2012, 10:05 PM
no. 3/4 is about the max you can go and it will even limit how much you can tilt down the bars.
post #3 of 8 Old 02-27-2012, 10:27 PM Thread Starter
Batman
velodesign's Avatar
Thanks for the reply...although depressing kind of. I hate fussing with the brake system...too many things that could go seriously wrong for a simple minded mistake I always seem to make when wrenching.
Now not only will I be getting new springs for the front with new fork oil, I will need to do the lines at the same time...might as well upgrade to stainless all around then...and I hate bleeding brakes.
Then, its off to rise the bars a bit...
Thanks pv!
post #4 of 8 Old 02-28-2012, 03:12 AM
Hold on there... I have risers that lift the bars 1" up and 1" back, they worked with the stock brake lines, they were a bit snug but it worked.
post #5 of 8 Old 02-28-2012, 06:32 AM
Need money for parts.
ganktor's Avatar
I put the renthal mediums on my bike. A little clever rerouting of lines (didn't have to disconnect anything) and everything has enough play to go to both stops without putting weird tension on anything.
ganktor is offline
post #6 of 8 Old 02-28-2012, 06:54 AM Thread Starter
Batman
velodesign's Avatar
Hey rmb, define snug? I'm going to try just a riser that goes up 1", but not back an inch.
post #7 of 8 Old 02-28-2012, 07:30 AM
i guess i stand corrected then! i have 3/4 risers and could barely get them to work. couldnt tilt the bars down much due to the brake lines so maybe it was me that fucked up something lol.
i trust rmb, if he says he got it to work then you surely can.
post #8 of 8 Old 02-28-2012, 03:18 PM
I could move it (top line) a little, no problem turning the bars lock to lock.
