White spark plugs - Wrist Twisters
post #1 of 16 Old 06-08-2014, 11:51 AM Thread Starter
White spark plugs
Hello guys, today i inspected my spark plugs and i saw that electrod spark plugs have white color. This means that my mixture is poor?
I have 900RR headers and Tyga perfomance exhaust with oem air filter.
I am very concerned and i need help.
hookups is offline
post #2 of 16 Old 06-08-2014, 01:48 PM
Nickr919's Avatar
High heat or running lean, pictures of the plug?
Nickr919 is offline
post #3 of 16 Old 06-08-2014, 04:24 PM
yeah pics of the plug would be best.
if they truly are white you are running lean which is not good.
post #4 of 16 Old 06-08-2014, 07:15 PM
Chief 10 Beers
wgrady's Avatar
Hard to believe a 919 would run lean!
There are bold motorcyclists and old motorcyclists, but (OK) there are few old bold motorcyclists
wgrady is offline
post #5 of 16 Old 06-09-2014, 12:01 PM Thread Starter
hookups is offline
post #6 of 16 Old 06-09-2014, 12:16 PM
Hastatus Prior
TheBeeDeeGee's Avatar
Is that too lean? It looks to be what I thought was normal wear.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #7 of 16 Old 06-09-2014, 12:19 PM
Nickr919's Avatar
I think it should be a tiny bit more tan than that, but what your looking at isnt terrible or motor - threatening
Nickr919 is offline
post #8 of 16 Old 06-09-2014, 12:50 PM
Looks fine. Fuel injected motorcycles do not yield the same plug characteristics as conventional carbs do. For example you simply cannot do a plug chop in a fuel injected 4 stroke engine and expect to get accurate results like in the old days. Inspecting the plugs of a modern Fi motorcycle engine will only alert you to a problem of extreme nature.
post #9 of 16 Old 06-09-2014, 04:39 PM
TEXAN
MF1VE's Avatar
I remember doing plug chops on carbureted race cars. Those were the days.
MF1VE is offline
post #10 of 16 Old 06-11-2014, 11:32 AM Thread Starter
Thanks guys, now I can sleep peacefully))))))
hookups is offline
post #11 of 16 Old 06-28-2014, 12:55 AM Thread Starter
Hello again, I did a post about spark plugs, thinking that the problem is in them.
The problem is this, after warm up, the bike starts to move badly, appeared in the muffler claps, when closing the throttle in high speed sound like pur-pur-pur. But on a cold engine is no such problem. The FPR replaced 6000 km ago.
Also installed PAIR plates.
hookups is offline
post #12 of 16 Old 07-01-2014, 01:50 PM Thread Starter
Make a short video, please check the sound at low speed, seems fpr is dead. Am I right?
Low rpm bad perfomance - YouTube
hookups is offline
post #13 of 16 Old 07-01-2014, 02:26 PM
Sorry man, audio is WAY too low to hear anything...
You'll know if you have a bad FPR if the 2/3 header pipes are colder than 1/4.
post #14 of 16 Old 07-02-2014, 12:17 AM Thread Starter
Hello guys.
It is written in the description of the synchronization procedure in this forum
-remove vacuum hoses from throttle bodys 1 and 4
-remove the vacuum lines closest to center line of bike on 2 and 3 (the outer vacuum lines on 2 and 3 are tied to the fuel pressure regulator and should not be removed)
In the service manual on the picture shows that the FPR hoses route another
And I found on ebay two pics, 1st is 02' 919 and 2nd is 07
Which is right?
hookups is offline
post #15 of 16 Old 07-02-2014, 02:05 AM Thread Starter
Thanks, I will try to make another video.
hookups is offline
post #16 of 16 Old 07-02-2014, 08:31 AM Thread Starter
Today I checked the heating pipes, 2 and 3 as hot as 1, but is colder.
And I began to search problem.
Started the engine and disconnected a plug cap on 4th cyl. nothing happened.
I swapped plug wires with cap 1 and 4 cylinder - no changes
I swapped ignition coils 2/3 and 1/4 - no changes
I replaced spark plug - no changes
I think that the problem in fuel injector 4 cyl.
What do you think?
Low rpm bad perfomance #2 - YouTube
hookups is offline
