WHICH PLUGS FOR THE 919?? - Wrist Twisters
post #1 of 9 Old 06-20-2012, 01:58 PM Thread Starter
Oh, you didn't know?!
bkwildman's Avatar
I thought about changing my spark plugs when I do the block off plates. Which plugs are the top choice for the 919? Anybody......Anybody........
bkwildman is offline
post #2 of 9 Old 06-20-2012, 02:22 PM
I've ran a couple of different NGK's (both heat and type)...seat of the pants tells me, go with your cheaper option but stay in the right heat range (e.g. read the plug.)
post #3 of 9 Old 06-20-2012, 04:25 PM
Hastatus Prior
TheBeeDeeGee's Avatar
I should probably change mine too. Is it inspect or change at 16000 in the manual?
Sent from my DROID RAZR using Tapatalk 2
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #4 of 9 Old 06-20-2012, 05:55 PM
The manual says replace at 8K. I replaced mine at 8K and they looked brand new. I switched to replacing at 16K to coincide with valve clearance checks, because its so much easier to get to #3 with the valve over off and everything out of the way.
I have tried the standard NGK's and the Iriduims and didn't notice any difference. I am gonna stick with the standards for my 48K change within the next month.
post #5 of 9 Old 06-20-2012, 07:41 PM
What could happen?!...
Tackleberry's Avatar
I got some NGK Iriduims sitting im my closet waiting to get changed in a thousand miles.. Is there any disadvantage to using them? A mechanic friend suggested to sticking to the stock type, but I already got these... Whats your thoughts?
Tackleberry is offline
post #6 of 9 Old 06-20-2012, 08:19 PM
They will be fine. I had these Iridiums on my bike from 8K to 32K miles. Could have gone much farther.
post #7 of 9 Old 06-20-2012, 08:30 PM
Awesome. Thanks.
post #8 of 9 Old 06-21-2012, 06:13 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Got 21 K on my current set of stock plugs & running well.
ST-DocLizard1 is offline
post #9 of 9 Old 06-24-2012, 09:37 AM
24,300 on my stockers and still running good. I'll swap them at the 32 valve check and swap the coolant too.
Lemonhead is offline
