Which oil filter WRENCH do you use? - Wrist Twisters
post #1 of 37 Old 10-08-2014, 02:45 PM Thread Starter
Question Which oil filter WRENCH do you use?
No, this is not another oil thread!
Just wondering what style of oil filter WRENCH you all use on the 919?
I have tried several different styles with different results.
So, which do you use...
traditional,
strap,
cap style,
pliers style,
3 jaw style,
screwdriver through the filter,
other...
garyb900 is offline
post #2 of 37 Old 10-08-2014, 02:49 PM
I normally just use my hand
voodooridr is online now
post #3 of 37 Old 10-08-2014, 03:14 PM
"CERTIFIABLE"
Ken Phenix's Avatar
My method for decades:
  • Wrap a short strap around the filter
  • thread the ends of the strap through one end of a box-end wrench
  • put a big screwdriver through the other end of the wrench and
  • crank.
Ken Phenix is offline
post #4 of 37 Old 10-08-2014, 03:20 PM
TWSS
I use one like this...plier type I guess.
post #5 of 37 Old 10-08-2014, 03:31 PM
If it takes pliers or a wrench to get your filter off, calm the [email protected]$^ down when installing and don't forget to use fresh oil on the o-ring.
I do have a strap wrench for my Silverado, but only because I cannot get my hands around the filter.
post #6 of 37 Old 10-08-2014, 03:41 PM
I torque mine to 69 ft-lbs....if it's good enough for the rear axle it's good enough for the oil filter.
post #7 of 37 Old 10-08-2014, 03:41 PM
I found this one, works well and it was around $10 or so IIRC.
post #8 of 37 Old 10-08-2014, 04:24 PM
Total Awards: 17
I use a strap wrench which can be found for under $10. It is also useful for the bar end removal, lets you keep the bar from moving while its screw is being removed. One can use it to remove grips from handlebars.
zaq123 is offline
post #9 of 37 Old 10-08-2014, 05:12 PM
This-->
g26er is offline
post #10 of 37 Old 10-08-2014, 06:11 PM
I just use my hand as well... If it's my first change on the vehicle and the previous owner put it on too tight I'll just knock a screwdriver through the filter to twist it off
post #11 of 37 Old 10-08-2014, 06:30 PM
rpcraft's Avatar
I use the one at the end of my arm usually. If I can not turn it normally I have some of those gloves that have a rough rubber coating on them and that does the trick, Anything beyond that they I usually have one of those rubber strap units but I try to avoid using anything but the end because sometimes things can get damaged far too quick when you start using mechanical leverage.
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #12 of 37 Old 10-08-2014, 07:01 PM
^^This.
And it's only ever a hand-job after that.
[....on your marks....GO!]
K1w1Boy is offline
post #13 of 37 Old 10-08-2014, 08:17 PM
Hand tight has never done me wrong
post #14 of 37 Old 10-08-2014, 08:29 PM
hand tight on only.
to take off after a while sometimes ill need a big pair o pliers.
post #15 of 37 Old 10-09-2014, 03:55 AM
Honda919Rider #1
Well, if it's a Honda, I use the "Honda Oil Filter Tool"
I did have to take it to a Yamaha dealer to weld the nut back on, the original weld was technically "crappy"
Steve is offline
post #16 of 37 Old 10-10-2014, 05:43 AM Thread Starter
I was always taught to install it hand tight but then give it a 1/4 - 1/2 turn with a wrench.
I have never actually tried to remove it without a wrench. Maybe I'll give that a try next time.
Thanks for all your input guys!
garyb900 is offline
post #17 of 37 Old 10-10-2014, 10:31 AM
Honda919Rider #1
Honda torque spec's are 15-20 Nm, 11-14 ft/lb, and if you're only doing them by hand, you're possibly loosing significant horsepower.
I keep hearing so many of you talking about run issues, maybe it's just that you have not properly torqued your filter.
Odds are very, very slim that it has anything to do with anything.
Steve is offline
post #18 of 37 Old 10-10-2014, 10:55 AM
Are those numbers correct when using a synthetic torque wrench?
post #19 of 37 Old 10-10-2014, 11:14 AM
Only if it is additive free.
post #20 of 37 Old 10-10-2014, 12:03 PM
I put synthetic oil in mine. Where can I get this synthetic torque wrench. Is it smoother getting off.
Rotella wrench or Mobil 1?
sharkey is offline
post #21 of 37 Old 10-10-2014, 12:16 PM
Total Awards: 17
There is not such a thing as a synthetic torque wrench
zaq123 is offline
post #22 of 37 Old 10-10-2014, 12:23 PM
Damn you! I was getting ready to list one for sale in the classifieds.
post #23 of 37 Old 10-10-2014, 02:35 PM
post #24 of 37 Old 10-10-2014, 03:01 PM
Total Awards: 17
too soon. Sharkey didn't respond yet
zaq123 is offline
post #25 of 37 Old 10-11-2014, 07:18 PM
8mm socket and Craftsman ratchet. It's a KTM. Doesn't let oil run all over the header, BTW. Doesn't take any longer to do an oil change than a 919 does.
post #26 of 37 Old 10-12-2014, 04:19 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
TWSS
Same here for removal only. "Two hand tight" for installation with a lubed seal.
ST-DocLizard1 is offline
post #27 of 37 Old 10-12-2014, 05:45 AM
Yep. I also only put on hand tight, but they have a way of tightening up.
post #28 of 37 Old 10-12-2014, 06:03 AM
deandeib's Avatar
Hand job always works for me. On and off. Done
deandeib is offline
post #29 of 37 Old 10-12-2014, 06:16 AM
This thread is about oil filters
post #30 of 37 Old 10-12-2014, 06:37 AM
Honda919Rider #1
Steve is offline
post #31 of 37 Old 10-12-2014, 09:01 AM
Total Awards: 17
at least match the font so it looks legit
zaq123 is offline
post #32 of 37 Old 10-12-2014, 02:15 PM
Honda919Rider #1
Picky picky picky!
Steve is offline
post #33 of 37 Old 12-20-2014, 01:42 PM
I use the Wix Filter that take. A regular wrench or socket
farmboy555 is offline
post #34 of 37 Old 12-22-2014, 06:55 AM
Todi's Avatar
MIKE!!!!! 69 ft-lbs is not good for rear axle - it needs to be hand-torqued
Hand job on + an extra 1/4 turn. For taking it off, I use one of those rubber straps Amazon.com: Alltrade 070008 2 Piece Got Wrench Set (colors may vary): Home Improvement - what's good for jar lid works on oil filter too
Todi is offline
post #35 of 37 Old 12-22-2014, 10:11 AM
I tried hand torquing the rear axle, but it gave me too many callouses on my fingers, so I started using a wrench.
I have used a strap wrench on the filter too, but I like the pliers better. YMMV.
post #36 of 37 Old 12-22-2014, 04:38 PM
Total Awards: 17
Picky picky picky!
again????.... what have he done this time???
zaq123 is offline
post #37 of 37 Old 12-22-2014, 05:10 PM
Todi's Avatar
Like natural corn? Can we ask for a natural wrench for Christmas?
Todi is offline
