Weird Vibration - Wrist Twisters
 1Likes
  • 1 Post By nathanktm
post #1 of 11 Old 05-24-2016, 03:12 PM Thread Starter
nathanktm's Avatar
Weird Vibration
I changed my tires and my chain/sprockets(oem) in one go, and now I get a weird vibration. It's not so much of a buzz as it feels like someone doing a drum-roll on my handlebars. I feel the vibration between 60-70 mph, but only in 5th or 6th gear. The frequency of the vibration changes between these two gears. I feel roughly 8 taps per second in 5th, and like 2-3 times that in 6th. I feel it on acceleration, deceleration, but not with the clutch pulled in. No vibration in any other gear at the same speed or rev range. I'm at a loss. Maybe someone can help me figure out what this is?
nathanktm is offline
post #2 of 11 Old 05-24-2016, 03:38 PM
Check your chain tension, sounds like it might be too tight.
post #3 of 11 Old 05-24-2016, 04:41 PM Thread Starter
nathanktm's Avatar
http://puu.sh/p42TD/5d3cbdf81c.mp4
this is good...i think?
i went a little on the looser side since i'm going to a track this weekend, and last time i went they wanted it to be on the looser side.
I don't get why it's ONLY in 5/6th gear... if it was the chain, i figure i should feel it in any gear at the same speed, but I dont.
post #4 of 11 Old 05-24-2016, 04:55 PM
redline919's Avatar
Maybe the exhaust mount under the engine?
redline919 is offline
post #5 of 11 Old 05-24-2016, 04:59 PM Thread Starter
nathanktm's Avatar
nope, still intact surprisingly
post #6 of 11 Old 05-24-2016, 05:03 PM
redline919's Avatar
Over torque rear axle?
post #7 of 11 Old 05-24-2016, 05:10 PM Thread Starter
nathanktm's Avatar
that is a possibility. i'll back it off a bit and see what happens.
post #8 of 11 Old 05-24-2016, 06:00 PM
Canadian Blue
Mark919's Avatar
Good video - but IMO that looks to be too loose! What does it measure?
Mark919 is offline
post #9 of 11 Old 05-24-2016, 06:03 PM Thread Starter
nathanktm's Avatar
yeah i beat on it a bit since i put it on, it slacked up a bit. i'll take some slack out and re torque the rear axle, pretty sure its good though.
post #10 of 11 Old 05-28-2016, 08:24 PM Thread Starter
nathanktm's Avatar
it was an overtorqued rear axle. thanks! backed it off a bit and it went away. i woulda never thought of that.
beefsalad likes this.
post #11 of 11 Old 05-29-2016, 09:33 AM
Don't torque it to oem spec, it's still too high. Torque it anywhere from 54-58 ft lbs depending on when you start to get drag and you'll be good to go.
