Weird feeling when accelerating - Wrist Twisters
post #1 of 12 Old 06-30-2016, 07:58 PM Thread Starter
ewmin3m's Avatar
Hello All,
I feel a subtle clunk when I accelerate, when in gear or when I blip the throttle in neutral.
The clunk feels as if the front sprocket is loose on the shaft that it's on. I feel as if when I accelerate I feel it move a bit and then it catches if that makes sense.
Even when in neutral I feel the subtle clunk as well when I blip the throttle...
I'm just wondering if this sounds familiar and if it's something i should worry about...
Thanks,
sSmacKK
ewmin3m is offline
post #2 of 12 Old 07-01-2016, 01:41 AM
nathanktm's Avatar
does it make a noise? if so, a video would be just dandy if not too much to ask for
nathanktm is online now
post #3 of 12 Old 07-07-2016, 10:38 PM
Check to see if your chain is loose.
post #4 of 12 Old 07-15-2016, 09:57 AM Thread Starter
ewmin3m's Avatar
I think it was the chain because it greatly reduced this behaviour...
I'll keep an ear to it.
ewmin3m is offline
post #5 of 12 Old 07-24-2016, 07:30 PM
Not so Rookie Anymore
stiggy8's Avatar
Definitely check the chain and/or your sprockets... Had a similar experience and it was a worn rear sprocket.
Temecula, CA (So Cal)
06-919
Pass it on.
stiggy8 is offline
post #6 of 12 Old 07-25-2016, 11:32 AM Thread Starter
ewmin3m's Avatar
Yup. It's what it is. I also noticed a very very small play in the rear sprocket and the teeth are starting to get quite pointy too.
None the less I ordered the 17/44 kit from LDH, because I don't know how long and how well the chain/sprockets have been taken care of so I figured i'd upgrade and i'll keep track and good maintenance while I own the bike.
ewmin3m is offline
post #7 of 12 Old 07-25-2016, 08:29 PM
You'll like the new chain and sprockets. Money well spent. The bike will be smoother and quieter.
I like that blue. I wish the US would have gotten that color.
Sniper-x is offline
post #8 of 12 Old 07-25-2016, 09:05 PM Thread Starter
ewmin3m's Avatar
Yup I can't wait.
Yes, i thought I'd never like any colour as much as I liked the red but... This blue looks great... Especially on a nice bright day.
ewmin3m is offline
post #9 of 12 Old 07-30-2016, 02:41 PM Thread Starter
ewmin3m's Avatar
Got the new chain and sprockets installed... It's feels like this is how it should've been from the factory.
Turns out that my rear wheel bearings are a bit lose. Also I think the rubber things inside the wheel that the rear sprocket sits on seems a bit loose. So I'm guess that + bushings makes the weird feeling.
But then again this isn't really a race bike so maybe my expectations of it being tight are a bit too high...
Now that the drive train + gearing had been solved time to move to the suspension :-D
ewmin3m is offline
post #10 of 12 Old 07-30-2016, 07:49 PM
redline919's Avatar
Nice work. Glad you narrowed it down. For what it's worth. I had to replace my rear wheel bearings and those rubber cush drive pieces on my 919. They were completely shot at roughly 25K. I could feel the bearings under hard acceleration and upon braking. It was not a good feeling. Also the sprocket carrier sat loosely in place with the old rubber bushings. Since I replaced them it doesn't budge by hand. If anything I would replace those bearings asap if you suspect them being worn just to be safe for now if you are able to.
redline919 is offline
post #11 of 12 Old 07-30-2016, 11:24 PM Thread Starter
ewmin3m's Avatar
Thanks for the tips. I'll definitely change both bearings and the cush drive pieces...
It seems quite the pattern that the rear bearings on this bike wear out fast. I'm wondering if its because of the stock gearing which promotes higher torque and therefore higher strain on the rear wheel?
ewmin3m is offline
post #12 of 12 Old 08-11-2016, 11:57 PM Thread Starter
ewmin3m's Avatar
A quick update. Just had my rear bearings and cush drive replaced...and it was definitely the issue it's all smooth as butter and with the new 17/44 gearing and chain bine runs like a dream
ewmin3m is offline
