Water-pump replacement - Wrist Twisters
post #1 of 2 Old 09-12-2016, 03:19 PM Thread Starter
Ive got the dreaded leaking-from-the-weephole waterpump. Replacement unit on the way. Did some reading and it sounds like it should be plug-and-play when swapping out the old unit. Can anyone whos done the swap-out chime in in terms of what o-rings/gaskets are needed when replacing? Thanks!
honda ng gingsa is offline
post #2 of 2 Old 09-12-2016, 06:08 PM
It's been a few years, but it was SUPER easy. 3 or 4 bolts if I remember right. Took me longer to purge the system then it did to swap it out. I think the pump came with all the needed gaskets.
PAULIBIKER is offline
