Water in the tank after rain. How to clean drain passage. - Wrist Twisters
post #1 of 2 Old 12-08-2013, 07:29 PM Thread Starter
I went to fill up, opened the gas cap and there was water around the edge from the rain. I used a few paper towels to get the water out, but a bit did get into the tank. I thought there was some kinda drain passage there.
Is there a passage and does it have a hose somewhere? Is there a certain way to clean it out? Maybe a welding wire or run air or carb cleaner?
post #2 of 2 Old 12-08-2013, 08:48 PM
I would throw some seafoam / marine Stabil in the tank... and top her off and you will be fine.
IT SHOULD drain, but lots of times the overflow / drain tube for around the cap can get pinched. It comes out just below the throttle side foot peg.
