vibration in guage panel - Wrist Twisters
post #1 of 3 Old 11-12-2013, 04:14 PM Thread Starter
Just joined this site. And need some thought on a vibrating guage panel on my 919. It starts and stops between 70 and 90 klm. Cheers.
Nobba is offline
post #2 of 3 Old 11-12-2013, 04:21 PM
Welcome!
Check for the rubber stops that connect it to the harness in between the forks and upper triple clamp.
If those are gone it vibrates like a mofo.
post #3 of 3 Old 11-12-2013, 04:23 PM
The gauges have four rubber isolated mounts, two under the triple and two on the headlight bracket all the hardware is in place, check to make sure they are all snug.
It could also be a vibration from contact, make sure its not hard up against the triple, headlight or windscreen if you have one.
