Turn Signal Problem - Wrist Twisters
post #1 of 5 Old 10-21-2012, 03:37 PM Thread Starter
mikero's Avatar
Turn Signal Problem
My left turn signal works when I hold the switch to the left and only intermittenly when I let go of the switch. In other words,most of the time I have to keep my finger on the switch for the signal to work. The right works normally. Any ideas?
mikero is offline
post #2 of 5 Old 10-21-2012, 03:50 PM
StormSurfer
Whiplash97's Avatar
Think they both use the same blinker relay(but not sure) so thinkin it's the switch, open it up, soak with WD-40 then blast with air, repeat if needed
I've done this with ALOT of atv's and it usually works pretty good, maybe it work for you
:buell:
Whiplash97 is offline
post #3 of 5 Old 10-21-2012, 04:51 PM
Yup, switch sadly. You'll have to open it up and look for any breaks/loose connections. Clean it out as well and reassemble.
post #4 of 5 Old 10-21-2012, 05:13 PM
If I remember correctly, the switch for left and right is one piece that makes connection on each side when you slide it over. The screw holding that piece down could be loose or the left contact could be off. Nothing too complicated just need to dig into it.
Take note on how it all goes back together should you fully disassemble it.
post #5 of 5 Old 10-22-2012, 08:10 AM Thread Starter
mikero's Avatar
Problem seems to have corrected itself. The signal works every time now. We shall see.
Thanks to all
Mikero
mikero is offline
