To filter or not to filter, that is the question... - Wrist Twisters
post #1 of 6 Old 03-25-2012, 04:14 AM Thread Starter
So I have a 1982 Honda Sabre with the Vf750 and I can't find a mention either in the Clymer manual or any online parts lists for a fuel filter. I know the tank is getting old and whether its rust or other stuff, I feel like I'd like to filter the fuel. Problem is its a gravity feed system and I don't want to restrict the flow too much. Anybody put an inline fuel filter on a gravity feed system like this? Any suggestions?
Thanks
pemc621 is offline
post #2 of 6 Old 03-25-2012, 04:33 AM
Total Awards: 17
isn't filter/fuel screen is a part of petcock on those?
zaq123 is offline
post #3 of 6 Old 03-25-2012, 06:09 AM
No filter on those. Just rebuild your petcock valve and you should be good. However, if you do want a filter put it inline AFTER it goes into the petcock and before it goes into the Carbs.
07919Dave is offline
post #4 of 6 Old 03-25-2012, 06:37 AM
TEXAN
MF1VE's Avatar
I've had an inline filter on a couple of bikes. The filter was where Dave said it should be, and it worked well for me.
MF1VE is offline
post #5 of 6 Old 03-25-2012, 08:53 AM
post #6 of 6 Old 03-25-2012, 10:56 AM
lusting over something...
james_kraska's Avatar
I have a few older bikes, and just as stated above, I use a small engine fuel filter that can be opened up and have the filter medium changed out. They're usually about $4, and since they're translucent, you can see how red/brown the filter gets and change it as need be.
james_kraska is offline
