Tire Change - Wrist Twisters
post #1 of 27 Old 07-25-2009, 08:12 AM Thread Starter
Tire Change
I did my 3rd rear tire change this morning. Put on another Pirelli Diablo Strada. Seems to get a little easier everytime. Snapped a few pics along the way.
A few tools laid out. Valve stem tool, tire irons, rim protectors made from large yogurt containers, torque wrench and sockets for the rear axle, and a 19X19 box that I built to keep the underside (rotors) from damage.
Sprocket and bumpers removed
My ghetto bead breaker (under the deck)
First bead over the rim using tire irons and rim protectors, the second one is easy.
New tire ready to go on. The first bead goes right over with a little lube. I used pledge furniture polish to lubricate the beads on the tire.
First bead on
Second bead on. This one takes a lil more effort
Tire inflated and on my homemade balancer. Made from a couple of jackstands, bearings, and an aluminum rod.
Cleaned the chain with mineral spirits and the inside of the swingarm that gets all gunked up with chain lube and dirt
Mounted up chain adjusted, torqued and ready to roll
Took me bout an hour and half, but I like working on my own bike.
post #2 of 27 Old 07-25-2009, 08:38 AM
3dcycle's Avatar
i will try to snap a few pics of my tire setup, not like yours but it works.
3dcycle is offline
post #3 of 27 Old 07-25-2009, 08:42 AM
xlent bead breaker...I will be using it
madmatt is offline
post #4 of 27 Old 07-25-2009, 09:32 AM
AMA U'RA
MONK's Avatar
Nice setup..... Only two things I'd probably do differently....Use soap instead of furniture polish...... and put the jack stands closer together on the balancer.... That's a real nice thinking man's set-up... way to go...
Monk
Riding defensively is a pro-active must.VFR MOD's : GripPuppies;ThrottleBoss;NepThottlelock;LowCutBra; BubbleMirrors;HondaBags;GPS TomTom2ndEd(Powered,W/Tightwad'sPowerletSystem);SargentSeat w/silver piping;StockWindscreenW/LaminarLip;
3-M BlackReflectiveTape;FirstGearSilverMiniTankBag;Gez aHalfCover;AxioSilverHardshellTailbag;
HeldSpeedySeatBag;KuryakynLEDBatteryGauge;TyresMic hPR2's;NWS Hugger;RedWheelTape;RedRadiatorGrill.
MONK is offline
post #5 of 27 Old 07-25-2009, 09:33 AM
919>food>beer
Jeef's Avatar
nice set up, really wish I had a garage where I could do my own, I hate paying for someone to do it for me!
Jeef is offline
post #6 of 27 Old 07-25-2009, 10:15 AM Thread Starter
Cool I'd like to see it. I saw a few vids on youtube on how to change a motorcycle tire and adapted my setup to those.
Its cheap and easy. I bolted a pipe nipple to my deck post, and just take the elbow, pipe and angled off 2X4 outside to use it. Works really good.
Thanks Monk. I usually use soapy water to lube the beads, but I had heard that pledge works pretty good, and it did. Good call on the jack stands, I got lazy.
Me too. The best part is I can do it whenever I want and not have to sit an wait at the dealer.
post #7 of 27 Old 07-25-2009, 10:25 AM
AMA U'RA
MONK's Avatar
It probably does work better..... I was thinking about tyre slippage on the rim while riding.... but if you've used it before with no problem that you know of, my worries may have been in vain.... But I will steal a few ideas from you.... Thx
Monk
MONK is offline
post #8 of 27 Old 07-25-2009, 02:55 PM
Trackday Recognition Donation
nice job dude!
not that long ago, I could get tires mounted and balanced at the local Yam dealer for $12 each. At that price, it wasn't worth breaking a sweat but now all three dealers near me charge $80+ per pair! For 15 minutes of labor.
When a friend recently decided he was no longer going to ride the CO 500 after doing it 30 yrs in a row, I snagged his Coats 220 dirt cheap (to the right of the Bandito) and will try it out next week for the 1st time.
gpzTurbo is offline
post #9 of 27 Old 07-25-2009, 03:09 PM
3dcycle's Avatar
those are good machines, take your time with it and soon you will be doing everyones tires for 50 bucks making a little money and saving everyone else a arse load of money.
3dcycle is offline
post #10 of 27 Old 07-25-2009, 04:33 PM Thread Starter
Originally Posted by gpzTurbo View Post
nice job dude!
Thanks gpz. I bet that Coates machine will make quick work of the job. Let us know how it works. I thought about trying out a simple tire changing machine, but didnt really have a good spot to put it. Seemed like you would have to bolt it to the floor.
Good luck with the Coates
post #11 of 27 Old 07-25-2009, 05:11 PM
Self proclaimed idiot....
Border's Avatar
Wow, I love the "ghetto" approach. I was thinking about how difficult it would be, and it really doesn't appear to be that bad.
Thanks for the info Mike.
Border is offline
post #12 of 27 Old 07-26-2009, 04:07 AM
He guys.. Has anyone seen this unit in person?
Tire Changer for Motorcycles and More
It looks like a pretty compact unit and takes up very little foot print, just a bit pricey
CB900F2 is offline
post #13 of 27 Old 07-26-2009, 04:21 AM Thread Starter
You're welcome. I had the same thought, but my local installers prices are anywhere from $50-$75 to install a rear tire. If you're interested, these three vids are pretty good. He's teaching a group how to do it, so he goes really slow and shows how to do it. It's not the easiest thing I've ever done, but it's not bad.
Tire removal
Tire Install
Balancing
post #14 of 27 Old 07-26-2009, 06:41 AM
Mike, very nice ... I like the ingenuity! I'm lazy when it comes to road tires ... Cycle Gear does it for cheap. Remove, mount and balance ... $40.
I stick with the easier dirt or DP tires for DIY.
RC51_CBRXX is offline
post #15 of 27 Old 07-26-2009, 06:56 AM
dr1
dr1
dr1's Avatar
I did it myself for the first time a month or two ago.. wasnt bad but I didnt have a fancy bead breaker. I ended up using this c-clamp type thing. I didnt even kill the tire which is good because I had to put it back on. After I patched it, I had it back on the rim in 5 minutes. I used an antifreeze jug for my rim protectors. And I "balanced" it on the bike with just the axle in and no chain or brakes on. lol. Its good 'nuff. Been to 100 many times already :P
dr1 is offline
post #16 of 27 Old 07-26-2009, 07:16 AM
AMA U'RA
MONK's Avatar
This thread got me looking around, and for you guys(and me) that are concerned with having a place to bolt it to the floor, due to lack of room.
I found that a lot of peps just put female concrete plugs in the floor(4 usually), and just bolt it down when needed. Just a thought..... I bookmarked this T-changer, I'm going to keep an eye out. Right now I'm only paying $26.50 a wheel, with me taking the wheel off the bike.. But the way things are going, it wouldn't surprise if it goes up.
I bought a balancer due to no one being able to balance my rear wheel(because of the singlesided swingarm). So I got one with an adapter for my VFR, from HF...
Monk
MONK is offline
post #17 of 27 Old 07-26-2009, 08:28 AM
Yes, it's gotta be bolted down. I'm lucky to share an xtra large shop with my bro in law. Compressors, pneumatic tools, bike lift, and now a tire changer.
Had I not come across my friend's Coates, the NoMar is probably the one I would've chosen.
gpzTurbo is offline
post #18 of 27 Old 07-27-2009, 04:03 AM Thread Starter
Thanks man. I wish I had a Cycle Gear...closest ones are in Delaware or Virginia Beach. All I have are motorcycle dealers around me.
post #19 of 27 Old 07-27-2009, 04:29 AM
Thanks man. I wish I had a Cycle Gear...closest ones are in Deleware or Virginia Beach. All I have are motorcycle dealers around me.
Yeah.... DOn't knwo anyone down here you could visit with while a cycle gear... And it is in Norfolk, not Virginia Beach. You old guys.....
post #20 of 27 Old 07-27-2009, 04:38 AM
McCrimmon's Avatar
Cool set up Mike...I cheat though, I get to use one of these at work
2008 Yamaha FZ1-Street
2005 Honda CBR 600rr-Track
McCrimmon is offline
post #21 of 27 Old 07-27-2009, 05:18 AM
screw the tire changer... we need more pics of that sweetass honda mower back there! As I'm sure that I have its twin in my garage!!!
Ripper is offline
post #22 of 27 Old 07-31-2009, 10:04 AM
BrokeRecord
If my Tire dealer ever charges me over $10 for the pair I buy from him, then I'm gonna build me one too!
brokerecord is offline
post #23 of 27 Old 10-05-2009, 08:17 PM
Survivor/Broken&Busted
yostevo052's Avatar
Community Service Veteran
imma have to start doin this too... 80 bucKs a tire here is prolly the cheapest you'll find:/
yostevo052 is offline
post #24 of 27 Old 10-05-2009, 08:24 PM
That's Right!!!
BMiller's Avatar
That's crazy! Even if you bring them the bike here........I bring my wheels/tires in and they charge me like $30-40 locally for both.
2003 Honda RC51
BMiller is offline
post #25 of 27 Old 10-07-2009, 04:27 PM
Madmotor's Avatar
Questions from a first timer
Getting ready to do my first tire change this weekend. Changing the stock rear out for a Dunlop Roadsmart and I had a few questions for Mike and others that have done this before:
Mike - Why remove the sprocket etc? Is it for clearance for your tire tools?
I plan to install Dyna beads in the new tire. With the Dyna beads in I should be able to remove the stock wheel weights, right?
I thought I read somewhere that there is a paint mark on the tire that is supposed to be lined up with the valve stem or opposite the valve stem. Any idea?
Thanks in advance,
Madmotor
'06 919
Madmotor is offline
post #26 of 27 Old 10-07-2009, 05:22 PM
Thanks in advance,
Madmotor
'06 919
yes remove the stock weights...
yes line the paint spot up with the valve stem as accurately as possible..
and the sprocket does not necessarily have to come off but it makes life a little easier to remove/install tires with the sprocket removed...
hope this helped..
post #27 of 27 Old 10-07-2009, 08:31 PM Thread Starter
Thanks in advance,
Madmotor
'06 919
I haven't tried the dynabead route yet, but I would agree with Barton that the wheel weights should come off.
I have used Pirelli's and never could really find the paint spot. I'm not sure it matters too much.
With the sprocket, there's nothing really to unbolt, the whole assembly just pulls off. Keeps it from falling out when you flip the tire over and stuff. Good luck and be patient.
