throttle position sensor - Wrist Twisters
post #1 of 13 Old 04-30-2011, 02:27 PM Thread Starter
mpcb04919's Avatar
Does anyone know if the throttle position sensor can be replaced and if so how? My son yanked on the wire and one of the male connectors broke off. Uhhgh!
mpcb04919 is offline
post #2 of 13 Old 04-30-2011, 02:34 PM
I'm not 100% sure but I think it's only available as part of the complete throttle body assy.
post #3 of 13 Old 04-30-2011, 02:37 PM
That's bad news! The worse news is that the TPS itself is not sold separately, and is part of the throttle body assembly...$$$ (edit: RMB beat me to it, and he is correct!)
Is it possible to fix the connector, or reattach the broken wire?
post #4 of 13 Old 04-30-2011, 03:52 PM
Is the sensor body broken? If not it should be an easy job to remove the pin from the connector and solder the wire back on to it. If so, read on.
Honda should be ashamed of the fragility of that sensor, especially since it's right out there in front of god and everybody just waiting to be broken. The reason why is it is the same as the automotive units Honda has been using for at least 15 years, though it rotates in the opposite direction (it figures!).
It is repairable with some microsurgery to the housing to expose the metal of the intermediate contacts. Not easy, but considering the cost of it's replacement (with a throttle body attached to it) it is definitely worth a try. If I was doing it I would attach wires to it and place a connector in a more protected spot as well. Another thing you should consider doing is to involve your son in the repair to demonstrate the consequences of his actions and probably prevent a repeat performance. That will also either clean up your vocabulary ... or extend your son's depending on how "cleaned up" your vocabulary is or isn't!
Good luck.
post #5 of 13 Old 05-03-2011, 03:16 PM Thread Starter
mpcb04919's Avatar
So this is what happened. I have a soldering gun and am ready to try it. As far as involving my 1 1/2 year old son is not a good idea. Yes he is 1 1/2. He can speak about 10 words but he knows around 30-50. He knows somewhat right from wrong and the phrase like "don't touch" or "that's not ours". My fault was not keeping an eye on him while being busy with my own work.
post #6 of 13 Old 05-03-2011, 03:20 PM
Good luck!
post #7 of 13 Old 05-04-2011, 01:52 AM
Ah kids. Daddy is playing with his motorcycle so I will too!
Mind you I've seen qualified mechanics do just as bad!
post #8 of 13 Old 05-04-2011, 10:16 AM
u should be alright, worst case, you cut off the other 2 pins, solder 3 wires up to the stubs of all 3, and connect to the original harness with some splices.
TBH never understood why the bike has 2 TPS's... both sets of throttle bodies are rotated by the same thing.
I wonder if you could just split the 3 wires off the good one to both sets of plugs to fool the ecu into thinking there are 2 TPS's.
post #9 of 13 Old 05-09-2011, 04:56 PM
Tikhon's Avatar
Let me know if this works or not... My TPS also was broken when I laid it down--not badly, but badly enough to break the housing a little and disconnect it from the sensor.
Tikhon is offline
post #10 of 13 Old 05-13-2011, 04:44 AM
Tikhon's Avatar
I was inspired by you guys and did a little soldering job on my TBS... Essentially, I took a dremmel tool and cut away the plastic that was broken and exposed the good metal that was left. I then soldered wires to the connectors on the throttle body and then soldered the wires to the plug. I turned it on to see if it worked or not... and SUCCESS!! Now I just need to make it pretty and tuck it all away...
Tikhon is offline
post #11 of 13 Old 05-13-2011, 06:08 AM
Survivor/Broken&Busted
yostevo052's Avatar
Community Service Veteran
Great job !!! ......
yostevo052 is offline
post #12 of 13 Old 05-13-2011, 10:29 AM
Congrats!
post #13 of 13 Old 05-14-2011, 06:11 PM
Tikhon's Avatar
It was extremely satisfying to have it start right up, have no lag when I opened her up a bit, and have no flashing FI light!
Tikhon is offline
