Thinking about flush mounts - Wrist Twisters
post #1 of 5 Old 11-07-2008, 06:21 PM Thread Starter
goldilocks919's Avatar
So i've been thinking about putting a set of flush mount turn signals on to replace the stock front turn signals. However, i made my own fender eliminator using tail light integrator instead of the rear blinkers, which causes the blinker to blink faster. It says that the integrator will not work with LED tail lights. Is this also true for LED blinkers?
goldilocks919 is offline
post #2 of 5 Old 11-07-2008, 06:34 PM
Been done before, actually I did it and ended up taking them off.
Here is the thread with Pictures for you. https://www.wristtwisters.com/forum/s...t=turn+signals
Ripper is offline
post #3 of 5 Old 11-07-2008, 06:48 PM Thread Starter
ya i read that some people had already done it and taken them off because of visibility, i was just curious about the integrator issue, thanks
post #4 of 5 Old 11-07-2008, 06:56 PM
So you installed an integrator and not the Clear Alternative integrated LED light? I think I understand what your asking and a good question it is... Wish I could help. I think Mr. Mike would be the one to answer this for you.
Ripper is offline
post #5 of 5 Old 11-07-2008, 07:03 PM Thread Starter
ya, it's basically a trailor wiring harness, nothing else done to the tail light, removed the entire rear fender, made my own license plate bracket from sheet metal, and used a small LED for a license plate light, just don't like the stock look of the front end. thanks for the help
