Testing the voltage regulator/rectifier - Wrist Twisters
post #1 of 36 Old 10-29-2013, 11:37 AM Thread Starter
Yo no s nada
spyke1019's Avatar
2000 Honda Shadow750 Ace Deluxe(750CD2)
OK so my battery does not charge, I have tested the stator and it is fine. I get correct readings between all three pins and the readings increase with the throttle.
How do I check the R/R, I have the manual but it is not a help in checking the R/R, just changing it out.
spyke1019 is offline
post #2 of 36 Old 10-29-2013, 11:56 AM Thread Starter
Yo no s nada
spyke1019's Avatar
Followin this diagram I should be getting a voltage reading between the red/white cable and the green cable(coming out of the r/r) on my multimeter correct?
Attachment 36738
post #3 of 36 Old 10-29-2013, 12:54 PM
I had done the same thing a few years back on a CBR 900RR. New battery and I tested the stator. Everything checked out. Battery would still die after about 30 miles. Replaced the reg./rect. to no avail. Turns out it was the stator. I would remove the cover and check it for burning.
post #4 of 36 Old 10-29-2013, 01:12 PM Thread Starter
Yo no s nada
spyke1019's Avatar
That sucks, I really didn't want to pull that cover off.
post #5 of 36 Old 10-29-2013, 01:51 PM
Not sure about the shadow but some models don't even need a new gasket afterwards. Open it up, inspect and close it back up if it looks good. Even if you need a gasket, it's way cheaper than a R/R.
post #6 of 36 Old 10-29-2013, 02:42 PM Thread Starter
Yo no s nada
spyke1019's Avatar
I just tested the battery and I'm getting 25.9V, I don't think that's normal
post #7 of 36 Old 10-29-2013, 03:04 PM
Yea, not really normal.... Is that with the bike running? Do you have your meter set to DC voltage?
post #8 of 36 Old 10-29-2013, 04:40 PM Thread Starter
Yo no s nada
spyke1019's Avatar
That's off, running it goes up to 26.8v. I'm not 100% on the setting, I'll take a pic when I get home, just left the gym.
post #9 of 36 Old 10-29-2013, 04:57 PM Thread Starter
Yo no s nada
spyke1019's Avatar
This is the setting I am using, is it correct?
post #10 of 36 Old 10-29-2013, 04:59 PM
Attachment 36762
Nope, should be set on the 20V DC setting. It's probably set up for measuring house voltage.
marylandmike is online now
post #11 of 36 Old 10-29-2013, 05:02 PM Thread Starter
Yo no s nada
spyke1019's Avatar
Ok that's the setting I was using to measure the stator. I wasn't sure about it for checking the battery
post #12 of 36 Old 10-29-2013, 05:04 PM Thread Starter
Yo no s nada
spyke1019's Avatar
Should it be set here?
post #13 of 36 Old 10-29-2013, 05:07 PM
Yep that's right for measuring the DC voltage at the battery.
post #14 of 36 Old 10-29-2013, 05:13 PM Thread Starter
Yo no s nada
spyke1019's Avatar
Okay so I fix the setting and I got 13.2 with the bike off. when I started it up it went down to 10.9 with throttle. When I turned the bike off again and check with ignition off it went down to 12.1.
post #15 of 36 Old 10-29-2013, 05:27 PM
Definitely not right. The voltage with throttle should go up to somewhere between your battery voltage with the bike off and 15V or so.
Did the battery start the bike easily? If so I would suspect the stator or regulator/ rectifier
post #16 of 36 Old 10-29-2013, 05:39 PM Thread Starter
Yo no s nada
spyke1019's Avatar
I just took it off the charger. It died on my way to work yesterday, I noticed that the headlight does not get brighter when I downshift also,
post #17 of 36 Old 10-29-2013, 05:46 PM
The next test is to measure the resistance of the stator windings. To do this set the meter on the lowest resistance setting, unplug the three pin heavy gauge connector between the stator and the regulator / rectifier, and check the continuity of the three pins to each other and to ground. It should be a quite low reading between the pins, no more than 15 ohms or so and relatively equal, and no continuity at all to ground (use the 2,000 ohm scale for this check). If the readings are substantially different or it shows any resistance to ground the stator is bad and will have to be replaced. Otherwise the R/R is probably the problem. Of course check all connectors for burning or other evidence of distress.
robtharalson is online now
post #18 of 36 Old 10-29-2013, 05:49 PM Thread Starter
Yo no s nada
spyke1019's Avatar
I already did this exact thing, the three were reading between 12.2 to 13.9 at idle. Got up to 35.9 with throttle. No continuity.
post #19 of 36 Old 10-29-2013, 05:51 PM Thread Starter
Yo no s nada
spyke1019's Avatar
But I had it set up like the first picture. Is that ok?
post #20 of 36 Old 10-29-2013, 05:54 PM
The readings that Rob is talking about is without the bike running. Just checking the resistance of the stator coils. Use the lowest setting in the gray section (lower left) on your meter.
post #21 of 36 Old 10-29-2013, 06:51 PM Thread Starter
Yo no s nada
spyke1019's Avatar
Using the lowest setting in grey on my meter for 200 ohms I got a 1.2 across the board. And no continuity on all three pens. Ignition was off.
post #22 of 36 Old 10-29-2013, 06:53 PM Thread Starter
Yo no s nada
spyke1019's Avatar
I cleaned the leads and got a 00.1 all the way across
post #23 of 36 Old 10-29-2013, 07:04 PM
Sounds like the readings indicate that your stator is OK. Just to make sure, I would get your battery load tested.
post #24 of 36 Old 10-29-2013, 07:07 PM Thread Starter
Yo no s nada
spyke1019's Avatar
You mean a leak down test?
Edit: ok LOAD test, taking it off and to the auto parts store, correct?
post #25 of 36 Old 10-29-2013, 07:17 PM
Most auto parts stores will do it for free. It measures how low the voltage drops when a load is put on it. You can also do it with the battery on the bike and measure how low the voltage drops when you start the bike, but you would need a meter with would store the max and min readings. With a digital meter it would be really hard to do by just watching the numbers.
post #26 of 36 Old 10-29-2013, 07:40 PM Thread Starter
Yo no s nada
spyke1019's Avatar
I don't think it's the battery. While I rode it, the headlight did not get brighter when I downshift. It normally does.
post #27 of 36 Old 10-30-2013, 05:06 AM
Is this the small R/R, about the size of a matchbox?
post #28 of 36 Old 10-30-2013, 05:11 AM Thread Starter
Yo no s nada
spyke1019's Avatar
No it's bigger.
post #29 of 36 Old 10-30-2013, 05:13 AM Thread Starter
Yo no s nada
spyke1019's Avatar
I wear an Xl glove
post #30 of 36 Old 10-30-2013, 05:32 AM
I had the same problem on my old CB750F - turned out it was bad Stator coil. From what I remember the coil passed the continuity test, but visually looking at it some of the "gunk" coating the coils was cracked and crumbling off. I got one off of ebay for 25$ and it fixed it.
This article has some very good troubleshooting tips:
Dan's Motorcycle
eightball is offline
post #31 of 36 Old 10-30-2013, 08:51 AM
Dan's Motorcycle
Exactly what I was saying earlier. Passing the tests doesn't always prove anything.
post #32 of 36 Old 10-30-2013, 09:11 AM Thread Starter
Yo no s nada
spyke1019's Avatar
I got a 3.4v drop.
post #33 of 36 Old 10-30-2013, 09:26 AM
Brain stolen again?
Rob is telling you to do a "static resistance check" of an item, open circuit.
If you were doing the test with the engine idling, you are not doing the same test.
Reread his suggestion including unplugging the connector, then go back through it with the engine off and the ignition off and meter in the suggested resistance check ranges.
Good luck amigo.
Mathew Quigley
Bigdaa is online now
post #34 of 36 Old 10-30-2013, 09:29 AM Thread Starter
Yo no s nada
spyke1019's Avatar
Good luck amigo.
Results
post #35 of 36 Old 10-30-2013, 09:35 AM
Brain stolen again?
My mistake.
note to self..........................finish reading posts before "gobbing"
Mathew Quigley
post #36 of 36 Old 10-30-2013, 02:32 PM
Yeah, that's the matchbox r/r. A whole bunch of makes and bikes got screwed by that design in the 80s and 90s, which is why later r/r's are significantly larger and include cooling fins. To put that in perspective - the 919's r/r is about the size of an iPhone, is in an area that gets lots of air flow and has prominent cooling fins. My 700's is about the size of a small paperback book and is similarly finned and placed. Yours is not finned and not very large so it has little surface area for cooling.
The VFR guys are particularly affected by the problem due to where the matchbox is mounted on their machines, so they have the most institutional knowledge about it. Info below:
VFR Regulator/Rectifier Failure
Honda VFR 750 Regulator / Rectifier
How to fix common regulator/Stator failures
Bottom line: Pitch the matchbox and install a later Yamaha R1 or upgraded aftermarket R/R.
