Tachometer not working - Wrist Twisters
post #1 of 29 Old 02-04-2014, 09:42 PM Thread Starter
loudcity919's Avatar
Took all of my parts to get powdercoated and now have everything put back together, but my tachometer/speedometer won't register. The light comes on, and everything has been plugged in and replugged in. Any ideas?
loudcity919 is offline
post #2 of 29 Old 02-05-2014, 05:27 AM
It has to be a bad connection somewhere, re-check all connections for any corrosion on the contacts, maybe add some dielectric grease.
post #3 of 29 Old 02-05-2014, 08:15 AM
Dielectric grease is not conductive. Adding it to the equation will not help.
Iirc power/lights are fed from the black connector, signals come.in on the white connector.
post #4 of 29 Old 02-05-2014, 10:09 AM Thread Starter
I checked all of the connectors and they're perfectly clear. So should I be looking at the white connections?
post #5 of 29 Old 02-05-2014, 10:11 AM
If you looked at all of them, you would have looked at the white connector already. I'm wondering if somehow they didn't unplug inside the gauges.
post #6 of 29 Old 02-05-2014, 12:45 PM
It could have a short somewhere. I bought my 9 wrecked and the guages sometimes wont work and my temp is in the red. I smack it then the rpm and temp drops as to corects itself but the speedo doesnt work until i push on the guages then everything works.
My 9 is my daily...driver and carry.
Fighter9nr is offline
post #7 of 29 Old 02-05-2014, 12:57 PM Thread Starter
I took the back of the speedo off and everything was connected correctly. When you turn the bike on, the rpm won't register (when it jumps from 0-9rpm). I planned on buying Koso gauges soon, so I wonder if that would fix the problem. It seems like something's wrong with the gauges and not the wiring.
post #8 of 29 Old 02-05-2014, 02:23 PM
Are the gauges sweeping when you first turn the bike on?
If you buy the kosos, send me your old ones... would love to try and resurrect the set I have but kinda need that really 'spensive part.
post #9 of 29 Old 02-05-2014, 02:32 PM
Cloroxbleach4's Avatar
I may or may not be contemplating selling my koso gauges and going back to stock. Constantly going back and forth.
Cloroxbleach4 is offline
post #10 of 29 Old 02-05-2014, 02:34 PM Thread Starter
No, they won't register at all. They lights come on, everything else works fine but the tach. I'll be working on it more tomorrow after work and will hopefully figure it out. If I decide to get rid of the stock ones I'll give them to you.
post #11 of 29 Old 02-05-2014, 02:52 PM Thread Starter
What model do you have Clorox?
post #12 of 29 Old 02-05-2014, 04:48 PM
Does the tach sweep? (I think some years sweep, some years dont)
post #13 of 29 Old 02-05-2014, 04:59 PM Thread Starter
No it won't sweep. It used to but won't now
post #14 of 29 Old 02-05-2014, 08:15 PM Thread Starter
I guess a better question would be: Is it safe to drive until I get my new gauges?
post #15 of 29 Old 02-06-2014, 05:06 AM
I would think so....but what do I know?
post #16 of 29 Old 02-06-2014, 08:52 PM Thread Starter
Bumping. In hawaii I have to have a safety inspection, and having a non working tach will keep me off the road. Anyone have any experience with this problem?
post #17 of 29 Old 02-07-2014, 08:09 AM
Yoshis=me smiling
NH919's Avatar
The grease is not to help it conduct its to prevent moisture and corrosion. You don't want to use electrical contact grease as it can cause the contact to short off something it touches or jump to another contact. Just my 2 cents.
02' 919
85' cb450 (wife's)
78' cb550 project
84' z50r son's
09 trx90 daughter's
NH919 is offline
post #18 of 29 Old 02-07-2014, 12:47 PM
IIRC dielectric may be capacative too.
post #19 of 29 Old 02-07-2014, 01:20 PM Thread Starter
PM sent about those gauges
post #20 of 29 Old 02-08-2014, 05:42 PM
The only causes I can think of are a break in the Yellow / Green wire between the ECU and the instruments, no signal from the ECU, one of the small board connectors is not fully seated or, and I have seen this, one of the mounting screws for the tach air motor has come loose enough to prevent an adequate connection to drive it. The cure is to find and repair the broken wire, replacing the ECU , seating the appropriate connector, or tightening all the screws for both instrument motors.
If none of those is the culprit it's time to replace the instruments.
robtharalson is online now
post #21 of 29 Old 02-08-2014, 09:22 PM Thread Starter
Thank you Rob, hopefully that'll help me get it squared away.
post #22 of 29 Old 02-09-2014, 01:35 PM
What year bike? I assume it's a 919? I "think" the service manual has a whole section to troubleshooting this, I'd have to get off my butt and dig it out. I've got a manual that covers through 2004. Let me know and I'll try to scan and post it.
robroten is offline
post #23 of 29 Old 02-09-2014, 04:31 PM Thread Starter
I already tested everything the manual said to test. I have the manual. Thank you though.
post #24 of 29 Old 02-09-2014, 11:02 PM
FYI, we have a .pdf version of the manual under the Helpful Topics for 919 owners sticky thread.
post #25 of 29 Old 02-10-2014, 05:41 AM
doh ! Thanks for the heads up! Just trying to help...
robroten is offline
post #26 of 29 Old 02-10-2014, 08:06 AM
...and appreciated, just didn't want you to waste the time. If you're bored...all things 919:
https://www.dropbox.com/sh/ra9j3gn4czozojw/RW_e95OpKJ
post #27 of 29 Old 02-10-2014, 11:21 AM
Put the gauges on my 2002 yesterday and have a similar issue... However I know why mine are acting that way. Some idiot (me) pulled the needle... Dont do that, its a free way of ruining a perfectly OK set of gauges.
post #28 of 29 Old 02-11-2014, 01:10 PM Thread Starter
What do you mean pulled the needle?
post #29 of 29 Old 02-11-2014, 07:53 PM
I wanted to replace the gauge faces, since they are one big piece you have to pull the gauge needle to remove the face.
