Switching from Castrol 4T 20w50 with Castrol GTX 20w50 - Wrist Twisters
 3Likes
  • 1 Post By rmb
  • 1 Post By badmoon692008
  • 1 Post By KarlJay
post #1 of 28 Old 01-18-2018, 11:37 PM Thread Starter
I don't think it matters, but I bought a few cases of Castrol 4T 20w50 motorcycle oil years ago. I'm finally down to the last 2 qts.
I don't remember if Castrol GTX 20w50 is fine for a wet clutch motorcycle. I know about syn and 'high mileage' oils but I don't remember if GTX is in class.
post #2 of 28 Old 01-19-2018, 02:03 AM
heck the rating on the GTX, I believe it's "energy conserving" meaning it's no good for wet clutches. Look for the API rating on the bottle, must read "JSO MA" i believe..
post #3 of 28 Old 01-19-2018, 11:22 AM
20W50 is not any kind of advantageous viscosity for a street ridden 919.
Do yourself a favour, finish it off and get some JAS 10W40 or better yet a 0 or 5 W40.
20W50 is an air cooled rating also reflecting the limitations of oils of decades ago.
post #4 of 28 Old 01-19-2018, 02:54 PM Thread Starter
So I have a few 5 qt jugs of Quaker State 10w40 API SN. I look up in the book and it says "SJ" or higher. This link lists it but doesn't say if it's correct or not.
MotoMojo: Keep Your Motorcycle Runnin??With the Right Oil
So we're supposed to avoid graphite, 'extra milage', and synthetic, etc...
Q. Does "SJ" or higher mean that if you replace the "J" with anything alphabetically higher, it's OK?
So my jug of QS 10w40 "SN" is fine?
post #5 of 28 Old 01-19-2018, 03:07 PM Thread Starter
According to this (post #177):
Oil and Lubrication Thread! - Page 5 - Motorcycle Forum
API "SN" can't be run in a motorcycle.
Calls to the local dealers say the SN is fine for a motorcycle, but they also say it should be "non automotive" because of the chance of additives.
post #6 of 28 Old 01-19-2018, 04:08 PM
I am pretty sure the SN oils have a depressed antiwear component re catalytic converter contamination concerns.
Considering that our motorcycle cam engines are non roller design, why even contemplate using a SN.
Then there's the issue of 10W40 officially being a non Energy Conserving oil, some makers are still doping their 10W40 with a full friction modifier package.
Oil has become such a circus.
To make life simple, I've been using Rotella T6 5W40, it's a CJ-4/SM that is also an MA, it's for super hot and highly loaded turbo'd diesels, and has a decent extreme temp viscosity rating plus a decent hi shear rating. (the gear mesh in our trannies heavily shears the oil)
Save the jugs for your car is my suggestion.
As for "synthetics", there's a term that has been so mangled over the years it means next to nothing anymore.
post #7 of 28 Old 01-19-2018, 04:13 PM
I got to ask. Could bad oil choice be the cause of your clutch problems?
I'm thinking of going switching oils to maybe see an improvement in gear changes. Honda oil to a full synthetic.
post #8 of 28 Old 01-19-2018, 04:18 PM
I just checked the API website.
SN is for gasoline automotive engines.
There is no such thing as an API SN non automotive engine oil per API.
And SN is classified as an Energy Converving AND Resource Conserving, said Resource Conserving including reduced anti wear compound limits.
What a zoo, eh?
post #9 of 28 Old 01-19-2018, 04:25 PM
Oils do my head in.
Think I'll just stick to the honda stuff. Boring.
post #10 of 28 Old 01-19-2018, 05:10 PM Thread Starter
I don't know if the clutch is original or not, but the bike has some 26K+ miles, so IDK the life of an OEM clutch but if it made it over 25K, I'm happy.
I was running Castro 4T Motorcycle oil and only now have been told it's wrong and only by 1 person. The local deal was worthless for anyone that doesn't want pure Honda oil.
Full or partial synthetic is wrong.
In the end, I don't think the clutch is such a big deal. You have easy access to it, it's a < $100 for all friction plates and if you do both friction and steel, it's still some $160ish. So if I got 25k out of it, that's a bargain.
mcromo44 talks about the gears, I'd be MUCH more concerned about gears than a clutch. You can replace the clutch without pulling an breaking open the engine. Not to mention, finding a new or good used 919 gear set.
I opened the Nighthawk 700S a number of times and it's not exactly a party.
post #11 of 28 Old 01-19-2018, 05:13 PM Thread Starter
What a zoo, eh?
It is a zoo. One guy at a great shop told me I'm overthinking this whole thing. He said just stick with conventional oil. I'm going to run the Quaker State 10w40 API SN for now and maybe a 20w50 in the summer time. Everyone seems to say it's mostly the clutch that's the concern, so I can replace it if needed.
post #12 of 28 Old 01-20-2018, 01:41 PM
I learned my lesson years ago, by putting the wrong type of oil in my 929. Made the clutch slip. My Hondas get Honda Synthetic, in the red container. The KTMs get Motorex Synthetic. Yeah, it may cost a couple of dollars more, but Cheap is Cheap, only in the long run.
Sniper-x is offline
post #13 of 28 Old 01-20-2018, 04:44 PM
Smile
KJ, I suggest you check the particulars of whichever Q S you have.
I did a most cursory search on the Q S site and found their 10W40 SN "Defy", and the tech sheet says the oil has "additional" friction modifiers. Not just some, not just normal, but instead "additional".
Your new clutch plates might thank you for it.
post #14 of 28 Old 01-20-2018, 08:29 PM Thread Starter
Interesting and confusing. One thing I've always heard about synthetic is to NOT use it. Everyone always said use conventional oil.
post #15 of 28 Old 01-20-2018, 08:42 PM Thread Starter
I just went to their site and all it said was "SN". I'm being told SN is fine from one dealer.
TBH, this is just unreal. Something as simple as changing the damn oil, and three dealers are giving me different answers. Honda dealer will only sell Honda oil, one had no clue, the other said I was overthinking everything.
This really can't be this hard.
Anyways, I'm going to run the QS10w40 Advanced Durability an if it's wrong, I'll switch it out. How much damage can it do in one round?
There really should be an easier way to do this.
So much useless info out there, it's just unreal. Mostly the Honda dealer, it's bad enough they won't work on a bike over 10 years old, but they won't even tell you if an oil is right or wrong.
post #16 of 28 Old 01-21-2018, 04:53 AM
It really isn't that hard, use an oil designed for wet clutches in motorcycles. One round will ruin your new clutch.... I use standard Honda GN4 10w40. Have used it since the bike was new and change it every 2k to 3k miles, I can tell when it's time for a change by how it shifts.
badmoon692008 likes this.
post #17 of 28 Old 01-21-2018, 10:36 AM
I use the Honda GN4. Been thinking of going full synthetic. Trying to smooth out the gear changes a little. At times my gearbox is a little clunky, sometimes gears are a little hard to select, sometimes find a false neutral. I'm much better at gear changes than when I got the bike. A few changes to the bike and my technique have made improvements. Now I'd like to try a full synthetic to see if there is a difference. I live in Australia so will use a local made oil. Penrite. Here is an example of what I'm considering.
http://www.ebay.com.au/itm/282074521821
Full synthetic and suitable for wet clutch.
post #18 of 28 Old 01-21-2018, 02:05 PM
HP4S is Honda's full Synthetic, and what I use. Google it.
Sniper-x is offline
post #19 of 28 Old 01-21-2018, 02:43 PM Thread Starter
The hard part isn't in using the correct oil or not, that part is simple. It's that I have a Honda dealer saying yes, a non Honda dealer saying yes, another shop not knowing and a forum saying no.
The hard part is getting humans to agree on WHICH oil is correct. Even the manual isn't clear, it says above J so that means that the wet clutch motor oil from Castrol is wrong, yet it is made for a wet clutch.
Even what you say "use an oil designed for wet clutches in motorcycles" contradicts the Honda manual that says "above J"
SN is clearly above J, yet some are saying no.
post #20 of 28 Old 01-21-2018, 02:58 PM
I didn't know Honda had a full synthetic. I will try to get some.
post #21 of 28 Old 01-21-2018, 03:59 PM
My 2002 Factory Manual says SG or higher, EXCEPT oils labelled as energy conserving.
My 2005 Owners Manual says the same thing.
The manuals are very clear and contain no contradiction, as NO ENERGY CONSERVING OILS ARE TO BE USED.
While more recent specs can be used, what does not change is the exclusion of the use of energy conserving oils.
Keep in mind that for Mr. Honda, the dominant oil spec they invoke is JASO T 903 - MA.
API is secondary, and has to be, seeing as the API oil specs are for gasoline engines, not engines with bathed clutches and/or integral gearboxes.
What Honda is saying, to their credit, is select on the basis of a relevant spec that conforms to their requirements, and to help keep us out of trouble, run and hide from anything labelled as Energy Conserving, and if you want to make your life simple, buy a 'MA labelled oil in the correct viscosity grade.
A higher letter does not mean a better oil.
It just means a new spec has come along for a very specific set of reasons.
SN came out in October of 2010, is intended for gasoline burning engines of 2010 or more recent, that may be turbocharged, likely have rollerized valve trains, require less antiwear additive carryover into the exhaust re Cat' Con' contamination, and may see service on E85 fuel.
SNs are doped with energy conserving additives.
They have reduced antiwear additives.
In very general terms, mass market modern API automotive engine oils have gone in a negative direction in terms of use in flat tappet motorcycle engines with bathed clutches.
Short story, outside of dedicated motorcycle oils, one is best left to buy a suitable API designated diesel oil also with JASO MA markings, such as Shell Rotella T6 5W40 . (So far, I have not seen any JASO MA 0W40 T6, but if I do, I'll switch to that.)
post #22 of 28 Old 01-21-2018, 04:28 PM
A wee bit more...............just to make sure we all get suitably glassy eyed.
In terms of our precious automotive oils, API has 5 classes of base stocks that pertain to them.
I, II & III are all from crude oil.
But some marketers intimate 3s are Synthetics, when if fact they are not, as they all stem from crude oil.
IV is a pure POA "oil", in other words a totally manufactured fluid, and therefore a "synthetic".
V is anything that's not crude oil base, nor a straight POA, sort of a catchall for synthetics that are not POA.
post #23 of 28 Old 01-21-2018, 04:42 PM
It looks as though the oil was conceived and concocted under the governance of JASO, not that there's any problem at all with that.
Have you been able to find out what the API equivalent Base Stock is it made from?
So far, I have not been able to.
IF by chance it's Class III, then technically it would not be a true synthetic.
BUT the price is suggestive of it being a true synthetic.
post #24 of 28 Old 01-22-2018, 07:16 AM
I have 45,000+ miles on my OEM clutch and it's still going strong, and that includes track days and multiple trips to the drag strip (and a good helping of burnouts) I know there are members here with many more miles than that on OEM clutches, and I'm pretty sure the guy with 300,000 miles on his CBR is still on the OEM clutch.
mcromo44 likes this.
post #25 of 28 Old 01-24-2018, 11:40 AM
KarlJay has gone silent for some days now.
I hope he hasn't been driven around the bend from all the conflicting info.
post #26 of 28 Old 01-24-2018, 04:16 PM Thread Starter
Still here, I got the cable installed and the disks soaking. I didn't install the clutch yet, it's actually doesn't seem to be slipping that much.
One of the reasons for wanting to address the slipping as soon as it starts is that the steels are usually good and you can get replace the friction disks. However, if you push it too far, you might end up having to replace both steel and friction, I had that happen on the Nighthawk 700S.
post #27 of 28 Old 01-24-2018, 04:46 PM
I can't remember if cable routing has come up yet re all this.
If you're following the same routing, maybe someone else was there before you got the bike and changed things.
Regardless, seeing as you have the cable fitted and the clutch is not yet assembled, a really good check on the routing is to take the clutch end in your hand and push it back and forth. It should easily be able to "flap" the clutch lever. If it doesn't, seeing as it's a new cable and for sure the correct one, then it's indicative of a cable routing problem and/or excessive friction point(s) at the lever.
post #28 of 28 Old 01-25-2018, 04:18 AM Thread Starter
One of the things I checked first was the pull on the new cable vs the old one, very different. However, it was barely enough to keep the bearing off the clutch. It's like that little spring on the lever needs a bit more. I know that springs wear over time. I think as long as it doesn't let the bearing ride, I'll be ok.
I plan on doing a write up because there's a way to do this that make it pretty simple and these bikes are getting to the age where things like this are going to be an issue.
We have to remember that the NEWEST 919 is now > 10 years old. It would be in our best interest to have a list of things that go bad so that we can keep the ball rolling as long as we can. Cables are pretty much a no brainer, wear item.
Islandboy likes this.
