Switched 12v source help... - Wrist Twisters
post #1 of 9 Old 02-24-2012, 11:13 AM Thread Starter
Jonny's Avatar
So, I got the dual headlight set up in my avitar and I dig it. The low beams throw a wider cast and seem to be an improvement over the stocker, BUT the high beam is fairly narrow.
The way it came was just ground and power for each of the 2 headlights. I used spay connectors to plug the 2 grounds wired together into the green ground of the stock headlight connector, high beem to the blue and low to the white (I think.).
What I want is for the lows to stay on when I go to high beam for better visibility when I want it, so my question is, is there a 12v source still protected by the headlight fuse that is constant when the bike is on that I can T into for the low beams or is there a way to use a relay so they are both on when I flip it to high?
A 12v switched source seems like the simple solution. My only concern is overloading the circuit with both lights on...
Any ideas?
Thanks!
-Jonny
Jonny is offline
post #2 of 9 Old 02-24-2012, 11:49 AM
dont worry about overloading the ciruit jonny, i run my 599 headlight with both lights on for high, and others run with their dominators with both headlights on so you're clear.
post #3 of 9 Old 02-24-2012, 12:03 PM Thread Starter
Jonny's Avatar
Awesome...so...how'd you do it??
Jonny is offline
post #4 of 9 Old 02-24-2012, 12:05 PM
had it wired into the harness when i ordered the harness. i wouldn't be surprised if there's a switch somewhere in your headlight assembly that turns off the lowbeam and switches to highbeam. if you can find it, take pictures of it and we'll figure out how to bypass it so the lowbeam always stays on.
edit: nm i re-read your original post. i wonder if you could re-spade your connectors and bridge the high/low beam? rob would be an excellent source of help on this topic!
PAGING ROB THARLSON!
post #5 of 9 Old 02-24-2012, 12:10 PM Thread Starter
Jonny's Avatar
Far as I know, it's in the rocker switch, but I'll see what I can chase down if I get some free time this weekend. It's not a dire need...more of a something to do while I wait on my exhaust parts...
-Jonny
Jonny is offline
post #6 of 9 Old 02-24-2012, 12:11 PM
i cant remember if both filiments of the h4 bulb is on when in highbeam mode. can anyone confirm/deny?
post #7 of 9 Old 02-24-2012, 12:23 PM Thread Starter
Jonny's Avatar
I think I have it.
If I add a relay to the H beam that is both energized by the H beam and feeds the L beam only when the relay is energized, then the H beam should kick both on.
Just as an add on, leaving all connections for H & L beams the way they are:
86 = H Beam +
85 = Ground
87 = H Beam +
30 = L Beam +
Power from L to 30 is dead end when H beam is off.
When H is switched on, it comes on like normal, but also feed the relay which connects 87 to 30 and also powers the L beam.
That should work, right?? Gold?
4 female spay connectors, 4 Ts and one 4 prong relay and we'll find out!
-Jonny
Jonny is offline
post #8 of 9 Old 02-24-2012, 12:58 PM
that sounds about right jonny. give it a shot and report back to us.
post #9 of 9 Old 02-24-2012, 05:33 PM Thread Starter
Jonny's Avatar
Well it worked... And it didn't. It wouldn't go back to just low beams. Relay stays energized. I found a red and black wire that's switched and hard wired the low beam. All fixed!
-Jonny
Jonny is offline
